#1001
David, Im not sure how far from you, but there's a shop called Classic Pontiac Rescue in Donald's SC. The owner is a member of the Palmetto Pontiac club with many knowledgeable members. Maybe by reaching out you could find some assistance.
#1002
#1003
Ask Caster1 about CPR too. I was a deputy in Anderson County. I can tell you more than 4 horror stories
#1004
[QUOTE=64speed;6348665]Ask Caster1 about CPR too. I was a deputy in Anderson County. I can tell you more than 4 horror stories.
Wow he sounds like complete scum.Just saw his name pop up on the Palmetto club newsletter. Jesse Anderson and until a few years ago, Larry Snyder were also members, although I haven't touched base with them since Larry moved his shop. |
#1005
Dave - any update on this filling system?
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
#1006
Nothing to report,I have been at the beach. Truthfully I am at a loss. I don’t want electric fans but I don’t know what to do.
#1007
I called Derale and ordered their best 16 inch fan. It’s supposed to cool at idle. Trying to avoid that big shroud setup that cold case sells I really don’t want all that under my hood. I got enough crap as it is. I’m not excited about the fan but I gotta do something
#1008
You really need to check your timing first, but since you already pulled the trigger... .
| The Following User Says Thank You to HWYSTR455 For This Useful Post: | ||
#1009
#1010
Ok I have tried and tried to get help with my timing and I can’t get anyone over here. I know my initial should be between 12-15 when cranking. I have the factory bushings in it that came with the Summit ready to run of which they provide you no information. It runs better on full manifold vacuum at idle or cruise but that would be if it’s like an MSD almost 41 degrees of timing. If I back it off it’s starts running like crap.
#1011
Is help needed for technical knowledge? I ask cause I have short arms and adjust timing by myself. Also, are you saying you've tried and verified 15 initial and 10 VA (manifold) and it didn't help with idle temp?
#1012
I can’t see that great but I am pretty sure I’m on 13 initial. When I plug the vacuum advance and it’s just running whatever the distributor advance is it still creeps. Same with ported. If I put the vacuum on it it still creeps just much slower but I can’t get the summit guys to tell me how much advance the can adds. I’m 42 and have cataracts from Prednisone shots so it’s hard for me to see
468/TKO600 Ford thru bolt equipped 64 Tempest Custom. Custom Nocturne Blue with black interior. Last edited by 64speed; 06-21-2022 at 01:10 PM. |
#1013
I would suggest you send a PM to "Suntuned" & his dad and have them set up the distributor on their equipment properly for you. Worth the money to have them check it out on their distributor machine equipment.
| The Following 2 Users Say Thank You to Tom Vaught For This Useful Post: | ||
#1014
Bob, is one of the "answer men", here, and period!!!
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down...
#1015
Your engine is a distributor machine and paired with the information available you are in a good spot to figure things out for yourself. And you might save a few bucks and learn a bunch along the way.
https://www.tapatalk.com/groups/raci.../ignition-f21/ And any info posted by Tuner is very informative including quadrajets. Especially quadrajets. He also modifies HEI advance by bending at the pivot points of the weights. Very smart guy and would likely be the answer man to our answer men. |
| The Following User Says Thank You to P@blo For This Useful Post: | ||
#1016
My nephew is coming this weekend. I am gonna curve the distributor with the kit that came with the distributor as close as I can to the engine builders specs. I also ordered two 12 inch fans and a relay kit. If that doesn’t fix it then I don’t know what.
#1017
I got all my parts today but it was just too hot to work. I did drive it about 60 miles and with the ac on at stoplights it would go up to 200 but I wasn’t at them long. Start moving again and it would go back to about 185. Will do all the work that needs to be done this weekend and report back.
#1018
Sounds like it’s cooling pretty well. If you don’t mind be asking, what temperature are you wanting to get to? Your car hasn’t ever boiled over has it?
Good luck! Murf |
#1019
I agree. I don't think you're ever gonna get this to idle, with the A/C on, and stay near 185. Maybe put it on E85 or methanol. lol I'd say you're lucky to stay near 200. You can throw it in neutral when you're stopped and rev the engine up slightly. This can have a dramatic affect on your temp. I know it's a pain. But it does work.
#1020
I never considered A/C an option on my '64. It was all I could do to keep the 455 cool. I had it under control. But knew that air would put it out.
| The Following User Says Thank You to JSchmitz For This Useful Post: | ||
