Old 06-13-2022, 04:35 PM
i82much's Avatar
i82much i82much is offline
Default Mismatched lug nuts
My 65 GTO has 7/16 wheel studs up front and 1/2 in the back. The larger studs in the rear came with the S60 differential I used.
I have Rally 2 wheels from a later car on both axles. Right now I have the OEM style Rally 2 lug nuts up front with the black center, and parts store chrome 1/2 lug nuts in the rear.
Is there a way to get 1/2 Rally 2 lug nuts for the rear with the black center? Maybe the big cars had 1/2 lugs? Any other ideas?
The Following User Says Thank You to i82much For This Useful Post:
Old 06-13-2022, 04:38 PM
72projectbird's Avatar
No idea if they make original style in 1/2", but you could paint the tops of the larger lugs black to make them look original-ish.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 06-13-2022, 04:44 PM
25stevem's Avatar
25stevem 25stevem is offline
The only option on the B body cars was the 8 lug set up, but it was still 7/16”.
I do stuff for reasons.
Old 06-13-2022, 05:05 PM
misterp266's Avatar
McGard sells black plastic inserts for open ended lug nuts. But they don’t say what size they are.....
https://shop.mcgard.com/black-nylon-...set-of-4-plugs
" Darksiders Rule "
Old 06-13-2022, 05:44 PM
77 TRASHCAN's Avatar
Google Dorman, they make all kinds of lug nuts...
Shut it off
Shut it off
Old 06-13-2022, 07:04 PM
Verdoro 68's Avatar
YearOne sells 1/2” RII lugs made for Year One Rally IIs. They might might work. I have a extra set if you want to give them a shot.
https://www.yearone.com/Product/wheels/125bas
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 06-13-2022, 08:20 PM
i82much's Avatar
those look perfect, i will order a set. i think they should be fine. thanks for the heads-up!
Old 06-14-2022, 07:48 AM
I pulled Half-Inch Lug nuts from a 69 Bonnevile with Rally IIs. They were decrepit though.
So they existed, but ever repopped? (Year One eh)
I have the S60 with Half-Inch Studs and wagon 15x7 Rally IIs and use lug nuts from the 95 Lincoln Town Car. Stud ends sharpied black.
