Old 06-30-2022, 10:56 AM
Sport69 Sport69 is offline
Default Instrument pod LED lighting
So I've been playing around with brightening up my dash lights from the original dim 194 bulbs. Here's a set that's 400 lumen, I think they're bright enough without painting the inside of the pod white, but it is an option, it's currently blue (attached pic). Thoughts?
Pic 1. Instrument pod
Pic 2. Lights on
Pic 3. Lights off
ID:	593475   Click image for larger version
ID:	593476   Click image for larger version
Cholesterol Bad Adrenaline Good
Do it till your eyes bug out!
Old 06-30-2022, 11:21 AM
One of the better modifications I did was putting LED's in the gauge pod. I don't have the ability to dim the lights, but that's fine on my end as I usually have my instruments on full bright anyhow.
I was tempted to try out red LED's but didn't want to pull the backing to repaint over the eggshell blue, which would have created a purple hue. I like it and I would run with what you have if I was making the decision.
-Jason
1969 Pontiac Firebird
Old 06-30-2022, 12:14 PM
I believe you're right, I think they're 1000% better than they were, without doing anything more. Thanks...
Old 06-30-2022, 12:25 PM
The only thing I would mention here is that I would put a new traditional 194 light for your GEN dummy light. While an LED there won't cause any engine run-on or other mechanical/electrical issues, the LED doesn't provide enough resistance to function properly itself. Mine no longer illuminates on key-on or when in acc mode or car off with lights on.
Just something to think about.
-Jason
Old 06-30-2022, 12:36 PM
Does using an LED in the GEN spot make it inoperable if the alternator quits charging?
Old 06-30-2022, 12:38 PM
Old Goat 67's Avatar
The one I put in from Super Bright LED'S do.
Old 06-30-2022, 12:52 PM
I don't know, but considering how it acts in a car off ignition on setting, it's quite possible.
-Jason
Old 06-30-2022, 01:41 PM
dataway's Avatar
dataway dataway is offline
So now you tell me ... I was wondering why it doesn't come on at start anymore. Going to be tough to reach up in there and change it now
Old 06-30-2022, 01:44 PM
Yeah. I saw the bahavior a little while after I put the interior back together.
All I could do was sit in the driver's seat, admire the view, take a deep breath and think to myself...
-Jason
Old 06-30-2022, 02:18 PM
grivera's Avatar
grivera grivera is offline
Do the LED 194s install one way only to work? Polarity sensitive?
Will Rivera
Old 06-30-2022, 03:13 PM
No polarity, install either direction. They're dimmable too, but they'll only dim about 50% not completely like the originals.
Old 06-30-2022, 04:55 PM
Some LED's are polarity sensitive. Not all are dimmable. The cheaper ones you can get through amazon etc typically won't have the ability to dimm and are likely polarity sensitive.
If you purchase LED's that are polarity sensitive, having the cluster out to where you can see the printed circuit and it's ground paths is almost essential. If you're trying to do this with the cluster in the car, buy the higher dollar LED's that don't care.
-Jason
Old 06-30-2022, 07:52 PM
Angry
JL, the ones I purchased were off of Amazon, they're not polarity sensitive (a big plus), and they dim down to about 50% of their brightness. They were around $16 for a pack of 10, more than enough to do my gauges, are 400 lumens, and the best ones I've found. I hope they hold up good, and I have no reason to believe they won't from their reviews. I wanted to be able to see my dash lights at night, these will definitely allow that now!
I have my dash out so it made it much easier doing comparisons, and testing out different ones. All I had to do was plug in the instrument pod, ground it, and turn on my headlight switch. I had previously tried some that were 135 lumen but found out pretty quick that they weren't bright enough.
This is the fourth time I've had my dash out for various reasons since 2014, I don't plan on there being a 5th, it's not a fun task!
ID:	593507   Click image for larger version
Old 06-30-2022, 11:45 PM
Tuske427's Avatar
Tuske427 Tuske427 is offline
I have LED's in my car, and painted the back area fluorescent red as well. I also use dimmable LED's and love it. brighter, less power required, less heat to dry out the plastic, all a win win imo.
Long live the Muscle Car
Instagram @tuske427
1967 Firebird #BVbird
1967 Firebird 400 4 speed project
1969 Verdoro green GTO (daily)
The Following User Says Thank You to Tuske427 For This Useful Post:
Old 07-01-2022, 01:50 AM
dataway's Avatar
Mine are polarity sensitive and don't dim. Dimming ... not concerned, polarity though is a pain to keep straight ... and if you have to reach up there and change one .. not fun to have to do it twice because you got the polarity wrong.
Old 07-01-2022, 08:10 AM
Tuskegee, that looks really good. I agree, a win win.
The Following User Says Thank You to Sport69 For This Useful Post:
Old 07-01-2022, 08:12 AM
Data way, I hope I never have to screw with this ever again in my lifetime, but that's probably too much to wish for, lol.
Old 07-01-2022, 03:00 PM
dataway's Avatar
This thread has now added to my to-do list ... going to have to remove the left side AC duct and see if I can get in there and change the Alt light back to conventional ... luckily it's down low and sticks out some in the back.
Old 07-01-2022, 04:33 PM
Smile
Dataway, get a young lad (son, grandson, neighbors kid, lol) with small hands and see if he can reach it. Just a thought.
Old 07-03-2022, 06:45 AM
grivera's Avatar
Do you have a link for the ones you bought?
Will Rivera
