Old 07-17-2022, 11:37 AM
461-69bird's Avatar
461-69bird 461-69bird is offline
Default Comp 290b cam users
I'm going back to my 290b after my roller damage. I have better flowing heads now, 300 from 240 when I used it before. When degreeing this cam, where would you install it? I don't know how it was done in my old 400.
69 Firebird
472, Bullet SFT, KRE 85cc, Victor, 850xp, TH400, TSP 9.5" 4800, 3.90 10 bolt, Viking DA rears, QA1 single fronts, 3558lbs. best to date 11.14@120
Old 07-17-2022, 04:52 PM
AG's Avatar
AG AG is offline
What's the LSA?
Old 07-17-2022, 07:50 PM
461-69bird's Avatar
69 Firebird
Old 07-18-2022, 06:25 AM
25stevem's Avatar
25stevem 25stevem is offline
If have always used it straight up or 2 degrees advanced just to make up for chain stretch.
That 2 degree key is very hard to come by these days!
I do stuff for reasons.
Old 07-18-2022, 08:08 AM
Surely change out them roller lifter springs to. flat tappet springs
Will be most interesting to see same or improved performance!
Old 07-18-2022, 02:03 PM
461-69bird's Avatar
His, yes I'm going to change springs and pushrods
69 Firebird
Old 07-19-2022, 09:08 AM
RJRjr's Avatar
RJRjr RJRjr is offline
That cam worked great when I used it. Installed straight up.
Old 07-19-2022, 10:32 AM
461-69bird's Avatar
Thanks, good to hear first hand.
69 Firebird
Old 07-19-2022, 11:13 AM
RJRjr's Avatar
Yeah, it was in my car when I first broke into the 10's. 370 gear, ati 4500 converter 463" 11.5 compression e- heads. Ran best of 10.81 @124.5. Have since lowered compression and went small .420 lobe solid roller. Car was slightly faster with 290b. 10.90's now.
Old 07-19-2022, 06:21 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Do a search in this section.
There was a guy that ran in the low 10's high 9's with that cam with 310 cfm d-ports.
May have been on E85 though.
Old 07-20-2022, 12:31 AM
I've seen that cam in a 450ci IA1 with edelbrocks go 9.90's in a 70 gto back in 2002.
The car was gutted with a glass hood but it wasn't super light.. it was a guy named Dalton out of Chesapeake VA..
The engine was built by Jim lehart ( not a fan so don't kill the messenger) .. it ran good..
Old 07-20-2022, 05:05 AM
461-69bird's Avatar
It was Jim who built my previous engine with the 290b in.
69 Firebird
Old 07-20-2022, 09:20 AM
i82much's Avatar
i82much i82much is offline
is that this engine?
https://forums.maxperformanceinc.com...d.php?t=772253
I have some experience with that shop as well ...
Old 07-20-2022, 10:04 AM
What year was that and how did it go? I ask for a specific reason...
Old 07-20-2022, 10:42 AM
i82much's Avatar
approx 2009-2013. as i recall it lost a solid flat cam, blew a head gasket, broke a rocker stud (which i think took out the solid roller cam), and threw a rod through the pan driving down the interstate.
since having it redone at another shop it runs great.
kinda sad, i liked jim and it seemed like he did everything he could to make things right. i do not really understand what happened.
Old 07-20-2022, 01:46 PM
461-69bird's Avatar
Yes that was mine.
69 Firebird
Old 07-20-2022, 09:00 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
Not intending to hijack but what is the minimum/maximum compression range of the 290b6?
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 300CFM D-ports, Howard's custom SFT, Nash Intake,QFT 950 E85 carb, TCI TH-350, 4200 converter 3.73 12 bolt [email protected]
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1972 LeMans 350 Pontiac H/S Drags project
Old 07-21-2022, 06:26 AM
25stevem's Avatar
It depends on how many cid where dealing with also?
Old 07-21-2022, 01:13 PM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
I've never used them in a 400 but I put them in at 102 in the 455's.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 07-21-2022, 07:06 PM
461-69bird's Avatar
Jack, mine is a 472 stroker, does that make a difference?
69 Firebird
