#61
Mine are 3/4" NPT.
'65 Tempest 467 3650# [email protected] |
#62
lets confuse things here-- I ran a reverse cooling -- remote pump with lines to the back of each head then out the front at the original water pump inlet holes and the thermostat housing. BOP made some nice fittings to bolt up there to have AN hose thread right on.
#63
The IA2 block we run in Fairmont is reverse cooled. Race only and it was done to cool the heads first since it's a 1000+ hp nitrous application. The block is run dry deck with no water cooling passages into the heads. It uses a remote mounted Meziere 55gpm electric water pump. The water travels out the front of the engine, thru a fixture that eliminates the block mounted water pump, into the front of the heads, out the back of the heads into the block, which has water passage provisions for it in the rear of the block, then thru the block back to the front. The system uses a radiator. The remote elec water pump is located on the lower outlet of the radiator.
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE |
| The Following User Says Thank You to Steve C. For This Useful Post: | ||
#64
I removed the adapter and put everything back to the way I had it setup last summer. I don't like the idea of not running a thermostat. I routed the back of both heads to the front water crossover, and also went to the timing cover heater return. I also left in place the bypass. And drilled 2- 1/8" holes in the thermostat to remove any air. I used -10 for all my fittings and just used heater hose line for now.
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 3:90 gear. 28" slick. Best so far 9.95@135 mph. 1.39 60 ft. 76 Trans am, TKX .81 o/d, 3.73 Moser rearend, 468 with KRE D-ports, Doug headers, 3" Exhaust 950 Quickfuel. |
#65
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind, E85 Holley Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
| The Following User Says Thank You to R 70 Judge For This Useful Post: | ||
#66
After quite a few months of waiting and waiting I’ve decided to design and build my own CNC aluminum water manifold adapter/thermostat housing for a Pontiac. The final touches are being put on the design file now.
If there are additional features that anyone feels should be integrated let me know and I’ll consider them. I expect this to be a very limited run. I haven’t decided on how many I’m going to produce yet. This is just a fun project. Btw if you need pieces for a LS or the new LT4 these are currently available. Contact me for info. (see attached)
#67
Are you making a spacer that will allow #8 orb fittings?
will those fittings be under the T stat or above it? just looking to see if i add additional rear cooling from heads to the front, i wanted to see if there is a solution like i saw with a SBC spacer where the t-stat sits on top of the spacer and the #8 ORB fittings are below this way it helps to control temps from being to cold, at least that is my understanding i might be interested Quote:
#68
#69
R 70 Judge PM sent
#70
Interested. Let us know the final details when you have them. Thanks for your efforts.
#71
"Artificial intelligence is no match for natural stupidity". 1966 GTO Post Coupe, 467ci. N/A Pump gas, best 1/4 11.6 118mph 1966 GTO Post Coupe, "The Bright Idea" 535ci. N/A Pump gas, best 1/4 9.56 139mph |
#72
Just an update on my thermostat and coolant setup. We ran the Car at Mission B.C. track this past weekend. Temperatures during the day were hitting 38*C or 100*F. It was very hot. The announcer was saying the track temp was around 140*F. Car ran great. The temperature on the engine never went past 180* The thermostat is at 160* After a run and back at the pit area the engine temp was 170-175*. We cooled it down with the fans and electric water pump. Works very well to cool engine down. Even with the thermostat and two holes drilled in Thermostat, the engine cooled to 140* very easily. Car ran a best of 10.11 at 133 mph. I still having traction issues which I'm going to address. Visited with Dave from S.D. Thanks to Dave for the tips on the Suspension.
#73
My engine is hard blocked with .006 piston to wall and I want it to warm up as fast as possible. |
#74
If you need something right away and don't care that both -8 coolant lines are on one side you could possibly redrill the Meziere piece to fit a Pontiac.
#75
How much $ ? |
| The Following 2 Users Say Thank You to Dragncar For This Useful Post: | ||
#76
Did you ever make any thermostat versions ? I tried to order the ones with the disc but they are 6 weeks out.
#77
If you are desperate for one ASAP I suggest buying one from Meziere and redrilling it for a Pontiac. https://www.meziere.com/Products/Coo...t-Spacers.aspx
#78
On a race only application: electric pump, electric fan, coolant restrictor with 1" hole. A 3/8 aluminum line from the rear of each head to the thermostat housing above the restrictor. Works like a champ. When I do the E-85 changeover in the spring, expecting to drop radiator size a goodly bit.
Clutch Guys Matter _______________________________________ 53 Studebaker, 400 pontiac 72 4-4-2 Mondello's VO Twister II 1964 F-85 Home of the 700hp small-block Olds **Still wanting a 64 Bonneville or Catalina** |
#79
Okay I have an update. Funkhouser’s ended up fabricating a low profile water neck for my build. As some of you know I’m in the process of switching to efi and eventually turbos so I wanted a forward facing throttle body. He tried a CSR 360* swivel water neck but it hit my intake pipe/clamp so he whipped this up in Solidworks. This design is very different than a traditional water neck.
Features:
Also, if anyone is interested in remote power steering brackets (clears driver’s side turbo manifold) or Holley smart coil brackets please let me know ASAP.
#80
What a sweet engine.
