Old 08-22-2022, 07:37 PM
64speed's Avatar
64speed 64speed is offline
Even in a worst case scenario this may be a blessing in disguise. I never liked the ticking of the Lunati lifters. IF I need a cam and lifters what should I be looking at. I have the TKO600 with the .64 final drive and 3.70 gears with a 26 inch tall tire. I looked at the Lunati website in case my cam is not salvageable and they are out of almost everything. My machinist is of the opinion that since its running right now that there is a small chance of a catastrophic failure and that no machine work should be necessary other than checking the bearings. I am going to replace the Torker with a Performer RPM. Any other suggestions before I drop it off next Monday?
  #1182
Old 08-22-2022, 07:40 PM
grivera's Avatar
grivera grivera is online now
Did builder say to do any inspection yourself prior to taking to him or just bite the bullet and pull it?
Will Rivera
  #1183
Old 08-22-2022, 07:47 PM
64speed's Avatar
He will not touch it with it in the car, he is too old and crotchety to be bending over a fender. My nephews and I can have it out in 45 minutes so I will take it out ASAP and take it down there. He is backed up and I am broker so I will be making payments on parts necessary and he will work at his pace, I told him as long as it was back on the road by March so I can go to Myrtle Beach for the car show I would be happy.
  #1184
Old 08-22-2022, 08:09 PM
64speed's Avatar
What are the absolute best pushrods I can get
  #1185
Old 08-22-2022, 08:27 PM
grivera's Avatar
Wish I could answer that but it being said, What’s wrong with the brand of pushrods you have now? I’m sure you know, this is unlikely to blame on the pushrods.
Will Rivera
  #1186
Old 08-22-2022, 08:54 PM
64speed's Avatar
Well I’m getting 16 pushrods cause I don’t want to replace just two. Just wondering
  #1187
Old 08-22-2022, 09:02 PM
grivera's Avatar
Definitely understand that as different lifters will likely require a different length pushrod. Do you have the build sheet for your engine? May say the brand and wall thickness of the ones you have now.
Will Rivera
  #1188
Old 08-22-2022, 09:34 PM
64speed's Avatar
Wayne has it. I’m hoping this goes smoothly and I can be back on the road in about 3 months. Will definitely be getting and MSD box with rev limiter
  #1189
Old 08-23-2022, 10:09 AM
When you get the rockers off, take a pic of the tops/tips of the valves, can see if the pushrod length was a factor. Might as well take a pic of the bottom of those rockers on #2 as well. Or a few of them.
I would say the most likely cause is retainer clearance, but if that's the problem, it's going to be a builder issue, and he may just do the same thing over again. (since he didn't check/catch it the first time).
  #1190
Old 08-23-2022, 10:13 AM
Smith Bros pushrods are pretty good, and pretty affordable. Butler sells them in lengths of .050.
Some people prefer thicker wall ones, or larger diameter which requires changing the guide plates.
  #1191
Old 08-23-2022, 10:14 AM
Rev limiter? Do you think you over-revved it?
Just to say, over-revving is generally not a cause of bent pushrods.
  #1192
Old 08-23-2022, 10:25 AM
Nobuddy Nobuddy is offline
Is this the engine with big Chevy rockers because the machinist determined Pontiac rockers had incorrect geometry?
  #1193
Old 08-23-2022, 10:38 AM
grivera's Avatar
Here it indicates he was planning Lunati (unknown specs) pushrods...https://forums.maxperformanceinc.com...&postcount=165
Hopefully you get this all resolved with minimal damage!!
Will Rivera
  #1194
Old 08-23-2022, 10:43 AM
I missed that point, what's the post # on that? Or different thread?
Nevermind:
https://forums.maxperformanceinc.com...d.php?t=831609
  #1195
Old 08-23-2022, 10:45 AM
64speed's Avatar
Yeah I over revved it. I missed 3rd and it hit about 7000. Caster1 has almost exact engine in his car and has no problems from it. I am pretty sure I over revved it and that was it. It holds 10 pounds at idle even coasting down the road and ran fine other than a skip from the dead cylinder. I am hoping I can drop the pan, clean it out, put lifter and pushrods in and seal it back up.
  #1196
Old 08-23-2022, 10:50 AM
From the other thread:
"My Machinist up using bbc rocker arms because even the 1.65” riockers we tried from three different brands ended up not being able to get a good contact pattern on the valve tips. I have no idea why but they bolted right on and work just fine"
This is a red flag for me...
  #1197
Old 08-23-2022, 10:51 AM
My comment on the other thread:
"Hm. Something is askew here, I know I would like to see pics.
You say the 'geometry' is perfect with the BBC rockers? I know I would like to see a pic at mid lift. I'm guessing that the 'contact pattern' approach was used.
Also would be curious to know which lifters were used and the pushrod length. I'm betting there's a pretty short pushrod being used."
  #1198
Old 08-23-2022, 10:54 AM
Lifters probably came out of the bores.
Like I said, over-revving rarely causes a problem like this.
  #1199
Old 08-23-2022, 11:02 AM
More red flags from that post....
Block and all parts except for pushrods, gaskets (except head) and cam bearing are going to machinist Tuesday. We have worked out a deal I’m not gonna get in a hurry and give him until midsummer and in exchange he is gonna align bore the crank and came tunnel, fit the studs to main caps, assemble pistons to rods and ring the pistons, degree cam, zero deck block, do all the cylinder bore and home and everything else that goes into it including assembly and testfire and break in for 1600. He will be providing the Lunati pushrods, oversized cam bearings, and all gaskets except for head. I think that’s a hell of a deal. What are your thoughts?
  #1200
Old 08-23-2022, 11:11 AM
Looks like he's a Chevy/Chry/Ford guy:
http://www.cmengines.com/Engines/Str...5/Default.aspx
