Originally Posted by MDGOAT69
Car is a 4 speed, so I think that gives me a little more wiggle room?
Earlier in the week I picked up a cam from a member here for very cheap that I thought would work pretty well with this lower compression build, a Crane H272-2, I’ll attach the specs, but I think it may be a good match? If not, I’ll definitely go with the 2802, I know that’s been a popular option.
Good info there, impressive numbers
That cam will work fine for your project, especially since you already have it. If you want to optimize the combination, retard it a couple degrees and add 1.65 rocker arms.... You will have a strong running engine.
