Old 10-24-2022, 09:45 AM
charlie66's Avatar
Originally Posted by 73 TRANSAM View Post
I would go at least 55 on the squirters.
I had a .055 front and rear . But i feel i dont need it in the front so i backed it to .045.
I think the problem is in the back ..
My Half AN Injun.....
  #62
Old 10-24-2022, 09:46 AM
So 91 octane gas was to expensive?
  #63
Old 10-24-2022, 09:48 AM
charlie66's Avatar
5 dollars a gallon . E85 is 2.40
  #64
Old 10-24-2022, 10:03 AM
Fuel consumption will increase as well. Higher ethanol content increases water contamination issues in your fuel system. People I know that race with it drain their fuel system after a race and put good fuel in to let it sit.
  #65
Old 10-24-2022, 11:10 AM
charlie66's Avatar
[QUOTE=chiefbigb;6381958]Fuel consumption will increase as well. Higher ethanol content increases water contamination issues in your fuel system. People I know that race with it drain their fuel system after a race and put good fuel in to let it sit.[
Ok, Thank you ..
  #66
Old 10-24-2022, 11:29 AM
grandville455's Avatar
Originally Posted by charlie66 View Post
2 emulsions for each main well .028 .
.182 for the booster hole
Not your booster pin size, the holes in actual booster in the venturi
Darby
M/T 275/60 ET SS Drag Radial
  #67
Old 10-24-2022, 11:55 AM
charlie66's Avatar
[QUOTE=grandville455;6381968]Not your booster pin size, the holes in actual booster in the venturi[/QUO
.500
  #68
Old 10-24-2022, 12:02 PM
Have you advanced the timing?
Alcohol loves the extra timing.
Try advancing the timing 6-8º or so.
That would help the 'bog' also.
  #69
Old 10-24-2022, 12:24 PM
charlie66's Avatar
no i haven't. Its locked out at 34
  #70
Old 10-24-2022, 12:29 PM
shaker455's Avatar
Charlie
Pick up an external linkage kit.
You have more primary throttle blade articulation before pulling secondary side open.
Hope you still have ' Turbo Louie"
  #71
Old 10-24-2022, 12:45 PM
[QUOTE=charlie66;6381977]
.500
These holes, not the ID of booster
Darby
  #72
Old 10-24-2022, 01:00 PM
charlie66's Avatar
Originally Posted by shaker455 View Post
Charlie
Hey Jeff. I want to keep it at 1:1 if i can .
No Louie is gone unfortunately...
  #73
Old 10-24-2022, 01:07 PM
charlie66's Avatar
[QUOTE=grandville455;6381994]
Oh i see what you mean now. What size are yours? I assume yours is sized for e85?
How did you get that apart like that ? Not sure if mine comes apart. I tried pinning mine back when i converted but i don't remember the size of them . I think i made a area calculation in comparison to the .182 pin size and it was close . But i cant remember. Its hard to pin them when there all together ..
  #74
Old 10-24-2022, 01:18 PM
Dragracertoo Dragracertoo is offline
Charlie66, Read this, https://www.horsepowerinnovations.co...nd-conversions
Booster big hole is about 1/2 inch with 12 smaller holes inside ( don't know sizes )
PVCR is big difference between ours
I believe yes on exposed .078 transition slot
Might want to buy E85 conversion blocks
I believe it's hard to flood with E85, Give bigger jets and squirters/cams a try.
I've raced with E85 for 20 years with purposed built carbs, saved a ton of money, go 8.90 NA, 8.60 with 100 shot for3- 4 sec. Good Luck with your 1050. Rich
  #75
Old 10-24-2022, 01:55 PM
shaker455's Avatar
Sorry, Louie was awesome!
With external linkage you have the ability to do progressive thru 1:1 easily.
I have seen where 1:1 can produce a huge lean condition.
  #76
Old 10-24-2022, 02:44 PM
charlie66's Avatar
I read the article thank you Rich....
  #77
Old 10-24-2022, 02:55 PM
charlie66's Avatar
Thanks Jeff.
Yeah i understand how it makes it lean. Im just trying to keep it 1:1 if i can. I feel like i barley got it to work with gas . Took a lot of trial an error ..
I was thinking of closing down the front a bit and try to open up the back blades some for some more range in the slot (Or maybe lower the slot) . It seems like these dominators like being closed in the back more then the front . I say this because anytime i square up the blades to slots like the front it runs up the idle really high. So if i close up the front some i can open up the back more . Its just a thought...
  #78
Old 10-24-2022, 03:19 PM
[QUOTE=charlie66;6382003]
I SIZED MINE FOR MY 1250, I think stock 12 hole is 0.52? They need to be bigger then that for E85. They just press out, u can make a simple tool to get them out with banjos still installed in venturi
Darby
  #79
Old 10-24-2022, 03:20 PM
.078 isn't the length its the size of the restrictor that feeds the slot
Darby
  #80
Old 10-24-2022, 05:05 PM
charlie66's Avatar
[QUOTE=grandville455;6382026]
Do they get pressed out form the bottom or the top? So in other words , Turn the carb over and go through the throttle blades to press out ?
