#121
I remember back when i was tuning with 91 . I was having a rich problem with my original older 1050 . I couldn't get it lean enough in the mid range. So i changed over to this newer one im using now which got me to the AFR i was looking for. So im thinking of setting up the old one for e85 and see if i can get it richer . Maybe there's something wrong with this newer one im using now.. Im not at the point to go EFI . I want to get it working with the carburetor.. EFI is nice to have . Its nice being able to log ..
My Half AN Injun..... |
#122
What AFR are you at @ WOT ? Whats your target that you shoot for ?
#123
What worries me is will a 12.6 afr be lean enough to burn the motor up on e85 that naturally aspirated ?
#124
I’m using my fast afr meter which was for gas, n it’s hard to read cause it’s used but it looks like it’s around 12.0? I have the A1000 pump .
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,[email protected]@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected] M/T 275/60 ET SS Drag Radial 2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's |
#125
#126
#127
I know what you mean . I have mine mounted on the dash right in front of me and its still hard to read .
#128
The motor seems to really like the tune at 12.6 . But from all that ive read and have been told by a the fast n/a guys at the track is to shoot for 11.8 to12.0 with a #7 heat range for the plug. But i use a #8 because i like the color of the plug better then the #7. This motor makes peak power at 6600 but i shift 7200 into third because it recovers instantly .. With that said id rather be on the richer side of the tune..
#129
I made them small just to jump on the extreme side because everything i was trying wasn't resulting into any positive change . So i just left them there . I usually have them between .024 - .026 . So basically i was experimenting . I was surprised when nothing changed..
#130
What do you think of the Magnafuel 750?
#131
The pro tuner 750 (4303) is a big dog. I used the 4302 (525) til I went to an in tank set up.
'65 Tempest 467 3650# [email protected] |
#132
But if this pump i have for my Ventura is the problem then i really need to figure it out. I mean its passing the gph test for the HP i have .. Im chasing my tail now lol..
#133
How are you feeding the current pump? Fuel cell? Stock tank?
#134
stock with sump
#135
That should work fine as long as it's in the lowest part of the tank. Maybe the 125 pump can't keep up against the g force?
#136
I mean , thats a good point . You cant test it going down the road right. lol
#137
My friend is telling me he has a Holley blue with a 509 on E85 making 700 with no problems. So idk what to think at this point ...
My Half AN Injun..... Last edited by charlie66; 10-29-2022 at 09:58 AM. |
#138
Understood.
#139
I wish i had another pump to just try. Id be all for it...
#140
I have a Domi E85 Brand New built by Kevin At CSU Im thinking about selling
I got my EFI working well again |
