I see that SD Performance no longer ports cast iron heads per their website.
So.. who would you all recommend?? I've got a set of 12s and a set of 62s that I'd like done. Rob
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int 1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int 1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int |
Spott's Performance
| The Following 2 Users Say Thank You to chrisp For This Useful Post: | ||
Paul C at Carter Racing may be one place to check. He may or may not be porting iron heads.
Another one that was part of an engine build I got involved in is Dan Barton. He ported a set of 72 455HO heads that I had Paul C rebuild and flow test. The port work on those were excellent. Don't know if Dan is still porting iron heads these days or not. Iron has seemed to fall out of favor with most head porters when you have a market flooded with aluminum offerings these days. |
| The Following User Says Thank You to Formulajones For This Useful Post: | ||
this place says they do. no personal experience as of yet.
http://www.nitemareperformance.com/ bill has in the past (has a nice cnc macine), don't know if he still does. http://carlquistengines.com/
“We don’t build a ‘luxury’ car. We build a performance car then we make it luxurious.” |
| The Following User Says Thank You to Matt Meaney For This Useful Post: | ||
Marty Warden in Charlotte NC area did a set of 670s for me
| The Following User Says Thank You to chiphead For This Useful Post: | ||
JBP ports iron heads but it looks like you buy directly with option to send in cores. Would be worth asking if they'll just perform the work on yours: https://butlerperformance.com/i-2445...tegory:1234782
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb Last edited by grivera; 01-24-2023 at 01:59 PM. |
Jim Robertson He posts on this forum.
Stan
Also consider Paul Knippen who posts here. He is very adept at porting cylinder heads and has a flow bench. His cell is 630-400-4441
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE |
| The Following 2 Users Say Thank You to Steve C. For This Useful Post: | ||
He has the highest flowing set of Pontiac iron heads on earth. So yeah, Jim.
How many other guys run a 8 second NA Pontiac with D ports ? |
Paul Knippen knows how to make power Last edited by slowbird; 01-26-2023 at 02:39 PM. |
| The Following User Says Thank You to slowbird For This Useful Post: | ||
Did you try Automotive machine in Pekin? Alan left whats left of Mullvains or weddle and works over there now I believe. Id never stop foot in that shop again. they tried screwing me over and everyone else apparently
Illinois Outlaw Gassers 6.27@107 9.97@131 |
What I have on this list is 9.48 @ 142.87 @ #3385 If anyone has any faster runs for Jim please forward me that information. Stan
He did do the 320cfm pair of 48s that made 871 HP. Not sure if it had any power adder but you would think it could have. |
https://forums.maxperformanceinc.com...d.php?t=860361 Not close to 8s. Jim is great, no need to embellish what he's done. |
https://forums.maxperformanceinc.com...ght=320cfm+48s |
Might have taken a light car, so what. The Butlers had some guy do it years ago with D ports; Dan had a guy who could run 8.90s with his RAIVs a long time ago too. But for some reason you want me to admit I am wrong. Jim has been 9.39 with 96s. That a pump gas head. 8s are possible with smaller chamber, more CR and lighten the car up. Or real close to it. |
Jim's 9.39 was not on pump gas and was not low compression. You need to check your "facts" better. |
Jim is from pics on his site does great work
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119 |
I also wanted to add getting good low lift flow #s 265 @500 is fairly easy with little work on the short turn.After 500 or right when ,and it will #s will fall off by 20-30.The talent of porting the d port is getting that 265 back and biting at the str to extend that to 300 or 325.I wonder if he is using or any other porter of these heads a 2.19 valve?Cast heads are tough, messy,hazardous to the lungs,kills burrs,takes time and porters don't get paid enough
