Mine is as basic as they came. I don't think it has any options other than the GT package.. The one I had 40 years ago had the same 350 but it did have the 4 speed, tach in dash, wood grain cluster, PS, PB , vinyl seats. and trim rings When I drop the gas tank I hope to find the build sheet. I have high hopes it will be there as I am only the third owner. The car seems to have been maintained by the original owner just enough to keep it going till it came off the road in 92. It hasn't been messed with much as far as I can tell.. Last edited by 79 Phoenix; 02-04-2023 at 07:34 PM. |
Funny how the option sheet does not say boo about what transmission it has - I gather that if nothing is mentioned it defaults to manual 3 speed?
correct, if the option page does not list it, then it had standard equipment.
Dennis |
| The Following User Says Thank You to Scarebird For This Useful Post: | ||
HD Muncie 3spd was only avail as one ratio transmission as the standard equip trans in GT-37's & GTO's. Nearly all non AC 71 GT-37's, I have info on from the Survey, have 3.55 gearing.
Original AC equip 455 HO stick 233's like Dennis's HO GT-37 & my HO Coupe received 3.31's. Non AC received 3.55's. When a GT-37 was equipped with factory AC & a 350 2bbl stick or 400 4bbl, the ratio in the original 10 bolt would be 3.23.
| The Following User Says Thank You to 'ol Pinion head For This Useful Post: | ||
I believe the HD M-13 3-speed first gear ratio was 2.42, so better than the 2.20 first gear of an M-22 behind the 455HO engine.
Dennis |
| The Following User Says Thank You to SD455DJ For This Useful Post: | ||
earlier comments were in connection to the HD Muncie 3spd in '71 Pontiac GT-37's & 400 GTO's, definitely a few different ratios in 3 spds of this era. The Coupe's original M22 & 3.31 XUK will see little time in the car.
Buzzards gotta eat... same as worms. Last edited by 'ol Pinion head; 02-05-2023 at 02:35 PM. |
The 69-74 Muncie three speed only had two ratios:
The ‘car’ or “B” ratio: 2.42/1.58/1.00 The ‘truck’ or “A” ratio: 3.03/1.75/1.00 I believe that GM’s designation for this transmission was an SM-330 - but depending on the model year, platform or model, it could have one of several RPO’s. I have read on occasion that some full sized cars could get the “A” ratio, but to date I have not found anything to confirm this. My observations suggest that “B” gear set transmissions always had a front bearing retainer with an OD suited for a car bell housing, and a tail shaft for a floor shifter, while “A” gear set transmissions always had a front bearing retainer with an OD suited for a truck bell housing, and a tail shaft with no provisions for a floor shifter. Saginaw three speeds seem to be another case all together; I gave up on trying to understand GM’s coding for them, and what gear sets they came with; in part because I didn’t have a baseline to compare anything against…
When I get that far, I wonder if I could switch from current 3 speed to a 4 speed without affecting the originality and value of the car?
if done properly, I doubt it would affect the value.
From the few first hand accounts I received from people who ran the Muncie three speed, they all suggested that it seemed to be gear perfectly, so I hope you're not looking for a dramatic increase in performance. Everyone I have spoken to about this transmission cites it's bullet proof durability - and the only reason cited for swapping in a four speed, was for the "cool" factor. (The guy who I got my '70 Muncie three speed, was quite clear in his assessment of making his car slower - his was a 350-2bbl Lemans of some sort.) If you do go this route, you can swap over your chrome stick from the three speed shifter into an (OEM/correct) four speed shifter, and all you will be left to contend with is the reverse linkage. Also, if you do go this route, there may be some people on this board who would be interested in getting that three speed transmission.
Dennis |
Hope you have good luck on that.
Which plant was it built at ? If it was Atlanta , they usually had one taped on the inside of a door panel You might have a handful of minor options. Carpet Radio ? do you have an in-glass antenna in the windshield ? SoftRay windshield ? Recess wipers ? super lucky would be a saf-t-track rear axle These other guys will know for sure but seems like they all came with Rally2 wheels |
#38
Dennis |
#39
Yes I like them without the trim rings... The one I had years ago had them but now I prefer w/o.
