#81
Can you sell the quarters that are coming off the car?
" Long may we DRIVE !" |
#82
Beautiful car and compelling story.
I just bought a '74 T/A (white) from USA and I'm finally about to get it certified for the roads in Canada. Hopefully doesn't turn out as crazy as NZ - jinkies! She is totally worth it though...you must get some crazy looks driving down that road lol |
#83
The sail panel areas are going to be used on the new quarters, so they probably wont be much use to anyone.
Peter 1974 Trans Am, 400 4-speed, 3.42 rear.
#84
Been a while since I updated this thread.
Work is slowly progressing. Unfortunately the front spring pocket areas (below the rear passenger floors) along with the rear of the frame rails (where they meet the tailpanel) required a lot of work. ![]() The doors have had the new skins fitted, but the bottom of the door frames also had rust that had to be addressed. Outer wheelhouses, trunk extensions, quarters and tailpanel are in final mockup stage - should all be spotwelded on in the coming weeks;
| The Following User Says Thank You to pontiacstogo For This Useful Post: | ||
#85
Dang never ends hey...hang in there
| The Following User Says Thank You to kingbuzzo For This Useful Post: | ||
#86
Too bad you couldn't bribe the inspector , I don't think your car posed a hazard to anyone in any way. But you knew it was going to be tough, and you are working it out with an extremely great attitude. More power to you and best wishes ! Googled "what is good about NZ" Gisborne is the first place in the world to see the SUNRISE. It has the best air quality of any nation. There are no nuclear power stations in New Zealand. It is one of the last habitable countries in the world to become occupied by humans. There are No Snakes. (really ?) Only 5% of New Zealand’s population are human (the rest are animals). Home to more species of Penguin than anywhere else on the planet. New Zealand’s Prime Minister once appointed a national Wizard. You can pay with Hobbits. (Try that one at the body shop)
#87
Big shout out to Ames too - I hadn't counted on needing a tailpanel so I did not include one in my original parts order. I was worried it might delay the progress but the good folks there had everything boxed, shipped and landed in NZ in a very short period of time.
#88
Floors all blasted and sealed. Tank, rear end and exhaust going back in for the final time;
| The Following 2 Users Say Thank You to pontiacstogo For This Useful Post: | ||
#89
better than new...
#90
Quarters are finally welded on. Next up - stripping for prep. and paint.
#91
Peter, with respect, could I make a suggestion that you take this opportunity to remove the door lock mechanism from the left hand door (and possibly the right hand door), soak them in thinners and get all that overspray off. The attaching screws too.
I'm sure they were not originally painted at the factory. Apart from that, its looking amazing. Going to be a brilliant car when finished Ian ![]() ![]()
To laugh at men of sense is the privilege of fools. |
#92
They will be removed when the car is painted this time around as everything is being painted seperately.
#93
wow...still looks great with that primer-camo theme...lol
#94
Yep - it's not the prettiest at the moment. They are telling me that it will be painted and ready to go by the end of April. Seems a bit optimistic, but what do I know?
#95
Some photos of the quarter panels process.
This is utilizing the repro 75-81 full quarters combined with the sail panel section from the quarters that were on the car to make a 74 full quarter (which are not currently reproduced). Old quarter - showing original sail panel and 'half' lower patch panel; ![]() New 75-81 quarter with sail panel area removed; ![]() Section cut from old sail panel area; ![]() The two panels welded together; ![]() The '74' quarters blasted and finished inside;
#96
IMHO the quarters that were on the car ( GM?) look pretty solid, as does the whole car!
#97
The odd 74 strikes again...keep going!
#98
Not a lot of updates to report. One of the repair inspectors requirements was a 3D chassis measurement. That's taken a bit to organize but it is all done now and it's surprisingly good for a 50 year old car.
#99
Such an amazing journey
Thanks for sharing the story as it goes. |
#100
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
