Old 06-02-2023, 06:35 PM
gtorich gtorich is offline
Default KRE heads and spark plugs
I changed the plugs on my car today, had these heads since 2010, the plugs are auto lite 3924 with the crush washers,.
I always start them with a rubber hose over the plug to get them started, then i put my socket on them to turn till snug against the head.
This is where i seem to get confused, says hand tight till snug, then another 1/4 to 1/2 turn..................ok got that.
But as soon as i put the wrench on, and only using one hand to not overtighten the plug, they seem to spin quite a few more turns with really no effort, then they will get someone tight, then i go maybe a 1/8 to 1/4 turn..........im assuming the crush washer is crushed.
My question is when the plug is tight with the socket by hand, why does it seems to turn quite a bit more before becoming a little more than snug.......
I see no damage in any of the threads inside the motor...........the motor is on a stand now so easy to see .
Rich
Old 06-02-2023, 07:47 PM
Gach's Avatar
Gach Gach is offline
That’s perfectly normal. No worries.
Old 06-02-2023, 07:57 PM
Also according to Murphy’s law if you put a plug back in a aluminum head that is hot, then chances are that when the head cools the plug will be loose.
Old 06-02-2023, 09:48 PM
Hey, thanks guys................just wondering would it pay to run a spark plug chaser thru the heads.............never done that before.................Hey Gach, first the oil pump shaft issues, now spark plug issues.................im hoping to get this car running soon before i get a foot in the grave.........
Rich
Old 06-03-2023, 12:45 AM
Gach's Avatar
I wouldn’t Rich.
Old 06-03-2023, 05:55 AM
Wait a minute now!
Do the KRE heads use a 13/16” plug with a flat washer?
Are they machined for that type or only a 5/8” type with a taper seat?
Old 06-03-2023, 07:05 AM
chuckies76ta's Avatar
When installing these plugs into the heads I coat mine with a bit of cooper coat to prevent galling. Like mentioned the crush washer has to crush which will seat the plug. Tighten then up a bit. I use to run the Auto lite in my KRE heads, but I like the NGK plugs. R5671A-7
https://www.ngk.com/ngk-4091-r5671a-7-racing-plug
950 Quickfuel.
Old 06-03-2023, 07:51 AM
chrisp chrisp is offline
Wait a minute now!
Old 06-03-2023, 07:57 AM
Then how the heck are some folks trying to get washer / gasket type plug to work?
Old 06-03-2023, 08:01 AM
Gach.............i wasnt talking about a tap................i thought you could run a chaser/cleaner in the threads............thought they were supposed to just clean the threads, not damage them.................think i"ll just leave them alone.
Rich
Old 06-03-2023, 08:10 AM
It's my understanding that KRE recommends gasket /washer plugs.
950 Quickfuel.
Old 06-03-2023, 10:22 AM
77 TRASHCAN's Avatar
Autolite 3924 plugs are 5/8 with gasket.
Shut it off
Shut it off
Old 06-03-2023, 11:04 AM
Gach's Avatar
Rich
I gotcha
Old 06-03-2023, 01:07 PM
I just looked at my set of KRE heads and there is no taper on the spark plug holes.
950 Quickfuel.
