Old 06-20-2023, 05:58 PM
John Milner's Avatar
Default Crane HIT-290-2-NC Camshaft
Has anyone ever ran this particular Crane camshaft? It was in an extra 455 engine of mine and I am considering reusing it as it looks to be in excellent shape and appears to be from the 80's.
The numbers stamped on the back of the camshaft are:
Crane HIT-290-2-NC
I was just curious how this camshaft performs if you have ran it. I am also curious as to what the duration/lift specs are on it. Just a rough measurement with some dial calipers, it seems to be around .500 lift.
Old 06-20-2023, 06:10 PM
Steve C. Steve C. is offline
Cam card in post 11 here:
https://forums.maxperformanceinc.com...t=HIT-290-2-NC
https://www.summitracing.com/parts/crn-284281#overview
Old information here:
Old 06-20-2023, 06:15 PM
400 Lemans's Avatar
HIT 290-2-NC, .050 Duration is 234 int and 244 ex. Lift is 485 int and 505 ex. on a 112 LSA. Nice cam, one of the old Fireball grinds. Very rowdy in a 400 but perfect for a 455.
The Following User Says Thank You to 400 Lemans For This Useful Post:
Old 06-20-2023, 06:22 PM
Note the discussion here: https://forums.maxperformanceinc.com...t=HIT-290-2-NC
Old 06-20-2023, 10:13 PM
Dragncar Dragncar is offline
Run that all day long in a street 455.
Old 06-21-2023, 12:14 PM
NeighborsComplaint's Avatar
Here's a short, shaky vid of that cam in my 455. I made this quite a while back and don't recommend one-handing the car while recording like I did.
https://youtu.be/0UmApZeYKvM
Triple Black 1971 GTO
The Following 2 Users Say Thank You to NeighborsComplaint For This Useful Post:
Old 06-21-2023, 06:09 PM
Formulas's Avatar
Formulas Formulas is offline
I have a Crane HIT 290-2-NC new on the shelf
Old 06-21-2023, 07:08 PM
i82much's Avatar
i82much i82much is offline
Is this about what they used to call a "3/4" cam in the old days?
Old 06-21-2023, 07:13 PM
Thanks for the replies everyone. Your car sounds great NeighborsComplaint. I’m considering using this in a 455 short block with 197 heads. Hoping the lower compression doesn’t hurt it.
Old 06-21-2023, 07:26 PM
steve25 steve25 is online now
With the exh to intake ratio of those 197 heads in stock form, if your going to also run headers a would not run a cam like that with its full extra 10 degrees of exh duration .
I would go no more then 4 or 5 larger.
Old 06-21-2023, 08:40 PM
For its age, it holds up pretty well. Crane was pretty far ahead of the curve with asymmetric lobes and high intensity ramps on this 80's-90's grind. At that time, the choices were pretty limited considering cams like the straight pattern Comp Magnums and Lunati Bracket Masters were popular choices. Most guys I knew stuck with the 041 and this Crane was a step up from there. Mine certainly doesn't run like an antique. Watch my tach needle in the video.
Old 06-21-2023, 09:08 PM
Formulas's Avatar
Thats why I scooped mine up because its a big improvement over any stock offering but is prior to the ultra quick ramps associated with ruined cams during break in
Old 06-21-2023, 10:03 PM
The cam Whitmore spec-ed for my ported 197s was a .270-.275 @.050 cam.
Old 06-21-2023, 11:24 PM
RA4 231/240 = 9 deg
Crane HIT 284281 234/242 = 8 deg
Old 06-22-2023, 07:29 AM
AG's Avatar
AG AG is offline
If your 197 heads have a stock chamber size I think that cam has a little too much duration. I run a RAIV cam in a 8.9:1 static CR 455 with 7K3 heads and the combo runs well. I wouldn't want to lower the CR and increase the cam size in my motor. Probably something like 224/234 at 0.050" duration might work better.
Old 06-22-2023, 08:33 AM
Compare the seat to seat timing of the cam. NOT the .050" timing data.
( However note the cam card says something different than Summit. Is it 290/300 or 296/304. See post #4 in the link I posted above )
Old 06-22-2023, 09:17 AM
Dynamic Compression Ratio
Will my engine run on pump gas?
http://members.uia.net/pkelley2/DynamicCR.html
It's not a website based program, you download it and install it. See bottom of the page.
Old 06-22-2023, 01:32 PM
i82much's Avatar
yeah wasn't implying anything negative about the cam, just more curious about the terminology back in the day. i drove my GTO in the 90's as a teenager and had a crane fireball, ran great. but was never sure what the older guys meant by a "3/4" cam and yours sounds like a step up from what I ran (216 @ .050).
Old 06-22-2023, 01:43 PM
Stan Weiss's Avatar
Steve,
It is possible that those numbers are from the very same cam. It could just be a matter of where they are looking at seat duration. As you know some use 0.004", 0.045", 0.005", or 0.006" lifter raise.
Stan
Pontiac Pump Gas List
Old 06-22-2023, 01:53 PM
Yeah, that was early to late 60's terminology. Rather than confuse everyone with advertised duration vs duration at .050" lift, many cam makers ranked their "sticks" as Stock, Street, 3/4 Race (enough overlap for a rough idle) and Full Race.
