Old 07-23-2023, 11:58 PM
Vid's Avatar
Vid Vid is offline
Default Mystery wire and white smoke
Finally got ready to turn the key on the new motor. Bumped the starter and spotted white smoke from the voltage regulator/distributor area and shut it down immediately. Smoke was coming from the harness that connects to the voltage regulator. There is a wire (circled in yellow) that I could have sworn was grounded to one of the VR mounting bolts. I disconnected it from the ground bolt and no more white smoke. Is this a hot wire used for electric chokes? Tomorrow I’m going to take off the wire covering and investigate closer.
Old 07-24-2023, 03:28 AM
Scott Thelander's Avatar
That sure looks like a coil power wire clip
The Following 3 Users Say Thank You to Scott Thelander For This Useful Post:
Old 07-24-2023, 10:13 AM
Vid's Avatar
Vid Vid is offline
Ah! Leftover from the HEI conversion probably?
Old 07-24-2023, 11:47 AM
The Following User Says Thank You to Scott Thelander For This Useful Post:
Old 07-24-2023, 12:32 PM
Vid's Avatar
Vid Vid is offline
10-4
Could I hijack that wire for my electric choke?
Old 07-24-2023, 01:24 PM
tekheavy's Avatar
tekheavy tekheavy is offline
Not if it's a resistor wire. Take a volt meter and make sure you are getting a full 12 volts.
The Following User Says Thank You to tekheavy For This Useful Post:
Old 07-24-2023, 01:27 PM
Vid's Avatar
Vid Vid is offline
Roger that.
Old 07-24-2023, 01:52 PM
Shiny Shiny is offline
Good thought on the voltage drop but only if the wire is connected to the coil.
If the wire is powered but hanging open with no load (as shown in the photo), it will read 12V to ground, whether it's a resistor wire or not.
Current needs to flow in the wire to measure its voltage drop.
Either find the other end of the wire and measure resistance directly or hook it to the coil if you want to use a voltage reading.
How much resistance would it have if it was a resistance wire? What is the load resistance of an ignition coil? The ratio of the load resistance and wire resistance will determine the voltage drop within the wire.
For example, if a coil is a 10 ohm resistive load, and the wire is a 10-ohm resistor, then the voltage with the coil pulling current will be 6V. If the wire is straight copper, then the voltage will be near 12V because all the voltage loss will be in the coil.
Old 07-24-2023, 02:17 PM
Vid's Avatar
Vid Vid is offline
I’ll break out my multimeter and see what I get. The HEI of course has two terminals, which are battery and tach. Should I make the measurement between the open wire and the battery terminal? I just don’t want to fry anything more than I may have already. Sometimes I feel like my electrical ignorance knows no bounds, lol
Old 07-24-2023, 04:01 PM
You're not ignorant. You are smart and cautious, both good things!
If it were me, I'd:
1. First verify the wire is "hot"
Set your meter to measure volts, turn on the ignition and measure the voltage between the open wire terminal and ground.
Don't measure between the HEI battery terminal and the wire.
Measuring 12V between the open wire and a chassis ground will tell you if the wire is "hot" or not but won't tell you if it is intended to be a resistance wire for the original ignition.
Measuring with the ignition switch on and off will tell you if the wire is indeed a source of power for the ignition system, which I think is your goal.
2. Then determine if the wire has high or low resistance
Assuming you confirmed the wire is indeed "hot", I'm not sure the best way for you to tell if it is a resistance wire or not.
It would be easiest for you to tie this to the battery terminal of the HEI and measure voltage with the ignition switch on. I don't see that you could hurt the HEI but I don't know if it will draw enough current without the engine running to determine if the wire has resistance.
Others with direct experience can tell you this and I'm sorry I cannot.
I personally would get a resistor, like maybe 10 or 20 ohms and connect it between the wire terminal and ground, then measure voltage. But I have this stuff laying around.
If you aren't comfortable with any of this, don't be afraid to ask for more help. There are many on here with more experience that can probably give you better advice.
Mike
Old 07-24-2023, 04:09 PM
If I recall correctly, I think the ignition resistor wire only drops about 3 volts. It would probably be ok for your choke. At the very least it wouldn't hurt your choke and you could also read the voltage there which would answer the question about how many volts are being dropped.
Old 07-24-2023, 04:17 PM
Vid's Avatar
Vid Vid is offline
Thanks Mike, Greg and everyone for your assistance. I’ll keep you posted on my progress.
Old 07-24-2023, 04:56 PM
Good idea and agree it will be safe to hook it up.
I'd still confirm it is "hot" and understand "when" it is hot before looking at the voltage drop.
Mike
Old 07-24-2023, 05:19 PM
Mike
Absolutely. First things first.
Old 07-28-2023, 07:39 PM
Vid's Avatar
Vid Vid is offline
So to follow up, the resistor wire was 3 volts and works ideally for the electric choke. Got my wiring woes handled. Thanks again, what would I do without you guys
The Following User Says Thank You to Vid For This Useful Post:
