Old 07-23-2023, 09:18 PM
67'7F6'Bird's Avatar
Thank you Everyone who came by to visit us in the Pits.
Name:	Thank You Raven.jpg
  #2022
Old 07-23-2023, 09:28 PM
mgarblik mgarblik is offline
I understand why the Frantic 4 was cut down from 1/4 mile to 1/8th mile. Over the last several years, the field has been small and the breakage high at the event. I also understand that the 4 qualifiers need to be able to make their rounds and give the fans side by side racing during eliminations. I can say from experience it is Much, Much, easier on the hardware to run 1/8 mile than 1/4 mile. On the funny car, probably 75%+ of the breakage came after the 1/8th mile. So I get it.
Maybe it's my age, but 1/8 mile drag racing is cute. It's not real drag racing though to me. If our Pontiac engines can't run a 1/4 mile , we need to work harder, not make the race easier.
So I want to congratulate Ed and his crew, his engine builders and associates for "going for it" in 1/4 mile drag races. Keep up the effort and we will be watching.!
The Following 2 Users Say Thank You to mgarblik For This Useful Post:
  #2023
Old 07-25-2023, 11:27 AM
Thanks for the extra info on the Frantic 4 racing. (1/8th mile)
I was told that the track restricted the 1/4th mile to 1/8th mile for those cars.
Good Job Ed and team on your new personal best 1/4th mile track pass.
The Following 2 Users Say Thank You to Tom Vaught For This Useful Post:
  #2024
Old 07-26-2023, 09:22 AM
Here is the 194 mph Run.
https://www.youtube.com/watch?v=Lfqm6JC98ew
  #2025
Old 07-27-2023, 12:27 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
How many runs did the Raven make?
  #2026
Old 07-27-2023, 08:16 AM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Hi Jack,
We made 6 passes, pushed of the track Sunday on the 7th due to sensor malfunctions "safety kill" that shut the engine off. Seems we has a sensor ground fault that caused fuel pressure to drop and a few other temp sensors to read hot.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
The Following User Says Thank You to RAIV-Z For This Useful Post:
  #2027
Old 07-28-2023, 12:14 AM
Congratulations on the 194 mph!
Any Epping plans for this year?
  #2028
Old 07-28-2023, 06:22 AM
RAIV-Z's Avatar
Hi Jack,
Thanks!
Yes, well be heading to New England Dragway for a few events and some track rentals.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #2029
Old 07-31-2023, 04:22 PM
blueghoast's Avatar
Hi Jack,
Thanks!
Car is so bad ass, Keep up the great work.
GT
  #2030
Old 08-01-2023, 06:58 PM
RAIV-Z's Avatar
GT
Thank you!
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #2031
Old 08-01-2023, 07:14 PM
RAIV-Z's Avatar
The better time slips from Norwalk.
Name:	Norwalk 2023 Time Slips.jpg
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #2032
Old 08-02-2023, 09:04 AM
I saw on one run you had a 1.21 60 ft. against a 1.08 from your competitor. But by 330 ft. you were well ahead of him. If you can work on that launch, you would greatly improve your ET, obviously. Plenty of power. Does the car spin or is it just leaving soft? I know turbo cars are very difficult, to get just right at the starting line.
  #2033
Old 08-04-2023, 02:40 PM
RAIV-Z's Avatar
Hi Mike,
Leaving soft, ~8.8-9lb of boost. We'll work on building boost on the t-brake without cooking the transmission. Our target is ~18lb on the launch. The current tune is taking ~5 seconds to hit ~8lb.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
The Following 2 Users Say Thank You to RAIV-Z For This Useful Post:
  #2034
Old 08-04-2023, 02:54 PM
You will get there with more runs. Not going to the starting line on Kill is probably what has you still in the game. Measured approach. Be safe and fast!
The Following 3 Users Say Thank You to mgarblik For This Useful Post:
  #2035
Old 08-04-2023, 04:06 PM
RAIV-Z's Avatar
Finally got around to uploading a video https://www.youtube.com/watch?v=tvr5DqayKqM
ID:	617418   Click image for larger version
ID:	617419   Click image for larger version
Name:	GH012967 burnout ok great pass 194mph_ 1 (00.01.03.083).jpg
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #2036
Old 08-04-2023, 04:19 PM
BILL BOWMAN1's Avatar
Definitely a 6 second time slip in your future!
The Following 2 Users Say Thank You to BILL BOWMAN1 For This Useful Post:
  #2037
Old 08-29-2023, 03:56 PM
RAIV-Z's Avatar
After Norwalk, we took the top end off after seeing AFR lean on the passenger side. Checked the usual stuff, O2 sensor, lash, coils, plugs wires, injectors and then a compression test. Multiple cylinders were low, the worst #4 and #6 were at ~30psi, all others were also lower than expected. Both head gaskets looked great. The intake and exhaust valve seats were sinking, more so on the side where the in/ex valves share the port wall.
The data logs look good.
The general consensus is the chambers are too hot. Where we are running C16, we're trying to understand all possible causes before determining next steps.
Thoughts?
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #2038
Old 08-29-2023, 04:19 PM
charlie66's Avatar
Sounds like the lean condition might be the culprit. Is the fuel system up to par ? Being its already apart id double check the cam positioning ... Might be a good idea to call your cam guy and talk to him about whats going on ... Just a couple of thoughts.
Im sure you will figure it out.
Good luck
My Half AN Injun.....
  #2039
Old 08-29-2023, 04:33 PM
RAIV-Z's Avatar
Good luck
Fuel system is 7.8GPM and plenty volume there. Datalog AFRs look really conservative and plenty of fuel pressure.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #2040
Old 08-29-2023, 05:20 PM
charlie66's Avatar
When you say AFR was lean , what was it? Whats your timing at 30 psi?
