![]() Stan
Love the humor, and for sure I deserve some pokes in the backside on occasion when it comes to cam stuff.....good thing I have my big-boy britches on today so it bothers me not in the least.....
Anyhow, the conventional wisdom with all engine builds are to choose the the cam for the CID, head flow, compression ratio and USE OF THE VEHICLE. Can't argue the results here considering how simple the combo is and not using a lot of exotic parts to get er done...... Anyhow, OUT of here for a long weekend and to be there for my grand sons birth in a few days.....have fun gentlemen, even if it's at my expense!.......
| The Following User Says Thank You to Cliff R For This Useful Post: | ||
Stan
I agree. Stan
Glad we agree on something.
I think that's a first. That calls for a celebration (I'm always looking for a reason). Gonna whip up an Old Fashioned made with Bulleit Barrel Strength and smoked with cherry wood. I may have to have more than one they are so good!......
| The Following 2 Users Say Thank You to Cliff R For This Useful Post: | ||
My copy of John Schloe's 69 RAIV 400 stocker cam is 274/274@ 0.050! Probably not a good idle or work power brakes
But got the car in the 10s way back when.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
| The Following User Says Thank You to Skip Fix For This Useful Post: | ||
That sounds like a damned fine cocktail! See you on the bourbon trail! Sent from my iPhone using Tapatalk |
