Old 07-27-2023, 04:04 PM
Shiny Shiny is online now
Default Battery Cable Routing? 70 LeMans
How is the positive battery cable routed from the tube on engine to the battery?
Pictures?
How is it kept away from steering shaft and brake lines?
I think it snakes along the top of the inner fender along with the front harness but what happens in between engine and the fender?
Mike
Old 07-27-2023, 09:35 PM
If you have standard exhaust manifolds, use the top route in pic.
Old 07-28-2023, 11:45 PM
Thank you John
It seems the cable loops through only one of the clips/ties and just drapes above the steering shaft.
So the right cable length is the key to keeping it suspended high enough to clear everything.
I'm close to installing the battery so will soon know how it plays out.
Mike
Old 07-29-2023, 11:33 PM
What am I missing?
I installed the cable and don't like the way it drapes from engine to inner fender.
Do I have the wrong "tube" on the engine?
Is there another clip on the engine to raise the cable higher?
As it sits, I am concerned the cable could contact the shaft which is clearly a bad idea....and it's not smart.... and it is dangerous.
Mike
ID:	616971   Click image for larger version
ID:	616972   Click image for larger version
Old 07-30-2023, 09:45 AM
Looks like the factory diagram, maybe the angle of the tube is too angled toward fender?
says 30º on diagram
Old 07-30-2023, 01:16 PM
OK, thanks again John
I'll take a look and maybe try to bend the tube
I'm curious to see others' cable routing. Anyone have photos they can share to show the clearance between + cable and steering shaft?
Old 07-30-2023, 01:23 PM
SD455DJ SD455DJ is offline
Mike, Here is the routing on '69 350 HO, but it should be the same as any V8 A-body w/o RA manifolds. The original cable sheathing is pretty long and extends through the tube down to the solenoid and could provide protections from the steering shaft. The original plastic retainer strap can be seen in the first photo with the dual quad set-up.
Dennis
Name:	69-70 Positive Cable Routing.jpg
ID:	617031   Click image for larger version
Old 07-30-2023, 05:52 PM
Thank you Dennis!
Looks like the engineers used a sheath to reduce risk. I'll try and find something similar.
Appears your clearance is about the same as mine so it's just the way it is.
It's not a great design but must have been good enough!
Mike
Old 07-30-2023, 06:15 PM
Apparently not easy to find something durable.
Anyone know a source for Kevlar/aramid braided sheathing by the foot? Most of it appears to be PET or polypropylene which won't hold up as well.
Mike
Old 07-30-2023, 08:43 PM
tigertone tigertone is offline
Default Cable protection
Try a search for asphalt wire sheathing or loom. This is the braided cloth tar impregnated covering that was used on cables for heat and rash protection on the lower section of cable to the starter. It is sold in different diameters by the foot. It's not kevlar but always held up.
Old 07-30-2023, 09:13 PM
Dadspackard's Avatar
Dadspackard Dadspackard is offline
I have used this
https://www.npdlink.com/search/produ...parent=0&year=
Tom
Old 07-30-2023, 11:39 PM
Thank you both. I may have some of that tar-coated stuff. I'm surprised that was the original but sounds like another "good enough"!
Old 08-02-2023, 08:33 PM
Held for Ransom's Avatar
Just to agree with Dennis. My '70 had the same setup. Didn't have any pictures with the fenders still attached.
So long, farewell.
The Following 2 Users Say Thank You to Held for Ransom For This Useful Post:
Old 08-02-2023, 08:56 PM
Thanks!
I still need to find some sheathing, but for now, mine isn't touching anything.
I remain surprised by the design.
Looks like yours may actually touch the steering shaft!
Old 08-03-2023, 08:03 PM
I'm surprised it's not touching more. Front end was removed at that point and battery end should have been hanging to the floor. Tube was also disconnected from engine stud.
So long, farewell.
Old 08-03-2023, 10:03 PM
Aha!
Now it makes more sense..
