Old 02-16-2024, 01:53 PM
nas t eh nas t eh is offline
Got the tach working. I have a pertronix 3 and was worried about connecting the tach lead to the neg on the coil. I had incorrect info that the tach could be damaged by the multi spark feature.
But that is not true and in my cars case I didn’t need to add a resistor that is sometimes required for correct function of the tach.
Now I get too see how long the Pertronix functions before I get stranded like so many other have.
73 T/A 455, 4speed
Old 02-16-2024, 06:54 PM
OG68 OG68 is offline
I installed a Pertronix 3 on my 70 El Camino. No problems for the three years before I sold the car. I had an old SW tach (1965) with sending unit that worked just fine with the P3. (Tach is going back into my 68)
Old 02-24-2024, 06:29 PM
BILL BOWMAN1's Avatar
Progress, hope to start assembly Monday.
Then turn car around and start on driver side.
This tread has at least gotten me off my butt.
The Following 3 Users Say Thank You to BILL BOWMAN1 For This Useful Post:
Old 02-26-2024, 05:24 PM
Test fit lower control arm, took a little massaging to get back in with new bushings as expected. Had to spend the majority of the day in the yard spring cleaning, mainly those 80 trillion Sweet Gum monkey ball thingies- nastiest trees on the planet!
Old 03-06-2024, 08:04 PM
gtospieg gtospieg is offline
You'll have the satisfaction of having done it yourself...and saved a ton of money.
The Following User Says Thank You to gtospieg For This Useful Post:
Old 02-23-2024, 01:51 AM
Verdoro 68's Avatar
I took advantage of the dry weather and ran some errands in the T/A, then took the '68 down to open shop night at my son's school. I was hoping to do some more tinkering on the brakes but all the bays were full. It was fun seeing the shop kids drool over it and shout "noooo waaaay!" when my son got in to drive it home. He definitely got some cool points.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 02-23-2024, 03:42 AM
Verdoro 68's Avatar
Forgot the pic...rolled over 19,000 miles in the Comp T/A while I was out today. It came to me with 16,700 in 2022 so I'm not exactly racking up the miles, but it's getting driven regularly. It apparently had a mere 500 miles put on in it in the 10 years prior to my ownership.
Since the tape player is fixed I rocked a little STP Purple while motoring around.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 02-23-2024, 01:02 PM
full tank of gas what is stopping you...lol
[/QUOTE]
Old 02-23-2024, 03:26 PM
jhein's Avatar
jhein jhein is offline
I could swap a HEI module faster than points on the side of the road. But, that's me. Maybe if your a points master it's the opposite.
Also, whenever anyone complains about HEI it usually seems to be Pertronix. I have a DUI and i've searched around and haven't really found many, if any, problems.
Old 02-23-2024, 03:49 PM
KS circutguy's Avatar
In my old speed shop install - sales days almost every pertronix failed early on.
We were the east coast jobber for speed equipment including circle track stuff.
Auto Finishers Speed and Custom.
We stopped selling them and always sold MSD, magnetic trigger.
DUI are solid as well magnetic triggers,Pertronix are hall effect.
But cross country you still can't beat points and a carb.
Old 02-23-2024, 04:29 PM
jhein's Avatar
Just did a quick look and it seems like Pertronix sells both big and small cap distributors that can be either Hall or magnetic. Not sure why they have both. I haven't found anything on the Pertronix website yet that talks about it. On the Summit site they tell you if it's Hall vs magnetic, Pertronix doesn't even mention it is the specs on their site at all. The DUIs all seem to be magnetic. Original GM HEI were also magnetic, correct?
Old 02-23-2024, 04:58 PM
yep
Also the Mallory units were always failing,
they were Hall Effect as well.
Old 02-24-2024, 01:00 AM
VCho455's Avatar
VCho455 VCho455 is offline
Picked up the motor for my Firebird from the machine shop. Pretty stoked about it. Lots of pieces of the puzzle are coming together on the bird.
ID:	629257   Click image for larger version
ID:	629258   Click image for larger version
ID:	629259   Click image for larger version
The Following 5 Users Say Thank You to VCho455 For This Useful Post:
Old 02-24-2024, 09:50 AM
4dblnkldude's Avatar
I am going to put an exhaust system on my 81 TA today. The car is almost ready for a test cruise!
The Following User Says Thank You to 4dblnkldude For This Useful Post:
Old 02-24-2024, 01:39 PM
Thumbs up
Who did you have do the machine work?
Old 02-24-2024, 02:20 PM
VCho455's Avatar
Somers Automotive Machine. We've used Archie almost exclusively for over 20 years for machine work. (Did my OHC 6) We have him do the machine work and we assemble them ourselves. Once he's done with the heads we'll have the short block ready and then we'll have it dynoed at his shop.
He's a bit grumpy but the work is always on time and done right. He has a lot of regular customers who race for points so sometimes it may take a bit longer but he lets you know up front how long to expect.
The Following 2 Users Say Thank You to VCho455 For This Useful Post:
Old 02-26-2024, 12:29 PM
Thumbs up
Yep,I've used Archie for 30 years and turned many on to him for machine work.
Old 02-24-2024, 01:17 PM
gtokid1968's Avatar
gtokid1968 gtokid1968 is offline
Today Nothing!
I did put the battery tender on in two weeks ago!
I bought 10 wix oil filters from rock auto.
The wifes kitcen up grade has taken what frre time I have this witer!
The Following User Says Thank You to gtokid1968 For This Useful Post:
Old 02-24-2024, 01:28 PM
68 Firebird's Avatar
68 Firebird 68 Firebird is offline
Default Unboxed next project
Well next project has arrived.
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, GM HEI and Ram Air pans and RARE Long Branch Manifolds
The Following 3 Users Say Thank You to 68 Firebird For This Useful Post:
Old 02-24-2024, 07:32 PM
tom s tom s is offline
Went to a car show early AM,came home and did more work on my engine on the run stand.Getting closer to doing breakin.Tom
The Following 4 Users Say Thank You to tom s For This Useful Post:
