Old 09-17-2023, 10:11 AM
johnta1 johnta1 is online now
It's like a 10-60 lubricant.
  #142
Old 09-17-2023, 05:19 PM
79 Phoenix's Avatar
79 Phoenix 79 Phoenix is online now
Okay-- I had seen that in my service manual but what is "water resistant FP grease"? Is it chassis lube?
  #143
Old 09-17-2023, 06:53 PM
No, it's more like rear-end grease, just not as thick.
  #144
Old 09-17-2023, 07:41 PM
EP is Extreme Pressure rating.
Probably whatever you use in your manual trans will work fine.
Maybe inquire to a place that rebuilds manual steering boxes about their recommendation.
  #145
Old 09-17-2023, 11:35 PM
79 Phoenix's Avatar
Okay guys...Thanks so much. I appreciate your input!
  #146
Old 09-23-2023, 05:04 PM
79 Phoenix's Avatar
Default PICTURES OF LAUERNTIAN GREEN 70-72
I am considering painting my car Laurentian Green instead of the original Starlight Black. Any one have pictures of a Lemans or GTO in Lauerntian Green?
  #147
Old 09-24-2023, 07:57 PM
You can go to www.ultimategto.com and use a dream car option that will show you all the 71's on their site that are Lauren Green.
About 16 or 17 across all nameplates and body styles that color.
You have one of the top color combos for a 71 GT-37
But its your choice
  #148
Old 09-24-2023, 11:11 PM
79 Phoenix's Avatar
But its your choice
Thanks so much! VERY helpful site! You mean Black w/ Gold stripe is one of the top combos?
  #149
Old 09-25-2023, 08:41 AM
Yes
Black & Gold would probably be in everyone's top 3
The Following 2 Users Say Thank You to Baron Von Zeppelin For This Useful Post:
  #150
Old 09-25-2023, 10:36 AM
Cammer-6 Cammer-6 is offline
anyone that wants to reject a factory black one,I ll take it.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
  #151
Old 09-25-2023, 07:33 PM
79 Phoenix's Avatar
Yes
Okay, good to know... Looks like I should stick with black! Thanks
  #152
Old 09-25-2023, 07:34 PM
79 Phoenix's Avatar
Okay, point made! Thanks for your helpful input!
  #153
Old 10-01-2023, 06:31 PM
79 Phoenix's Avatar
Default wheels and front suspension
Got the A-Arm bushings put in along with lower ball joints and re-assembled the front suspension with new springs...Glad that's done! Need to repair the radiator support but that should not be too big a deal for a welder. Also got my wheels painted and clear coated...
Next to drain the oil out of the new engine. It seems to be pretty healthy according to video I saw and the previous owner, but I am going to pull the pan and replace main and rod bearings while they are accessible...That way I'll know what I've got. *
Name:	Springs - Copy.jpg
ID:	620836   Click image for larger version
Name:	WHEELS - Copy.jpg
ID:	620837   Click image for larger version
  #154
Old 10-01-2023, 06:33 PM
79 Phoenix's Avatar
Default What is this???
Does anyone know what this is?
  #155
Old 10-02-2023, 08:12 AM
tstroud tstroud is offline
I believe that is the horn relay.
  #156
Old 10-02-2023, 08:18 AM
79 Phoenix's Avatar
Oooh...That must be a plastic cover around it. I've never seen one with a cover but looking on ebay I see they sell them with covers. THANKS!
  #157
Old 10-02-2023, 11:56 AM
how is the rear main seal
Old 10-02-2023, 01:58 PM
79 Phoenix's Avatar
Good question: I don't see evidence on the engine and I think the guy I bought it from told me no oil leaks... On a Pontiac motor can you replace the rear seal without removing the crank?
  #159
Old 10-02-2023, 07:29 PM
79 Phoenix's Avatar
Thanks again for asking this question. I hadn't thought about replacing the rear seal.
As far as I can tell there are 3 types of rear seals...a 1 piece, 2 piece vitron and 2 piece rope type... I don't like the rope type and would need to remove the crank to use the one piece... I might as well change the seal while I have it apart but would like to use the 2 piece vitron seal. I would need to lift crank slightly to put this in but not remove it all together.
Anyone know of a good source for the 2 piece vitron seal?
  #160
Old 10-02-2023, 10:44 PM
If you use either the one piece or two piece seals you will need to remove the serrations on the crankshaft in the seal area or it will eventually leak. Ask me how I know.
