LOL - our pup just turned one. I know what you’re talking about! The garage is my way of hiding from her.
Ken '68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around) '95 Comp T/A #6 M6 - bone stock (pics) |
Best thing you can do is spend a half hour everyday doing sit, stay, come routine. Give them a reward when they do good. My hybrid used to love fetching a basketball half full of air so he could grab it. I would kick the ball while he was in the "stay" command. Tell him to go get it and have him "stop" then "sit" then come to me and drop it. Make a game out of it, dogs love it. Its very important with a large, powerful dog for them to instantly "drop" anything in their mouth when commanded. My dogs could let a 2 year old feed them a hot dog, very gentle. I told him to drop a raccoon once and the sucker jumped back up and bit him. Should have let him take care of the racoon his way. But he dropped it when told. Good dog. |
The Following 2 Users Say Thank You to Dragncar For This Useful Post: | ||
Tim Corcoran |
The Following User Says Thank You to Tim Corcoran For This Useful Post: | ||
Call me crazy but I tightened up the two rearmost oil pan bolts and I could swear it stopped the leak. This is with the car sitting for 5 days, leaking, then tighten the bolts and, without starting car, leak seems to stop after tightening bolts.
Just so I fully understand - the oil level in the pan should be below the oil pan gasket surface right above the circled tit on the BOP gasket? Right at the bottommost portion of the curve, the oil level should be below that? |
Yes, but up in the lifter valley there’s a rear drain back hole that then sends that oil on to the spinning rear crank counter weight, and then all over if you do not have a crank scraper.
i have a really hard time reading the oil level too. it seems like if i go for a ride and check the oil the next morning, it will read low. but then if i don't touch the car for a week, i go back and the dipstick reads full.
I have the same milodon 7 qt pan & fought with what I thought was a rear main leak using a 2 piece BOP seal.... turns out after pulling the motor 2 times that it wasnt the rear main it was the U seal at the back of the pan.
The milodon pan uses the rubber U seal with 3 slots that are terrible at making a good seal, I ended up using the thick cork gasket & ultra black sealant there as described mr P body in the link below and it fixed the leak, been 8+ years since with lots of street miles & drag runs, no leaks but will "seep" a bit using synthetic oils, i just wipe it dry every season, no drips on the ground though, for a pontiac I consider that pretty much leak free. https://www.pontiacstreetperformance...sp/Sealit.html Other members here have mentioned using the thick cork gasket and it seems to be the best option, I used the standard felpro pan gasket too, not the 1 piece type. If tightening the bolts helped the leak keep your fingers crossed, if it still leaks consider using the thick cork U gasket. |
The Following User Says Thank You to 78w72 For This Useful Post: | ||
The Following User Says Thank You to i82much For This Useful Post: | ||
