When we dyno engines built for the pure stock drags, we make pulls with and without a base cut from a factory dual snorkel air cleaner that had damaged snorkels. Most engines respond positively with a several hp through the rpm range with the base. Its design smooths the air flow into the air horn of the carb.
I really like the '73-'76 4-bbl air cleaner design for the A&B bodies that has the single large snorkel that can be ducted to the radiator support for cold air intake. The F-bodies use the same design except has a drop base for the lower hood clearance and doesn't flow as well as the A&B base. Dennis |
| The Following 2 Users Say Thank You to SD455DJ For This Useful Post: | ||
As long as you don't really care, you can use a '68-72 single snorkel. In '70, the California vehicles used a '71-up style air cleaner. That underside has a hole in the bottom that will need to be plugged (from the outside, so that doesn't get sucked into the carb.).
Here is a relatively inexpensive single on eBay, just needs hole plugged. https://www.ebay.com/itm/335029417532
So long, farewell. |
| The Following User Says Thank You to Held for Ransom For This Useful Post: | ||
How does the breather connect to a 67 GTO air cleaner? I found this example of what I think is a Chevy base that has a nice solution for the breather on an open element air cleaner: Mike |
That's what the underside of my Z28 air cleaner looks like. If you have the center breather hole style valve covers like OEM, the tube points right at the filler hole. I bought a repro steel elbow and the short rubber connecting hose (also Chevy) and installed via a standard breather grommet in the valve cover. Looks like OEM and no interferences.
![]() I don't see why you're having a problem. Just install the breather tube elbow at the 10:00 position on your aftermarket air cleaner and run a heater hose to the breather. It shouldn't interfere with anything. On the factory air cleaner housing, install the tube at 12:00 (into the sidewall not underneath) pointing towards the breather and connect with heater hose. Just cap the factory tube off or cut it off and plug from below.
Triple Black 1971 GTO Last edited by NeighborsComplaint; 10-31-2023 at 01:14 PM. |
Also what vender did you use the acquire these items? Appreciate it!
Oh yeah, exactly what people were doing with the lids back in the day, heck I even saw a 74 455 Olds 88 police cruiser in the local Olds dealer's garage with the lid flipped, apparently by the dealer's mechanic.
65 Tempest, 400, TH400 86 Fiero SE 2.8 |
i just seen a post from a member the other day selling a 4bbl single snorkel for 60+ shipping he had quite a few others for sale as well
72 Luxury Lemans nicely optioned ![]() Best so far 12.40 Milan Dragway 2025 I am the Thread Killer! |
| The Following User Says Thank You to indymanjoe For This Useful Post: | ||
The interference was between the throttle linkage and/or the accelerator pump arm and the Moroso base. Hopefully I can fix this by rotating the base and there's a way to make it clear everything. The breather comes into play because the location of the breather opening in the Moroso base did not lend itself to an easy connection...it comes off at an awkward angle. I think I tried about 3 different fittings before finding something that allowed me to connect to the valve cover with a hose. The 5/8"? hose is stiff so didn't cooperate much. I suspect I ended up letting the breather hose dictate the orientation of the base. This probably explains the interference. I like the elbow you posted and will get off my butt and go check it all out when it warms up a little. Perhaps your elbow will make it all easy. The other input from this thread is the airflow is less than great with this Moroso base plate. The originals and some of the aftermarket base plates have a large radius as mentioned. So I may just toss the Moroso and start over with something easier to line up... but I'm still trying not to spend $300 on a dual snorkel and like the open element options. Mike |
Could be, I think I've seen something from GM- but it wasn't exactly that but similar.
I scanned/speed read this discussion;
Honestly, the grossly overlooked 68-72 single snorkel air cleaner is probably the way to go. There are a myriad of single snorkel air cleaners if you decide to look beyond the 68-72 style - they typically have a longer, and smaller end/inlet on the snorkel...
| The Following User Says Thank You to unruhjonny For This Useful Post: | ||
This is the one I have it’s pretty nice. https://forums.maxperformanceinc.com...ht=Air+cleaner
| The Following User Says Thank You to grandam1979 For This Useful Post: | ||
they make that L-88 base without the tube also. I run one ion my IA/Camaro as I can run a 4' filter on it . Pontiac motor and a Victor sit high even with a cowl hood. I can tell you on my motor i picked up a bunch with no aircleaner or base. I am sure a base will help so figuring out a setuo to keep one in place. i have seen the SS and Stockers use some springs.
I can also tell you pulling a filter out of my Shaker base with open scoop picked it up and changed the mixture so much it lean popped out the scoop at me!
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
| The Following User Says Thank You to Skip Fix For This Useful Post: | ||
i run an open element on a 72 chevy 4x4 i use to plow snow. i have a functional exhaust heat riser valve and exhaust crossover, works great. but that is a 4150 carb and maybe the bigger primaries are less susceptible to icing vs a quadrajet.
| The Following User Says Thank You to i82much For This Useful Post: | ||
70-72 Camaro unit on my Catalina. I love it.
LIFT HEAVY, LIFE IS TOO SHORT TO BE SMALL! |
| The Following User Says Thank You to BILL BOWMAN1 For This Useful Post: | ||
Small Block Chevy Valve Cover Elbow For 1969-1972 Camaro, Nova, Chevelle https://www.ebay.com/itm/12567313671...Cclp%3A4429486 1968-72 Camaro Z28; Air Cleaner Breather Hose; with Open Element Air Cleaner https://www.ebay.com/itm/37501351138...86.c101224.m-1 Valve Cover Elbow + Hose Camaro Chevelle Nova Impala 68 69 70 71 72 Small Block https://www.ebay.com/itm/15382425664...Bk9SR5zns7LyYg I lightened up the pic so you can see both elbows:
Triple Black 1971 GTO Last edited by NeighborsComplaint; 11-02-2023 at 11:25 PM. |
| The Following User Says Thank You to NeighborsComplaint For This Useful Post: | ||
#38
I found the flat base is getting whacked by the accelerator pump rod and there is no way to keep it from happening by rotating my air cleaner base.
A thick gasket might provide enough clearance but sounds like a band-aid for a basically poor design. I am leaning toward replacing this base with one of the "open" style Chevy air cleaner bases that I posted earlier in the thread. |
#39
Shiny, Here are a couple of original '67 GTO 400 H.O. air cleaners that are very similar to the Chevy's open element unit. I always loved the look of them on any engine. It's a good choice for your engine and more cost effective too.
You can see that there is a rubber plug in the pass valve cover opening and a breather cap on the driver's side. H.O.'s used the regular PCV set-up (valley cover to intake nipple) as your '70 350. Dennis |
| The Following User Says Thank You to SD455DJ For This Useful Post: | ||
#40
Dennis,
Thank you for taking the time to share this. Perfect for me and Mikey likes it. I'll work to make this happen. Mike |
