Old 11-14-2023, 11:55 AM
Originally Posted by 1_Wild_Cat View Post
Hi Greg -- I think the doubled Clecos just allow for securely clamping the panel where is needs to be. You can see that there is a little clip between the two Clecos (Cleci?).
I can certain ask Cam if you have questions...Like why that method instead of another?
No need, makes sense to me that it's probably for a more secure, warp free joint before welding.
I would like to know what he's using to make his cuts? The cut gap between the patches and quarters are so neat and perfectly uniform.
Old 11-14-2023, 06:45 PM
gtospieg gtospieg is offline
That looks like outstanding work there...
  #223
Old 11-14-2023, 08:08 PM
1_Wild_Cat's Avatar
Wow, that turned out great!
Thanks guys. Hard to believe there a still people in the world that can start with a flat piece of steel and end up there. I'm glad I got sent to see Cam...
He makes the initial cut with a .040" cut off wheel about 1/32" above the scribe line. Then sands to the line with a 36 grit sander and hand files as needed.
His tools for this:
This is all the tools used for the finishing and correction...
Thank you everyone for your kind word and for following along.
ID:	623316   Click image for larger version
The Following User Says Thank You to 1_Wild_Cat For This Useful Post:
  #224
Old 11-16-2023, 05:48 PM
1_Wild_Cat's Avatar
Hi Everyone --
Cam says: "And with that, all the major body work is done!"
Now we handle some of the "minor" stuff...Then SPI epoxy...Then my shop for everything else...
Yahoo - Progress!
Thanks everyone for following along. And your kind words and encouragement.
The final results on the quarter...
ID:	623356   Click image for larger version
ID:	623357   Click image for larger version
  #225
Old 11-16-2023, 06:06 PM
tempest1964's Avatar
Looks amazing!
  #226
Old 11-16-2023, 08:35 PM
ZeGermanHam's Avatar
Top notch! Very glad to see progress on this.
1998 BMW 328is (track rat)
  #227
Old 11-17-2023, 05:13 PM
1_Wild_Cat's Avatar
Looks amazing!
Thanks. Feels good to be making real progress again.
  #228
Old 03-13-2024, 01:15 PM
1_Wild_Cat's Avatar
Hi Everyone -- A little update for those still following along.
The hits just keep coming...The passenger door was banged up pretty good. Enough that fixing it was easier/faster by removing the skin. Maybe this was a good thing - since the rust laying in the pinch weld can be dealt with.
We will probably remove the skin from the other door too based on the rust. "In for a penny, in for a pound"...
In other news: Paul K hooked me up with a set of Molnar 6.7" rods to go with my Molnar crank. Super nice guy and great to deal with.
The trek continues. Thanks to everyone for following along - I sincerely appreciate it.
Name:	Passenger Door 2.jpg
ID:	630319   Click image for larger version
Name:	Passenger Door Struct Rust.jpg
ID:	630320   Click image for larger version
  #229
Old 03-13-2024, 06:45 PM
69hardtop 69hardtop is offline
I have a 64 pass door for parts if you need anything (I’m keeping the glass)
  #230
Old 03-14-2024, 10:31 PM
1_Wild_Cat's Avatar
Thanks. I don't think it will come to that - but I'll keep it in mind.
  #231
Old 05-17-2024, 01:23 PM
1_Wild_Cat's Avatar
For those following along....
Well - We had traction for a minute. But Cam was roller skating with his daughter recently...and managed to shatter both bones of his lower leg. Rods, screws, plates and 2 surgeries kind of break. Man...he has some tough luck. Looking like 8 weeks for recovery...
Thanks everyone for following along...I really do appreciate you taking this journey with me.
  #232
Old 05-17-2024, 02:20 PM
Cardo's Avatar
Cardo Cardo is offline
Uhhhhh! That's rough. You'd better go find something else that needs to be done for a while. Start polishing the stainless or rebuild something... It's gonna be a hot minute before he's back at it.
