Old 11-17-2023, 12:01 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
Default Old Venolia blower pistons .047 in the hole
Years ago I started to build a new 428 to replace the 455 in my 78 T/A. I started to build the motor and discovered the pistons were well down in the hole, a whopping .047.
I bought the used Venolia blower pistons (.990 pins) from the late Greg Merrick. He had passed before I used them so I couldn't ask him about it.
With that said, I shelved the project for a few years. I did find a set of BBC 6.660 rods and I do have a factory 428 crank with 2.20 rod journals. The pistons will still be .012 in the hole but it's usable.
Idea #1 build it with the 6.660 rod and spray it.
Idea #2 build it with the 6.625 (Eagle ESP .990 pin) rods and put a 6/71 blower on it.
Either way, I would be using my KRE aluminum heads on it with pump E85.
Attached is a old picture showing how far the pistons were in the hole. I believe this was the old style way of running blower pistons?
Thoughts?
Name:	428 deck1.jpg
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 300CFM D-ports, Howard's custom SFT, Nash Intake,QFT 950 E85 carb, TCI TH-350, 4200 converter 3.73 12 bolt [email protected]
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1972 LeMans 350 Pontiac H/S Drags project
Old 11-17-2023, 03:41 PM
Stan Weiss's Avatar
Idea #3 A 6.700" rod and a thicker head gasket
Stan
Pontiac Pump Gas List
The Following User Says Thank You to Stan Weiss For This Useful Post:
Old 11-18-2023, 03:12 PM
Johnny406's Avatar
Stan
The pistons would be out .028 so run a .060 headgasket?
Old 11-18-2023, 03:22 PM
Mr Twister's Avatar
Butler stocks .055 Cometic head gaskets. I have a set from them for a boost project.
The Following User Says Thank You to Mr Twister For This Useful Post:
