Old 11-20-2023, 06:56 PM
1964 GP 1964 GP is offline
Default 1964 Grand prix steering
Hi, I have a 1964 Grand Prix with a 389.
The steering arm is hitting the oil pan/ drain plug And it has dented the oil pan in, not enough for it to leak but i would like to correct the steering so that it is where it should be.
Is anyone else having this problem or have any ideas on how to fix it.
Old 11-20-2023, 08:05 PM
Mr Twister's Avatar
No experience with the car in question but I would check motor mounts for sag, deteriation, etc
The Following User Says Thank You to Mr Twister For This Useful Post:
Old 11-20-2023, 08:42 PM
ok thanks, thats a good thought. I will check into that
Old 11-20-2023, 11:48 PM
AZ64GP AZ64GP is offline
I own a '64 GP and though I have not driven it yet (I'm in the process of restoring it), I have not seen this problem with my car. Even before the car was taken apart and even after replacing all of the steering/suspension system, I did not have any issue with the steering arm contacting the oil pan.
I think the other reply about worn engine mounts or suspension/steering parts is playing a role in that issue. Good luck and let us know what you find.
Old 11-21-2023, 11:52 AM
Ok thanks, do you know how close the steering arm is to the oil pan on your GP? when you have the wheels straight. Or turned all the way to the right?
Old 11-21-2023, 12:00 PM
MarkS57's Avatar
MarkS57 MarkS57 is offline
My 62 389 Bonneville trashed a drivers side mount. One way of checking is to start the car with the hood open, foot on the brake, go to drive and apply gas putting stress on the mount. When mine went, you can see the engine start to lift up on the drivers side easily even sitting in the drivers seat.
65 Tempest, 400, TH400
86 Fiero SE 2.8
Old 11-21-2023, 12:06 PM
Thats a good idea. I have the exhaust off the car right now so it will be pretty loud in the shop!
Old 11-23-2023, 11:29 AM
I'm sorry but the engine is currently out of my car and I can't check for you. I do remember that the steering arm and the oil definitely did not touch.
Old 11-23-2023, 11:42 AM
Is this the original engine? If not maybe wrong oil pan?
Old 11-23-2023, 02:25 PM
it is the original engine (389) and the oil pan looks the same as other pictures of 389's oil pans. So I am guessing it is correct.
Old 11-23-2023, 02:29 PM
Does anyone have a 1964 GP with a 389 that they could measure the steering arm to the oil pan? It would help lots so that I know if from factory it was close to hitting the pan(but not touching). It would just let me know if mine is only a little out of whack. Or a lot out of whack
Old 11-23-2023, 09:00 PM
my 1964 GP has the 8 lug wheels and i want to put torque thrust wheels on it. But the front wheels on a 1964 GP have the brake drum bolted onto the spindle where the hub would go. (some Grand prix's had regular 5 bolt wheels)
I am looking for 5 bolt hubs for my 1964 GP but I cant find any place that has them. some places have 5 bolt hubs for a 1964 GTO. Does anyone know if the 1964 GTO front hubs would work on a 1964 GP?
Old 11-24-2023, 11:22 AM
You're better off creating a new thread for each question you have. It's easier for people to respond and also for you and other members to look up in the future if needed.
You won't be able to use '64 GTO spindles on your '64 GP. The suspension and steering geometry are completely different between the cars, as well as different bolt patterns. Someone smarter than me can probably reply with additional info on how to make the conversion from 8 lug to standard brakes on the GP, but I recommend searching Ebay for used '64 Catalina/GP/Bonneville spindles. You can also try Pontiac parts yards like Pontiac Heaven in AZ or Frank's Pontiac in CA. They can probably remove a pair of spindles for you and ship them to you. I'm not aware of any companies which are reproducing the spindles for our large cars as new parts.
Old 11-24-2023, 11:49 AM
Ok, thanks thats very good to know. And I will also do the new thread idea.
Old 11-24-2023, 11:58 AM
MarkS57's Avatar
2nd to Frank's. I've delta with them many times, no disappointments yet. Are the spindles different between the 2 wheels or just the hubs? If the hubs, then follow this link ~3/4 of the way down to the drums and there are 3 sets hubs & drums ready to go, I'd go with the 3rd set, finned & cut only .038 & 040. FWIW.
https://www.frankspontiacparts.com/e...nsionparts.htm
86 Fiero SE 2.8
Old 11-24-2023, 12:45 PM
I need to double check but I think the spindles are the same. WOW thank you sooo much! franks actually has some 5 bolt assembly's!
Old 11-24-2023, 12:58 PM
yes the spindles are the same so that is a perfect match then. Thanks
Old 06-30-2025, 06:56 PM
Hey, I forgot to update ya'll about the Grand Prix, I was able to figure out the steering arm problem. Turns out it was just bent... lol. It was in a funny spot and it made it hard to notice. Now it has plenty or clearance to the oil pan and it works as it should!
Also I found a nice disk brake conversion kit on eBay for about $500. (which is cheaper then buying the used stuff from Franks).
Thanks for all your help!
Old 06-30-2025, 09:39 PM
Where are you located? I just removed complete front brakes in like new condition to install disc brakes on a 1964 GP.
Old 06-30-2025, 10:15 PM
I live in Canada, Manitoba. Currently I am not in need of an original set of brakes. But depending on the price i might consider it.
Do you have the 8 lug aluminum or the 5 bolt steel?
