Old 11-26-2023, 11:36 AM
Mr. G Mr. G is offline
Default 1970 T/A stripes
The '70 T/A is coming out of the paint shop soon after being held hostage for almost three years. I had originally asked the shop to paint the stripes on the car instead of using the decals but I am having second thoughts on this and wondered if other T/A owners had the stripes painted on and how that turned out. Basically I am trying ti figure out which would be the best way to go about getting the correct stripes on the car with either reproduction stripe kit or have them painted on. Any feedback would be appreciated.
Old 11-26-2023, 01:10 PM
72projectbird's Avatar
What color is the car?
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 11-26-2023, 02:02 PM
It is a blue car.
Old 11-26-2023, 02:09 PM
R 70 Judge's Avatar
I’d use reproduction decals over paint. I wouldn’t trust them to get the stripes right with paint
James
1970 Trans Am
The Following User Says Thank You to R 70 Judge For This Useful Post:
Old 11-26-2023, 03:31 PM
Yes. That is what I am afraid of and after all this time I want it to be as correct as possible. Any recommendations for reproduction graphics?
Old 11-26-2023, 06:36 PM
R 70 Judge's Avatar
Here a good read regarding the latest run of reproduction stripes that were done. They are very highly rated. I bought a set for a white car to hold on to until I repaint my TA.
https://forums.maxperformanceinc.com...d.php?t=834302
Buy them here assuming they are still available
https://www.stencilsandstripes.com/p...s-am-firebird/
James
1970 Trans Am
TA455HO's Avatar
TA455HO TA455HO is offline
A forum member named Greg worked with Ralph at Stencils and Stripes to get them to recreate the decals from original GM stripes. We did a group buy a few years back since they needed a good number of pre-orders to make sure the up-front work was worth it. Now they have them on the shelf.
The Following User Says Thank You to TA455HO For This Useful Post:
Old 11-26-2023, 08:46 PM
I Agree your best bet is to go with Stencils & Stripes unless you could find a new old stock set
Old 11-26-2023, 09:00 PM
Thanks Gang! Stenciles and stripes it is.
Old 11-26-2023, 11:00 PM
necdb3's Avatar
necdb3 necdb3 is offline
Paint will never match the dot matrix pattern on the sticker.
The Following 2 Users Say Thank You to necdb3 For This Useful Post:
Old 11-28-2023, 01:03 PM
This is why I thought I had better ask here about the stripes as I have never had a chance to look closely at a correctly done blue '70-'72 T/A so I did not realize the design and the dot matrix part of the stripes, but in doing a bit of research it began to appear more complex than I had figured so as usual, I came here seeking advice. Thanks all for saving me a big head ache. Stencils and stripes is sending the entire stripe kit to me so the painter's job will be much easier.
Old 11-28-2023, 01:26 PM
My '70 has painted on stripes. They look good... but they aren't right.... but the car isn't right either.
Old 11-28-2023, 03:31 PM
Norwood's Avatar
Norwood Norwood is offline
Only a very few early blue cars got a dot pattern stripe. A member here has one. Very early in the production run the stripe was changed to solid black and white
The Following 2 Users Say Thank You to Norwood For This Useful Post:
Old 12-05-2023, 12:44 PM
OK. Now I am confused. So does the Stencils and Stripes kit feature the dot pattern or the later version of the stripes? As I mentioned before, I have never had the opportunity to look at one of these cars in real life so I was unaware there were two versions of the stripe.
Old 12-05-2023, 03:24 PM
necdb3's Avatar
The white cars had a dot matrix pattern in the stripe as a fade in the black portion. The blue cars were as mentioned. Most had solid colors without the dot matrix fade.
JMO, if I had a blue car, I would still prefer the sticker over a painted stripe because that's how they came. Again, JMO
Old 12-05-2023, 03:55 PM
srmmmm's Avatar
srmmmm srmmmm is offline
Attachment 623937
You car looks great! I've always wanted to see a version will fully blended-in wheel well spoilers. Nicely done!
