Old 12-02-2023, 04:42 AM
grivera's Avatar
grivera grivera is offline
Default What’s this QJet Worth
I acquired a 68 QJet Part Number 7028262 B8 VC - originally thought it was a 69 and planned on keeping it for the bird. It was in operating condition when I received it a couple of years ago. All linkage moves freely. What’s she worth?
ID:	624181   Click image for larger version
ID:	624182   Click image for larger version
ID:	624183   Click image for larger version
ID:	624184   Click image for larger version
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded)
Old 12-02-2023, 05:24 AM
Drag Star Le Mans's Avatar
Is this a Price is Right question? $1.00 Sorry I'm a west coast guy up late.
DragStarLeMans
Old 12-02-2023, 05:26 AM
Kenth's Avatar
Kenth Kenth is offline
Your carb is a "remanufactured" Frankencarb with a Carter made 7028262 float bowl and Buick airhorn and Buick throttle plate.
These kind of carbs usually have issues that takes a book to describe.
Value is in individual parts if you know what to look for, as a carb next to nothing i´m afraid.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
The Following 4 Users Say Thank You to Kenth For This Useful Post:
Old 12-02-2023, 05:41 AM
grivera's Avatar
Thanks- look forward to additional responses. Educate me - how do you know it’s a mix of parts?
Will Rivera
Old 12-02-2023, 06:52 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Well, LOTS of tell-tale signs of being a miss-match of parts. Buick throttle shaft/baseplate. Buick choke parts, 3/8" PCV vacuum tube used as a front vent. 2GC check ball retainer driver into the hole at the top of the choke tower in the airhorn.
It's also a Carter casting, not Rochester. They don't hold up quite as well from that time period and almost 100 percent of them will need a heli-coil for the fuel filter housing and many have already had the dreaded double "O" ring N/S instead of the screw in varity.
I wouldn't even work on those here when I still had the shop open doing carburetors. Lessons in humility await those who venture in that direction.......FWIW
The Following 5 Users Say Thank You to Cliff R For This Useful Post:
Old 12-02-2023, 11:40 AM
grivera's Avatar
Thanks .
I was planning on rebuilding this 17058241 carb - is it a mix of parts as well?
ID:	624191   Click image for larger version
ID:	624192   Click image for larger version
ID:	624193   Click image for larger version
ID:	624194   Click image for larger version
Will Rivera
Old 12-02-2023, 11:42 AM
grivera's Avatar
More pics of the 17058241:
ID:	624196   Click image for larger version
ID:	624197   Click image for larger version
Will Rivera
Old 12-02-2023, 12:31 PM
I don't know how to recognize the Frankencarbs like Kenth and Cliff but I can tell you that it's a Buick carb. At least the throttle plate. They have that funky, bent looking throttle arm. Actually, I would think that would be a pretty good one to build according to one of Cliff's recipes. I have one on the shelf myself. One good thing is the inlet being on the front like Pontiac.
Old 12-02-2023, 01:15 PM
Cliff R's Avatar
It looks about as original and unmolested as they come......
The Following 2 Users Say Thank You to Cliff R For This Useful Post:
Old 12-02-2023, 01:41 PM
grivera's Avatar
Great - thank you. It moves freely- once I get an engine together I will contact you for rebuild kit.
Will Rivera
Old 12-02-2023, 02:23 PM
Shiny Shiny is offline
I also got a lot of help identifying my Frankencarb. These people on PY are awesome.
What's the chance you experts could create a "How to ID a Frankencarb" sticky?
I learned a little but found it frustrating when, for example, I tried to use the casting part numbers to see if the body, airhorn, and throttle plate were "correct". I never found a listing... if this exists anywhere in Rochester or Delco literature, it would be a godsend.
I did learn that any carb with a blocking tab has been through a rebuilder...
Old 12-02-2023, 05:30 PM
Cliff R's Avatar
"Great - thank you. It moves freely- once I get an engine together I will contact you for rebuild kit."
Sounds great. We'll do a slight recalibration at the same time. I've built a lot of those and aside from the "goofy" linkage they make a great electric choke high performance unit.....
Old 12-02-2023, 08:57 PM
carbking's Avatar
carbking carbking is offline
Casting part numbers are for a "blank" casting prior to machining; they are not unique. One can sometimes use the casting numbers to get in the ballpark, but not to knock the home run.
A better use of the casting numbers is the negative side. If a carburetor doesn't have a certain casting, it isn't what it is supposed to be; but just because it has the proper casting number is not a positive identification.
A much more useful document would be a part number interchange, which Rochester actually printed........................................... .........in 1959! Have never seen a newer one.
I have spent hundreds of hours, perhaps thousands of hours, working on one, but a long way from complete.
Jon
The Following User Says Thank You to carbking For This Useful Post:
Old 12-02-2023, 09:53 PM
Jon
Thanks Jon
I appreciate the casting numbers were machined per application and therefore not definitive. I also get your point about the "wrong" casting number being an obvious mismatch.
I found it totally unexpected that each main part would not have a unique identifier after machining. I have no idea how they managed this in a factory but obviously they had a way.
Interesting and again, unexpected, about the lack of a "published" interchange document. I guess without a unique identifier on the machined part, such a document would have limited value.
Your list would be more like VERY valuable. I can't be the only one that's ever struggled to determine what he had or want to piece together a "correct" set of cast parts. Even being in the ballpark would feel like a home run after a couple hours of frustrating puzzle-solving.
Mike
