Old 12-02-2023, 08:56 PM
Tim Corcoran's Avatar
Tim Corcoran Tim Corcoran is online now
Five More
ID:	624262   Click image for larger version
ID:	624263   Click image for larger version
ID:	624264   Click image for larger version
ID:	624265   Click image for larger version
Tim Corcoran
The Following 2 Users Say Thank You to Tim Corcoran For This Useful Post:
  #82
Old 12-02-2023, 09:03 PM
Five More
ID:	624267   Click image for larger version
ID:	624268   Click image for larger version
ID:	624269   Click image for larger version
ID:	624270   Click image for larger version
Tim Corcoran
  #83
Old 12-02-2023, 09:26 PM
Last 3
When I showed the IH the .953 is my eheads
the .976 is the speedmaster
the .918 is the speedmaster with a .055 spring locater
You will notice in some of the pictures I am showing my older style combustion chamber eheads compared to the streetmaster heads
ID:	624275   Click image for larger version
ID:	624276   Click image for larger version
Tim Corcoran
  #84
Old 12-02-2023, 10:10 PM
AG's Avatar
AG AG is offline
Heads look good and you can't beat the price. I wanted to get a pair of the assembled non-CNC ported HR heads since the assembled weren't much more than bare heads. I don't need them so I didn't get them, but I will get them in the future if I have a need.
  #85
Old 12-02-2023, 10:44 PM
Unless something has changed 1.65 will work out the box. 1.5 will need work to fit
The Following User Says Thank You to chiefbigb For This Useful Post:
  #86
Old 12-02-2023, 10:55 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
Mine came in yesterday as well. I'm going to try to pull the 463 out of my 78 T/A next week (weather pending), I'll match them up and do some comparison pictures with my KRE D-ports once those heads are off.
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 300CFM D-ports, Howard's custom SFT, Nash Intake,QFT 950 E85 carb, TCI TH-350, 4200 converter 3.73 12 bolt [email protected]
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1972 LeMans 350 Pontiac H/S Drags project
The Following User Says Thank You to Johnny406 For This Useful Post:
  #87
Old 12-02-2023, 11:04 PM
HUH?
Tim Corcoran
  #88
Old 12-03-2023, 12:54 AM
performerrpm's Avatar
i think chiefbigbmight have got the ratios confused as to what fits
  #89
Old 12-03-2023, 08:03 AM
I recently installed a set on a 406. 1.5 ratio rockers have the pushrod up against the intake side of the hole. A 1.6 rocket centered it in the hole.
  #90
Old 12-03-2023, 08:07 AM
Mock up pics
  #91
Old 12-03-2023, 10:33 AM
Moved the holes towards the intake side about where the valve cover rail is and had plenty of room.
  #92
Old 12-03-2023, 01:21 PM
Thanks for the clarification that is good info. It's the opposite of what we see on iron heads and E-heads that's why I was confused. You wouldn't have a photo of the rework would you? Curious how big and how far down I will need to go.
Tim Corcoran
  #93
Old 12-03-2023, 06:11 PM
Best I can do. Looking at the hole next to the pushrods you can see a bit. Moved the entire hole that direction top to bottom
  #94
Old 12-03-2023, 09:11 PM
Johnny406's Avatar
Does anyone know what the valve spring open/closed pressure is on the SM HR heads?
  #95
Old 12-03-2023, 10:08 PM
Flattrack88 Flattrack88 is offline
Here's what mine looked like when it had 1.5s. Fortunately only used them for break in then switched to 1.65s.
  #96
Old 12-03-2023, 10:22 PM
Bill Eveland's Avatar
See post 66.
Illinois Outlaw Gassers
6.27@107
9.97@131
The Following User Says Thank You to Bill Eveland For This Useful Post:
  #97
Old 12-03-2023, 11:06 PM
The heads I received the holes for the rocker studs were not deep enough to install the studs all the way. I will have to cut an 1/8" inch off the studs to get them fully seated. Has anyone else had this problem? Has anyone cc's these to see if they are actually 78 cc's?
Tim Corcoran
  #98
Old 12-04-2023, 10:00 AM
Murf Murf is offline
Tim, are they too short with the helicoil tangs broken off? I’ve broken the tangs off mine but haven’t installed the studs yet to see if mine fit properly.
Murf
  #99
Old 12-04-2023, 10:15 AM
I had old studs and guideplates from my E heads when I switched to a shaft and they fit fine even before the tabs were popped off. But the first one before I popped tabs off felt a little "tight" at the bottom.
  #100
Old 12-04-2023, 10:23 AM
Used a hack saw and cut mine a bit.
ID:	624378   Click image for larger version
