Old 11-28-2023, 12:15 PM
1oldgoat's Avatar
1oldgoat 1oldgoat is offline
Default Wanted 7029099 Choke Stat Coil
I am looking for an original or NOS 7029099, stamped 9099 choke stat coil. Thanks.
68 GTO Ram Air I Auto, Starlight Black/Teal-Survivor
68 Firebird Ram Air II 4spd, Aegena Blue/Black/Black
68 Firebird 400 Conv. Auto, Red/Parchment/Parchment
69 Firebird Ram Air IV, 4spd Matador Red/Black-Survivor
71 GTO 455HO 4spd, Lucerne Blue/Black/Black
71 GTO 455HO Auto, Lucerne Blue/Sandalwood/Blue
Old 12-05-2023, 08:32 AM
Scott Thelander's Avatar
Default Choke
Well
Sorry
I don’t have one……
Scott
702 7197
702 7198. None
702 8097
702 8097 ——- restamp w 8098
702 8098
702 9097
702 9098
702 9099. None
702 0097
702 1094
Pontiac Rochester choke coil thermostat 3.750
1967 1968 1969 1970 1971 RA Iii IV 400 428 455
Gto Firebird HO
ID:	624433   Click image for larger version
ID:	624434   Click image for larger version
ID:	624435   Click image for larger version
ID:	624436   Click image for larger version
Old 12-05-2023, 09:20 AM
1oldgoat's Avatar
Originally Posted by Scott Thelander View Post
Well
Sorry
I don’t have one……
Scott
702 7197
702 7198. None
702 8097
702 8098
702 9097
702 9098
702 9099. None
702 0097
702 1094
Gto Firebird HO
Thanks for checking Scott!
Old 12-06-2023, 02:26 PM
Tim john Tim john is offline
I finally found the box I was looking for and the one I have is a 9097, it is in excellent condition if that helps you out. According to the box and paperwork inside, I purchased this from Jim Hand years ago for our 69 Firebird.
Tim
Old 12-06-2023, 02:42 PM
1oldgoat's Avatar
Tim
Thanks Tim. I appreciate your help. I do need the 9099 specifically for my application.
Old 12-15-2023, 09:56 PM
68hotbird 68hotbird is offline
Default choke stove
my 69 bird ra iv has a 9097 on it from the factory. Very early lords town built car.
Old 12-17-2023, 03:50 AM
1oldgoat's Avatar
Interesting. Everything I have seen says It should have the 9099. Thanks for the info.
Old 01-20-2024, 01:17 PM
unruhjonny's Avatar
FYI:
THIS just showed up on one of my ePay alerts.
1970 Formula 400
Old 01-21-2024, 11:25 AM
I looked no 9099 but what does 9098 come on ? I have one of those. Thanks
Old 01-21-2024, 05:12 PM
unruhjonny's Avatar
Scott’s last picture attachment with post #2 shows applications;
they can also be found in a master parts catalog
1970 Formula 400
The Following User Says Thank You to unruhjonny For This Useful Post:
Old 01-21-2024, 10:35 PM
1oldgoat's Avatar
Thanks for the heads up. I am going to hold out for a 9099.
Old 04-09-2024, 03:04 PM
unruhjonny's Avatar
what do you make of this?
1970 Formula 400
Old 04-09-2024, 03:16 PM
1oldgoat's Avatar
Interesting! I'm not sure what to make of it. I have been told that some of the original RA IV cars came with ones with another number on them that is crossed out like this one and re-stamped with 9099 by the factory. I have not seen or heard of one with 9099 crossed out. PM sent.
Old 04-09-2024, 03:30 PM
unruhjonny's Avatar
I just noticed this!
That picture I posted - probably because of the lighting, made me think I was seeing a "0" and an "8" to the left of the number - obscured by rust;
I just lightly wire wheeled it, and sure enough - to the left of the lined out 9099 is a 1094
EDIT:
So based on Scott's handy list, was this maybe a left over 9099 that was renumbered to use on a 1971 455HO?
Old 04-09-2024, 04:20 PM
Nice find!!!
Pinion head has a great chart on the speed /timing the different numbers open up
Old 04-09-2024, 06:18 PM
unruhjonny's Avatar
I just came across this thread/post:
Originally Posted by Bet Winner View Post
Here is a little chart:
REMOVED
I believe I ordered a new choke thermostat from Pontiac in 1979 or 1980 because the original choke spring was not keeping the choke completely closed. I have not found the original choke thermostat housing, but I'm still looking. The number stamped on my replacement is 1094 which agrees to the choke stamped number for a 7028273 carb in this chart. Is the correct Ram Air III manual 7028273 choke thermostat housing stamped 1094, or is it 9097 as stated below?
If 9097 is correct, why does this chart show 1094?
The chart link is removed because it is nfg;
Was 1094 maybe a latter replacement number - in addition to the original application of '71 455HO?
1970 Formula 400
Old 04-09-2024, 06:24 PM
1oldgoat's Avatar
Yes, the 1094 is the service replacement for many applications including the 9099. I have an NOS 1094.
The Following User Says Thank You to 1oldgoat For This Useful Post:
Old 04-09-2024, 06:39 PM
unruhjonny's Avatar
interesting.
I wonder if lack of demand for 9099 necessitated renumbering this one?
1970 Formula 400
Old 04-09-2024, 07:01 PM
1oldgoat's Avatar
interesting.
That one is interesting too!
Old 04-11-2024, 05:45 PM
nice .....
