Old 12-04-2023, 11:20 AM
Tim Corcoran's Avatar
Yes, even with the heli-coil tangs broken off they are still about an 1/8 inch short of seating tight against the guide plates.
Tim Corcoran
  #102
Old 12-04-2023, 11:22 AM
Nobuddy Nobuddy is offline
Originally Posted by Tim Corcoran View Post
The heads I received the holes for the rocker studs were not deep enough to install the studs all the way. I will have to cut an 1/8" inch off the studs to get them fully seated.
Similar on mine and depends on the studs and guideplates used. With the original tangs removed, ARP 100-7101 bottomed out. The blind hole is deep enough so I just wound out their coil, used a helicoil bottoming tap to add more threads, and also used a longer helicoil. I had the tools so cost me nothing.
Barry
  #103
Old 12-04-2023, 12:06 PM
mysticmissle's Avatar
I trimmed the studs for the pair we have running
Many versions of the bbc 7/16 stud out there I went taller to get geometry where I wanted it
Cutting a little off the bottom Was not a big deal breaker for me
These are good Budget heads anyone that thinks otherwise hasn’t driven a car with them on
  #104
Old 12-04-2023, 01:52 PM
I want to think I use ARP 7102s.
  #105
Old 12-04-2023, 01:58 PM
I had to shorten studs to fit factory iron heads just a month or so ago.
  #106
Old 12-04-2023, 02:26 PM
Edelbrock guide plates are thicker. That would help with this issue but like a few others I just trimmed up the studs. I have run into this on iron heads also.
  #107
Old 12-05-2023, 10:56 PM
mrennie's Avatar
mrennie mrennie is offline
Originally Posted by Johnny406 View Post
Does anyone know what the valve spring open/closed pressure is on the SM HR heads?
I'm looking for the same info, but for the flat tappet version if anyone has it handy.
Michael
1970 Oshawa built 1 option Judge. 24 year restoration/upgrade project finally finished!
1979 Trans Am - low-buck drag car project for when I retire
  #108
Old 12-05-2023, 11:04 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
If you're running a solid flat tappet, the HR springs are quite adequate.
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 300CFM D-ports, Howard's custom SFT, Nash Intake,QFT 950 E85 carb, TCI TH-350, 4200 converter 3.73 12 bolt [email protected]
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1972 LeMans 350 Pontiac H/S Drags project
  #109
Old 12-05-2023, 11:38 PM
mrennie's Avatar
I bought the HFT version for a future project. Don't have a cam picked out but the spring specs would be helpful.
Michael
  #110
Old 12-06-2023, 11:48 AM
Wouldn't Speedmaster be able to give you the spring rates? I'd give them a call.
Tim Corcoran
  #111
Old 12-06-2023, 12:27 PM
Of interest......
https://www.speedmaster79.com/1.450-....060-Coil-Bind
Old information here:
  #112
Old 12-06-2023, 12:53 PM
I noted the springs linked above are the only set that are 1.450" O.D. at 1.800" installed which is listed for their Pontiac cylinder heads.
I presume they would use the springs they sell.
Also noted the 1.800" - 1.060" Coil Bind info listed does not correlate with their 0.580" max lift stated.
Side note, regarding the 1.800" installed height stated.
I've seen two posts regarding two different sets of heads received and they were measured at 1.780" and 1.825" installed height.
  #113
Old 12-06-2023, 01:25 PM
Stan Weiss's Avatar
Steve,
This shows that many valve springs have those same differences listed.
Stan
Pontiac Pump Gas List
The Following User Says Thank You to Stan Weiss For This Useful Post:
  #114
Old 12-06-2023, 02:37 PM
Understood. But doing the
Math with it just doesn't jive with the max lift.
  #115
Old 12-06-2023, 02:52 PM
Steve
your link has this below. Notice at the bottom is says those springs are for small SBC and SBF heads.
Brand: Speedmaster
Part Number: PCE272.1007
Part Type: Valve Springs
Number of Springs Per Valve: Dual
Outside Diameter of Outer Spring (in): 1.450 in.
Coil Bind Height (in): 1.060 in.
Damper Spring Included: No
Spring Rate (lbs/in): 130lbs @ 1.800 in.
Inside Diameter of Outer Spring (in): 1.080 in.
Inside Diameter of Inner Spring (in): .834 in.
Valve Spring Style: Standard
Coated: No
Quantity: Sold as a set of 16
Notes: Dual valve spring commonly used in aftermarket aluminum Small Block Chevy and Small Block Ford Heads.
Tim Corcoran
  #116
Old 12-06-2023, 02:58 PM
Stan Weiss's Avatar
Steve,
Maybe they are using different Math. By that I mean these springs may want a difference min distance at coil bind than we are normal use too.
Stan
  #117
Old 12-06-2023, 03:39 PM
I cc'd the 78cc heads today and they measured 75cc's. I need closer to 80cc's, can I remove some material from the combustion chamber and get a few more cc's?
Tim Corcoran
  #118
Old 12-06-2023, 04:04 PM
Tim,
I see what the link says regarding Small Block Chevy and Small Block Ford Heads. However they state their Pontiac heads use a 1.450 O.D. spring, and from what I gather at a 1.800 installed height.
That is their only spring that matches that criteria as far as I can find in their catalog.
  #119
Old 12-06-2023, 06:02 PM
Dragncar Dragncar is offline
Speedmaster ? I bought a fuel pump, 2 filters and a filler neck for my fuel cell.
Nothing from them comes with instructions ? Who sells a fuel pump with no instructions ? Not even a "in-out" on the pump or what amp fuse to use.
The fuel filters, one 8AN has O rings on the caps. When you tighten them by hand you can not feel the O ring contact the tube. I think it will leak unless I change it to O rings that seal.
The other filter is a 3/8" hose deal and the nipples are barely long enough for a hose clamp and the little bump on the end is not big enough for my liking. It was 8 $ so what the heck.
Not saying none of this stuff will not work but you have to double check everything.
Simple instructions would be nice.
I guess they feel they can just copy what they want and put it out there without any.
Hey, they stuff was cheap but the you get what you pay for rule applies.
  #120
Old 12-06-2023, 07:07 PM
mrennie's Avatar
Probably, but was looking for actual results if anyone had measured them on a tester. I have no doubt SM can give me specs but I have trust issues. Will likely measure them myself prior to doing anything but was just curious if anyone had some existing experience.
Michael
