#701
That's a very rare & valuable exhaust manifold!!!
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
#702
I'll try running with just the one, I don't think it is going to work well...
1968 Firebird 400 coupe, Verdoro Green w/black vinyl top 1969 GTO Judge, Carousel Red, 4-speed, numbers matching 1971 Trans Am Cameo White, Auto, numbers matching 1970 Buick Skylark Custom convertible Fire Red 1972 Buick GS 455 Stage 1 Royal Blue |
#703
#704
I'm guessing no flow numbers because he didn't finish them, just bare cores with new guides &seals. I expected them to be pricey, and I would have bid, but local pick up only knocks that in the head. 2800 miles between me & him.
Ol' man Smith Pigeon Forge, Tn. Grand Rod Run Spring 2012 https://www.youtube.com/watch?v=DUIuGvWWthA http://s223.photobucket.com/user/fas...d%20Run%202012 Son video'd this... http://s223.photobucket.com/user/fas...a.mp4.html?o=0 |
#705
This is one of my favorite threads. Since I am new to Firebirds in general, can someone summarize the telltale signs of a RAII Firebird in case I am lucky to ever come across one?
#706
If you find a car that meets those first two criteria then other clues would be round port heads with "R" and "A" on the end exhaust ports, Ram Air pan and hood baffle, open hood scoops, HD axle with 3.90 or 4.33 gear set and M-21 trans (if manual). I think many or most F bodies had the 3.90 gear set but the 4.33 may have been available as an option. If you find a car with some or all of these items then a PHS inquiry will confirm or deny RA II heritage. Sent from my XT1585 using Tapatalk |
#707
For identification purposes 1968 RA II heads are as follows: Code # 96, Casting # 9793596, Screw in Studs, 2.11 intake, 1.77 exhaust, Volume 71cc.
These are good high compression round port heads. RA 1 & RA III are also good heads, however, they are D-port. Not saying you can't get D-ports to flow great numbers, but for the sake of describing RA II heads, remember they are early round port heads. If you happen up upon an abandoned 1968 firebird and you see heads attached to an engine that bear this description, you may wish to take a much closer look at what you have found. ![]() Verify the casting numbers to be sure. Don't mistake 1971 400 Cu In #96 heads for these. The 71's are great for bumping up the compression on 455 engines with their 96cc volume, but won't do much for your 400 engine. Hopefully, other guys will chime in and give you a lot better quick reference than I can.
#708
Thanks guys, this is exactly what I was looking for.
#709
ID wise, early heads are marked R on one end exh port and A on the other, later castings are 96. If the Firebird has Round port heads, pay the guy before he figures out what he has. Look at the difference between D port and O port, (middle exhaust port area) and you will be able to spot them across the parking lot. Of course there are many O port heads, RAII, RAIV, 455HO, 455SD,along with Aluminum Edelbrock, Kauffman, etc. But any O port head will be worth more money, along with Exhaust Manifolds/ headers.
1968 Firebird 400 RAII M21, 3.31 12 bolt, Mayfair Maize. 1977 Trans Am W72 400, TH350, 3.23 T Top Everyone you will ever meet knows something you don't. Bill Nye. |
#710
My RAII heads have both casting marks.... R, A and 96. It is my understanding that early heads had R on the left exhaust port, two center ports blank and A on the right exhaust port. Later heads added 96 on the center ports but the R, A remained.
If this is correct, then it is super easy to identify RA II heads with zero chance of confusion by looking for the "R" and "A" cast marks on any round port head. Some may have 96 on the center ports while others may not so it isn't really that important for identification purposes initially. Sent from my XT1585 using Tapatalk |
#711
The #96 cast on the center exhaust ports appeared some time during the night shift of D228, the heads cast from the day shift do not have it and ALL of the heads cast on D238 have the 96 as well (along with all of the ones cast after that).
My heads are the non 96 ones. The heads on this motor are not the ones I have now but identical to them.
#712
Did not know that! That's odd they changed castings in the night? I think my heads may be D228, Marked R A .
#713
Looks like this thread has been quiet for years. Is there an updated list of know RA II Birds?
68 GTO Ram Air I Auto, Starlight Black/Teal-Survivor 68 Firebird Ram Air II 4spd, Aegena Blue/Black/Black 68 Firebird 400 Conv. Auto, Red/Parchment/Parchment 69 Firebird Ram Air IV, 4spd Matador Red/Black-Survivor 71 GTO 455HO 4spd, Lucerne Blue/Black/Black 71 GTO 455HO Auto, Lucerne Blue/Sandalwood/Blue |
#714
I started a Registry for '68 RA Firebirds around 30+ years ago. Collecting anything I can find regarding surviving RA & RAII Birds. Currently updating the matrix. While most owners are glad to help, some prefer to not share details so there are some gaps.
John '68 Firebird Ram Air 4-spd Conv. John 14:6 Semper Fi
#715
This thread is extremely out of date. You should start a site, John. You have the info on both of my RAII birds...both of which are not in this Roll Call since I found both in the last two years.
Ambition is a dream with a V8 engine. -Elvis |
#716
I have a rudimentary page I had set up for the RAI & II. John had sent me some of his data, which I included. Not sure how updated it is though.
Most data is from this site or from John. I may have added some of my data. RA I & II That page also has a link for the form to send/update info.
#717
#718
It is almost a twin to my RA II except for 4-speed and hideaways! It's amazing that they are still surfacing. I like how the guy just kind of nonchalantly mentions that it is a RA II at the very end?!
#719
Maybe they changed the ad but this was the first line now and honestly what I recall reading last night:
#720
You're correct.
![]() I didn't notice it. Just saw that it had a 455 in it. When I saw the BHC, I knew it was a RA II. Then read it again (guess not well) with the 455 being built and Aluminum heads and didn't see it mentioned until the end.
