#201
Get to work Jones!
Bilsteins going on the front of the '68 today...or maybe tomorrow...or the next day....soon. ; )
Greg Reid Palmetto, Georgia Last edited by Greg Reid; 11-21-2023 at 02:03 PM. |
| The Following User Says Thank You to Greg Reid For This Useful Post: | ||
#202
[QUOTE=Keith Seymore;6468022]Did a little photo shoot.
2024 marks the 60th Anniversary of the introduction of the GTO; as such the M1 Concourse will be hosting a special event on the Friday of the Dream Cruise weekend. The images taken today will be used to promote this special event. Wow!
Esquire '74 T/A 455 Y-code SD clone previously on Dawson's Creek: '74 T/A 400 '81 AMC SX/4 '69 FB 350 |
#203
Todays Pontiac task. Installing a new windshield and having back window reinstalled on the '72 T/A
Current Pontiacs -1973 Formula SD455 - #'s auto orig paint 1972 Trans Am - 4 speed orig paint 1966 2+2 convertible - 421 4bbl automatic 1967 Grand Prix - 4 speed orig paint 1967 GTO - 4 speed orig paint 35k orig miles |
#204
#205
...still chasing down a non-start issue.
#206
Stripping paint...
"Those poor souls have made the fatal mistake of surrounding us. Now we can fire in any direction" 1970 Trans Am RAIII 4 speed 1971 Trans Am 5.3 LM7 1977 Trans Am W72 Y82 1987 Grand National |
#207
Had a buddy do some paint work on the '72. Got it back today and turned out great. Next on the list is interior work.
#208
I changed the oil on the T/A and hunted around looking for find an obvious solution to the Service Engine Soon light that popped up the other day..
I learned about '95s is that they are OBD1 systems with OBD2 ports, so most code scanners won't work with them. You also can't jump the terminals get it to flash codes. I ended up ordering a special ALDL cable with an OBD2 end on it and a $130 Windows laptop so I can run a free app to scan the code. Still cheaper than a $300+ scanner. I suspect it's the temp sensor as the fans are running like crazy and the temp gauge isn't moving, but I'll find out for sure when my stuff gets here.
Ken '68 GTO - 464 - Ram Air II heads - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around) '74 Ventura 350 '69 AMC Javelin SST |
#209
Bled my front brakes..
What started out as the much needed front shock replacements mentioned earlier turned into calipers being rebuilt and new rotors, bearings and seals. Finally finished today with bleeding everything. I'll test them tomorrow and hopefully no air in the system. The front end was an area I never touched when I made this car roadworthy some years back. Way overdue! A 3 year old boy could move the old shocks in and out. Pretty much not absorbing anything. Calipers were pretty gummed up too but functional. I just couldn't ignore the rotor/brake appearance any longer longer... I'm thinking that I've found the cause of my long time, occasional front tire rubbing. Turning hard into an incline for instance. ![]() ![]() ![]() Sent from my moto g stylus (2021) using Tapatalk
Greg Reid Palmetto, Georgia Last edited by Greg Reid; 12-31-2023 at 11:40 PM. |
| The Following 4 Users Say Thank You to Greg Reid For This Useful Post: | ||
#210
Got windshield washing working on the 'Bandit' Suburban. The pump had quit, but it's part of the wiper motor assembly, which I didn't want to replace. A separate new pump ($10!) is ugly but functional.
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) ... or has a Pontiac born the same year as Jim Wangers? (1926}
#211
Block sanding the body shell. Sure wish I would have done this while it was on the rotisserie.
#212
I bought a front end rebuild kit. Does that count as doing something?
LIFT HEAVY, LIFE IS TOO SHORT TO BE SMALL! |
| The Following User Says Thank You to BILL BOWMAN1 For This Useful Post: | ||
#213
Jeff |
| The Following User Says Thank You to geeteeohguy For This Useful Post: | ||
#214
I backed the GTO out of the shop this morning to bring the wife’s car in for brakes. If that counts, so does yours.
‘63 LeMans- ‘69 400 w/ original transaxle. 2.69 gears. ‘55 Catalina ‘62 Mercury Meteor-all original, bought new by my grandfather 71' GTO -original 400/4-speed/3.23 posi 13.95 @ 102.1 on street tires @ 4055lbs.-now my sons ride |
#215
Took it out for a short ride and also top off gas tank.
Came back and changed oil and filter. Finally installed new cap & rotor, she did run smoother!! time to put her away for winter. Gerry
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, GM HEI and Ram Air pans and RARE Long Branch Manifolds |
#216
Deal! 😀
#217
Pulled the cardboard out from underneath to look for drips after 6 months. Found none. Slid cardboard back underneath!!!! Hope that counts!!
"Bill"! |
| The Following User Says Thank You to bill ryder For This Useful Post: | ||
#218
Removed paint from a quarter panel on my 62 GP project car. Long way to go.
My money talks to me-it usually says goodbye! |
#219
It's not a Pontiac, but a Buick. They're part of the BOP family.
Took the GN out today to run errands. We're supposed to get a bunch of snow this weekend, so I wanted to get it out. Put about 100 miles on it. I'll have Pontiac updates soon!
| The Following 4 Users Say Thank You to 72projectbird For This Useful Post: | ||
#220
wow that's sharp....
