Old 11-21-2023, 01:34 PM
Get to work Jones!
Bilsteins going on the front of the '68 today...or maybe tomorrow...or the next day....soon. ; )
  #202
Old 11-21-2023, 01:47 PM
[QUOTE=Keith Seymore;6468022]Did a little photo shoot.
2024 marks the 60th Anniversary of the introduction of the GTO; as such the M1 Concourse will be hosting a special event on the Friday of the Dream Cruise weekend.
The images taken today will be used to promote this special event.
Wow!
Old 11-21-2023, 02:00 PM
Todays Pontiac task. Installing a new windshield and having back window reinstalled on the '72 T/A
  #204
Old 12-31-2023, 08:27 PM
tempest1964's Avatar
Just about have my dual quad finished…….
ID:	625793   Click image for larger version
  #205
Old 12-31-2023, 08:31 PM
...still chasing down a non-start issue.
  #206
Old 12-31-2023, 08:40 PM
72projectbird's Avatar
Stripping paint...
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
  #207
Old 12-31-2023, 08:50 PM
Had a buddy do some paint work on the '72. Got it back today and turned out great. Next on the list is interior work.
  #208
Old 12-31-2023, 09:41 PM
Verdoro 68's Avatar
I changed the oil on the T/A and hunted around looking for find an obvious solution to the Service Engine Soon light that popped up the other day..
I learned about '95s is that they are OBD1 systems with OBD2 ports, so most code scanners won't work with them. You also can't jump the terminals get it to flash codes. I ended up ordering a special ALDL cable with an OBD2 end on it and a $130 Windows laptop so I can run a free app to scan the code. Still cheaper than a $300+ scanner. I suspect it's the temp sensor as the fans are running like crazy and the temp gauge isn't moving, but I'll find out for sure when my stuff gets here.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #209
Old 12-31-2023, 11:34 PM
Bled my front brakes..
What started out as the much needed front shock replacements mentioned earlier turned into calipers being rebuilt and new rotors, bearings and seals.
Finally finished today with bleeding everything. I'll test them tomorrow and hopefully no air in the system.
The front end was an area I never touched when I made this car roadworthy some years back. Way overdue! A 3 year old boy could move the old shocks in and out. Pretty much not absorbing anything. Calipers were pretty gummed up too but functional. I just couldn't ignore the rotor/brake appearance any longer longer...
I'm thinking that I've found the cause of my long time, occasional front tire rubbing. Turning hard into an incline for instance.
Sent from my moto g stylus (2021) using Tapatalk
The Following 4 Users Say Thank You to Greg Reid For This Useful Post:
  #210
Old 01-01-2024, 02:17 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Got windshield washing working on the 'Bandit' Suburban. The pump had quit, but it's part of the wiper motor assembly, which I didn't want to replace. A separate new pump ($10!) is ugly but functional.
  #211
Old 01-01-2024, 05:36 AM
BB70's Avatar
BB70 BB70 is offline
Block sanding the body shell. Sure wish I would have done this while it was on the rotisserie.
  #212
Old 01-01-2024, 01:58 PM
BILL BOWMAN1's Avatar
I bought a front end rebuild kit. Does that count as doing something?
The Following User Says Thank You to BILL BOWMAN1 For This Useful Post:
  #213
Old 01-01-2024, 05:12 PM
geeteeohguy's Avatar
Name:	A Arm OEM.jpg
Name:	DS A Arm.jpg
ID:	625828Installed the new A arm bushings on the '66 last month and removed the windshield to repair the channel. Ordered Air Lift air bags yesterday from Jegs to install in the rear springs. It's creeping along. Oh, a power steering gearbox rebuild kit is on the way. The box started leaking out of the input and sector shafts after I got it back on the road after 41 years. It was fine for the first few miles. The engine is still leak free....for now.
Jeff
  #214
Old 01-01-2024, 06:04 PM
67drake's Avatar
67drake 67drake is online now
I backed the GTO out of the shop this morning to bring the wife’s car in for brakes. If that counts, so does yours.
‘55 Catalina
  #215
Old 01-01-2024, 06:21 PM
68 Firebird's Avatar
68 Firebird 68 Firebird is offline
Default firebird
Took it out for a short ride and also top off gas tank.
Came back and changed oil and filter.
Finally installed new cap & rotor, she did run smoother!!
time to put her away for winter.
Gerry
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, GM HEI and Ram Air pans and RARE Long Branch Manifolds
  #216
Old 01-01-2024, 06:43 PM
Deal! 😀
  #217
Old 01-01-2024, 07:26 PM
bill ryder's Avatar
bill ryder bill ryder is online now
Pulled the cardboard out from underneath to look for drips after 6 months. Found none. Slid cardboard back underneath!!!! Hope that counts!!
"Bill"!
The Following User Says Thank You to bill ryder For This Useful Post:
  #218
Old 01-01-2024, 07:34 PM
carcrazy carcrazy is offline
Removed paint from a quarter panel on my 62 GP project car. Long way to go.
  #219
Old 01-04-2024, 07:28 PM
It's not a Pontiac, but a Buick. They're part of the BOP family.
Took the GN out today to run errands. We're supposed to get a bunch of snow this weekend, so I wanted to get it out. Put about 100 miles on it.
I'll have Pontiac updates soon!
1987 Grand National
The Following 4 Users Say Thank You to 72projectbird For This Useful Post:
  #220
Old 01-05-2024, 01:31 PM
wow that's sharp....
