Old 01-04-2024, 12:44 PM
dpoltzer's Avatar
dpoltzer dpoltzer is offline
Default 3M 05895 no longer available?
I need to repair some small cracks in my endura bumper on a 1970 FB. Apparently 3M does not make the 05895A &B kit that I have used in the past. Can someone recommend another product I can use? Maybe an SEM product? Thanks.
1970 T/A
Old 01-04-2024, 03:27 PM
dpoltzer's Avatar
Default 3M stopped Making 05895!
I called 3M and they no longer make the 05895A & B in tubes. Replaced with #05887 but you need a special applicator gun that costs more than the product! Anyone know of a "Work-A Round" for the applicator? Thx.
1970 T/A
Old 01-04-2024, 04:02 PM
Stuart's Avatar
Stuart Stuart is offline
I found one place that indicates on their website they still have the 05895 available, but you'd have to check with them to confirm. There may be other places. https://www.wotcotools.com/product/4...895-5-oz-tubes
Old 01-04-2024, 04:28 PM
dpoltzer's Avatar
Default OK thanks.
Thank for the link Stuart.
1970 T/A
Old 01-04-2024, 07:12 PM
nytrainer's Avatar
nytrainer nytrainer is online now
If you end up buying the 05887 I have the gun and have lent to others in the past. PM me if you need it
The Following User Says Thank You to nytrainer For This Useful Post:
Old 01-04-2024, 09:21 PM
Cammer-6 Cammer-6 is offline
last repair to Endura I did I used Lord Fusor
seems to be doing OK so far
But I normally use 3M products so would have to research why I made that choice
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 01-04-2024, 11:54 PM
The excellent 3m product that I used was changed to Bondo brand/packaging but it's the same stuff as far as I can tell. Not sure what the product number is now. It's been good for well over a decade.
Old 01-05-2024, 08:30 AM
dpoltzer's Avatar
Default Thanks everyone.
Heading to body shop supply today to see what they have. I will report back.
1970 T/A
Old 01-05-2024, 10:14 AM
78w72 78w72 is online now
I used the flexible SEMWELD 39708 product on my 72 endure nose, comes in 2 tubes that you mix up like JB weld, excellent product that applies nice & sands smooth & easy.
I was going to buy the 3m stuff but the auto paint supply store I went to only had the kind that needed the expensive gun, the rep suggested the SEM and said its just as good and can be used on other types of rubber/plastic too.
I used it to repair a small tear on a 78 nose too along with the mesh tape for added strength. Its lasted for 15+ years on the 78 and 7+ on the 72 with no signs of any problems. It was cheaper than the 3m too.
Old 01-05-2024, 12:05 PM
dpoltzer's Avatar
Default SEMWELD
Thanks for the alternative product recommendation! I will compare size and $ for the money.
1970 T/A
Old 01-05-2024, 01:47 PM
mrennie's Avatar
mrennie mrennie is offline
The Bondo version is slightly different than the 3M stuff and is harder to sand. If you didn't have both to compare, you wouldn't know any better, but the 3M stuff is better to work with IMO.
There is a cheaper twin cartridge gun for larger 300 mL twin cartridges, and if you buy one you can wrap the 3M tubes in a few layers of cardboard from your favorite canned beer case, it will sit in the gun OK and you can use those smaller cartridges.
I wasn't willing to spend $200 for the proper autobody twin tube gun, but $50 for the larger gun was OK for 2-3 uses.
Something like this one, intended for 300mL cartridges. The pushing pads won't be centered in the tubes but it will still work. I used the same gun to dispense 3M NVH foam as well as Norton epoxy seam sealer from the smaller tubes so I feel like it was a good choice.
Also, some parts supply houses (my local Napa is one), bought the proper gun and would lend it to customers who bought the smaller tubes from them. I am a slow worker (see sig ) so I wanted my own for when I needed it.
https://www.ebay.com/itm/28530579201...Bk9SR_iHwKubYw
As long as the repair product you buy is a flexible epoxy repair kit, it should be fine. I used 3M (both in tubes and cartridges), Bondo, and a Canadian product from Dominion Sure Seal. The 3M sanded the best, the Bondo was the worst, and the Sure Seal was noticeably softer than the others once cured and did not feather as well.
Michael
1970 Oshawa built 1 option Judge. 24 year restoration/upgrade project finally finished!
1979 Trans Am - low-buck drag car project for when I retire
Old 01-05-2024, 02:33 PM
turbo69bird's Avatar
Here’s what I’d use works well stays flexible. Use it in marine applications all the time. You will be amazed at this product. If you want a harder less flexible for something use 5200
960 HP @ 11 psi, 9.70 at 146.
Old 01-08-2024, 01:00 PM
VCho455's Avatar
VCho455 VCho455 is offline
How well does the 4200 sand? I've used 5200 at work but I've never had to sand it and it never gave me the impression that it was sandable.
Old 01-08-2024, 02:46 PM
dpoltzer's Avatar
Default 3M 05887
Purchased the 3M 05887 and borrowed applicator gun from a friend. Product worked well and I am pleased with results. Hope to apply paint this week. Thanks again everyone. Dave
1970 T/A
Old 01-08-2024, 06:08 PM
cnc's Avatar
cnc cnc is offline
Dave did u happen to take any pics of the process
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
Old 01-08-2024, 07:36 PM
dpoltzer's Avatar
Default No Pics
Sorry I did not take any pics. I will take some once I get the bumper installed.
1970 T/A
Old 01-08-2024, 07:45 PM
cnc's Avatar
cnc cnc is offline
Ok great
Old 01-08-2024, 08:29 PM
just a warning to all that all of the mentioned products have a shelf life.
I wouldnt buy if its over a few months old.
Also resist the temptation to use up what you bought 2 yrs ago.
Old 01-09-2024, 07:35 AM
dataway's Avatar
dataway dataway is offline
Is the 3M 05895 the product that was recommended by the often used "Endura Repair" sticky topic? The gray colored stuff that sands so well?
Old 01-09-2024, 10:33 AM
Can you elaborate on this shelf life? Are certain products more time sensitive than others?
Reason I ask is because the SEM product doesnt mention any expire or use by date. I bought & first used mine about 15 years ago, then used it again on the 72 endura nose 8-9 years later, it looked new and applied as new with excellent results that have lasted ~8 years with no issues at all. Also used it again a few years ago on some honeycomb wheels I restored. Still looks & works like it always has and I dont see any problems using it again in the near future.
Most of these 2 part products have a very long shelf life in my experience, definitely longer than a few months, never used the 3m or lord fusor so cant comment on them... but normal bondo fillers and JB weld etc should last for many years if stored right.
