So here’s something I have never heard discussed.
As you are watching the Christmas tree countdown are you revving the motor up with just the center carb or do you have all three open? Don
1966 GTO 1966 421-10.1-1 comp-Race Tec 23cc Pistons KRE Tri-Power KRE 65cc Aluminum Heads XE274 cam by Comp Cams DUR 230 Int 236 Exh @.050 - 110 LSA LIFT .491" Int .491" Exh Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers 1966 Muncie Wide Ratio 4-Speed 1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears |
Stick or Automatic?
K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.56 @ 139 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
Hi Keith,
Stick
I'm at 5600 RPM on the 2 step at WOT.
| The Following User Says Thank You to wolf For This Useful Post: | ||
Center carb. After the light goes green, it depends on the traction and power. What setup do you got?
It’s in my info below
I'd say nothing to worry about!
![]() But seriously, on any manual tripower's I've owned - even stock ones - holding the secondaries open with the clutch disengagaged would hit redline in no time.. |
| The Following User Says Thank You to elefantrider For This Useful Post: | ||
I hold the RPM at 2000. 2nd yellow from the bottom side step the brakes and nail the gas pedal.
Car info: 1962 Tempest 1961 389 Tri-power 700R4 transmission torque converter stall is 2200 Ford 9 inch 3.50 gears.
If you built it, drive it. red 62 Tempest total stock restoration. white 62 Tempest modified, 61 389 Tri-Power, and a conventional drive train. |
| The Following User Says Thank You to Radman For This Useful Post: | ||
