Old 02-10-2024, 11:12 AM
phil400's Avatar
phil400 phil400 is offline
Default Wix 51258 Discontinued
As the title says, According to summit, so I assume the Napa gold 1258 is also, as well as the Wix 51042 A freind of mine was running that one with Hedman headers not sure what a guy is gonna do now.
78 T/A 4SPEED, Original paint, match #’s, stock original bottom end, milled 6x-4s, HE268H cam,17058263 Q-jet/ 72 jets, CH secondary rods, RA Manifolds, poly body bushings, Moroso SFCs, 3rd and last owner since ‘99, as long as I'm alive.
79 Parisienne originally 305 2bbl now 87 350 tbi swap, 193 heads, performer, Q-jet, headers
77 t/a sold
85 Monte Carlo SS sold
83 Mustang GT sold
The Following User Says Thank You to phil400 For This Useful Post:
Old 02-10-2024, 11:36 AM
64speed's Avatar
64speed 64speed is offline
PBL25288 is the American made small body purolator number. Baldwin B39
Old 02-10-2024, 11:44 AM
Steve C. Steve C. is offline
Consider the NapaGold 1045 Oil Filter (Wix 51045) it is smaller.
https://www.wixfilters.com/Lookup/Pa...px?Part=153657
Old information here:
Old 02-10-2024, 12:07 PM
Cliff R's Avatar
Cliff R Cliff R is offline
+2 for the Baldwin B39.
Slightly shorter than most of the others for additjonal header clearance, full flow, quickest repsonse on the gauge and you can block the bypass in the filter housing with no negatives anyplace........
Old 02-10-2024, 12:13 PM
PAUL K's Avatar
PAUL K PAUL K is offline
The good news is Wix didn't discontinue the SBC tall truck filter. They still offer that filter, it's just the same size as the standard SBC filter. 🙄
Go fast, see Elvis!
Old 02-10-2024, 12:32 PM
78w72 78w72 is offline
rock auto shows lots of 51258 filters available. if they are really discontinued y'all better buy a bunch of them before they are gone.
There are lots of other standard size good filters that will fit pontiacs with headers... ive been using the mobil1 filter that fits with hedman D ports & big 2" O-port hooker super comps.
Old 02-10-2024, 12:56 PM
Mr_GTO's Avatar
Mr_GTO Mr_GTO is offline
https://www.amazon.com/Wix-51258-Spi...A1UT4CS4MVANP0
Old 02-10-2024, 12:59 PM
ZeGermanHam's Avatar
Yikes, thanks for the heads-up. Just bought a case of 12 in case the rumor is true. That said, I'm still seeing them in stock at O'Reilly.
1998 BMW 328is (track rat)
Old 02-10-2024, 01:07 PM
Originally Posted by Mr_GTO View Post
$102 for 12 wix filters? Thats almost double what they cost at RA! Can buy 12 of these filters at rock auto for $57 + $11 shipping... & thats not with the 5% discount code. Hope nobody buys them from amazon!
Old 02-10-2024, 01:22 PM
Yep, they're $4.81/ea on Rock Auto. Great deal. What's nuts is that they cost $12.99/ea at O'Reilly. Wild.
Old 02-10-2024, 02:27 PM
gtokid1968's Avatar
gtokid1968 gtokid1968 is offline
Whats the rock auto discouny code????
Going to buy a dozen !
Old 02-10-2024, 02:52 PM
Jim Moshier's Avatar
+3 for the Baldwin B39
Jim Moshier
1962 Catalina 389
The Following User Says Thank You to Jim Moshier For This Useful Post:
Old 02-10-2024, 03:43 PM
Cammer-6 Cammer-6 is offline
when storing them for a long time be aware they will rust inside.
Keep in a humidity controlled environment
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
The Following 2 Users Say Thank You to Cammer-6 For This Useful Post:
Old 02-10-2024, 04:58 PM
https://www.fleetfilter.com/SRCH.html
1258 for $6.40 each case of 12
Save 10% $125 orders.
Save 20% $200 order.
Get together with your friends and buy whatever you need to stock up for all your vehicles and get the best discount and make the shipping cost worth it.
Old 02-10-2024, 06:08 PM
65 Lamnas's Avatar
65 Lamnas 65 Lamnas is online now
I just ordered 6 from Rock Auto with my discount code...4.81 each. Rock Auto Discount code is good til March. 257708170227572024
Old 02-10-2024, 06:20 PM
gtokid1968's Avatar
Thanks for posting the code!
Old 02-10-2024, 07:30 PM
max 93 max 93 is offline
Where is a good place to get the Baldwin filters?
Old 02-10-2024, 07:37 PM
65 Lamnas's Avatar
Google says https://www.baldwinfiltersrus.com/ba...hoCEyQQAvD_BwE
Old 02-10-2024, 09:05 PM
64speed's Avatar
Amazon is where I buy baldwin
Old 02-10-2024, 11:55 PM
rwfisher's Avatar
rwfisher rwfisher is offline
Fleet Filter still shows as stocked item.. I got a case from them a few weeks ago so they’re still shipping…..
