Old 02-15-2024, 02:30 AM
I like that 3spd Tempest.
Old 02-15-2024, 07:38 PM
69 Firebird convertible with wire hubcaps at $2500 with reserve not met in Minnesota. I have a set of wire for my 69 Firebird. They fit into a 14 X 7 inch Rally II, which I have on the car, so I can mix it up when I want to change the look. I also have a set of 14" honeycombs for it. Best looking wheel Pontiac ever made IMO, and the 14" ones were 71 and 72, so while not factory correct, a very cool look.
https://www.ebay.com/itm/32601181011...Bk9SR7qKvvG1Yw
  #3943
Old 02-15-2024, 09:26 PM
68 Lemans at $28.5K NR in Ohio. Nice car, but that too high air cleaner bolt is looking to put a dent in that hood.
https://www.ebay.com/itm/16659974752...Bk9SR8CKvvG1Yw
  #3944
Old 02-15-2024, 09:32 PM
Wow...love that one.
Old 02-19-2024, 08:14 PM
I know we've seen this one before, but I never tire of it. The interior pic with the steering wheel and stacked gauges is pretty much it when it comes to the rare options. 1969 Trans AM with 52K miles at $175K in Texas.
https://www.ebay.com/itm/30540478116...Bk9SR6Tlm724Yw
  #3946
Old 02-19-2024, 08:20 PM
72 GTO in SD at NR $4500. No engine or transmission, so it being a "real 455HO WW5" car means a lot less, though it does say the hood has the Ram Air pan, but no pic. This car is a money pit from the word go, but if this is "the" one you've been looking for, prolly worth it. Has a 10 bolt.... I would have guessed a 12 bolt. The Monte Carlos had 12 bolts.
https://www.ebay.com/itm/37526515003...Bk9SR6jlm724Yw
[IMG]https://i.ebayimg.com/images/g/***AAOSwTAxl0sfJ/s-l1600.jpg[/IMG]
  #3947
Old 02-19-2024, 08:29 PM
71 GTO 4-speed in AZ at a very reasonable $24K NR. Nice car with 50K miles and NM. Note how they didn't screw it up by putting a wing on it. It looks so much better in stock form.
https://www.ebay.com/itm/20465909620...Bk9SR6jlm724Yw
  #3948
Old 02-19-2024, 08:36 PM
That 69 is sweet with Tach & Stack
Maybe the snow states didn't always want Posi rear.
Built in late October 69 = Cool
That 72 WW5 is a sore sight .
Appears the driver quarter is going to be worse than pass side quarter.
Even the 12 bolt is gone
  #3949
Old 02-19-2024, 08:40 PM
79 Trans AM in Pennsylvania at NR $10K. Ad says the previous owner had $50K invested in it. Looks like an Olds engine, but the ad says nothing about what it is. Cars like these were the absolute bomb in the late 70's and early 80's. Big fat tires with Centerlines tucked under tubs with a Dana rear end and 4:11 gears. Add a roll bar and a lot of suspension parts plus those super heavy cushy seats and go cruzin'. Lots of money in this car, but mostly in parts. It does look good.
https://www.ebay.com/itm/26668144262...Bk9SR6rlm724Yw
  #3950
Old 02-19-2024, 08:49 PM
I thought a posi was standard on a 69 Trans AM?
  #3951
Old 02-20-2024, 12:20 AM
I think you are right absolutely right Thews .
It was the R2 wheels and 4spd/Auto Trans choice that didn't come standard in 69
Like they did for 2nd gen
  #3952
Old 02-20-2024, 07:09 PM
69 GTO Judge shell in SC at $13.5K. Lots of rust and missing everything.
https://www.ebay.com/itm/11607438312...Bk9SR8Svooy5Yw
  #3953
Old 02-20-2024, 07:13 PM
78 Y88 stick T/A in NJ at $10K OBO. Looks like it's complete.
https://www.ebay.com/itm/17624918872...Bk9SR8Kvooy5Yw
  #3954
Old 02-20-2024, 07:27 PM
tom s tom s is offline
The blk stripes on the white convert looks like they were painted with a broom!Tom
  #3955
Old 02-22-2024, 03:57 PM
Yes, that’s correct
  #3956
Old 02-23-2024, 12:18 AM
Default 74 TA
https://www.ebay.com/itm/37526799385...=&toolid=10049
Sus comments and noflakes for some reason...
  #3957
Old 02-24-2024, 09:46 PM
67 Firebird 400 in NJ at BIN $17.5K. Says it's numbers matching.
https://www.ebay.com/itm/13495155003...MAAOSwY8Bl2nlp
  #3958
Old 02-24-2024, 10:23 PM
That's my kind of project car right there. I like it.
  #3959
Old 02-25-2024, 06:42 PM
Wow! 70 GTO 455 4-speed at $2500 NR Idaho. Poverty caps on this car don't work at all.
https://www.ebay.com/itm/12634875534...Bk9SR9Li1Ka8Yw
  #3960
Old 02-26-2024, 08:16 PM
SD455DJ SD455DJ is offline
"Wow! 70 GTO 455 4-speed at $2500 NR Idaho. Poverty caps on this car don't work at all."
Nor do the backward Judge stripes on the rear quarters!
Dennis
