Old 02-25-2024, 07:11 PM
Verdoro 68's Avatar
Got more work done on the run stand.Getting close.
What are the specs on that one? Always curious to see what you’re cooking up.
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around)
  #302
Old 02-25-2024, 07:19 PM
tom s tom s is offline
455,WT 69 block,6.8 rod 3 in main 4.21 stroke.SM heads OF.Tom
The Following 3 Users Say Thank You to tom s For This Useful Post:
  #303
Old 02-26-2024, 10:48 AM
MUCHMETAL's Avatar
MUCHMETAL MUCHMETAL is offline
Default 55 Chieftain 2-dr Wagon
A little info on the current project:
1955 Chieftain 2-dr Wagon
- .30 over 428 (Thanks to Brewster for selling me the 428)
- Muncie M20 4-speed
- C4 front and rear suspension grafted onto wagon frame
- Paint will be left as-is for now, but may change after up and running
Last night, test fit the body back on the frame to check for fit and/or interferences. A couple areas of concern but nothing major. While body is on the frame, will measure and mark additional areas of firewall that need to be trimmed for clearance and for symmetry. Setback for the firewall will need to be in the neighborhood of 4”. Also installed, with some modifications, the 57 Chevy brake/clutch pedal assembly and test fit the new tilt steering column to figure out the connection between it and the C4 intermediate shaft, which turned out to be fairly simple.
A few additional build pics in the PY album:
55 Chieftain (https://forums.maxperformanceinc.com...p?albumid=2024)
Tony
1998 GOLD Pontiac Firebird Formula HT, M6
1968 Pontiac LeMans Convertible
1968 Pontiac Lemans HT - Frame-off restomod with LS1 transplant
1955 Pontiac Chieftain - 2 Dr Wagon - Newest project
2008 Chevy Silverado 4X4 - Daily driver
The Following 4 Users Say Thank You to MUCHMETAL For This Useful Post:
  #304
Old 02-26-2024, 12:29 PM
KS circutguy's Avatar
Thumbs up
Originally Posted by VCho455 View Post
Somers Automotive Machine. We've used Archie almost exclusively for over 20 years for machine work. (Did my OHC 6) We have him do the machine work and we assemble them ourselves. Once he's done with the heads we'll have the short block ready and then we'll have it dynoed at his shop.
He's a bit grumpy but the work is always on time and done right. He has a lot of regular customers who race for points so sometimes it may take a bit longer but he lets you know up front how long to expect.
Yep,I've used Archie for 30 years and turned many on to him for machine work.
"There's nothing more unsatisfying than watching an electric car go down the dragstrip."
  #305
Old 02-26-2024, 12:40 PM
I knew those Accel Super coils were good for something.
Nice work.
  #306
Old 02-26-2024, 03:07 PM
I never use it,owner of the run stand has it mounted on it.Tom
  #307
Old 02-26-2024, 03:47 PM
Verdoro 68's Avatar
What intake is that? The support from the heat cross over doesn't look familiar to me.
Ken
  #308
Old 02-26-2024, 03:49 PM
mgarblik mgarblik is offline
It is an incredible 66 degrees and sunny here today in Dayton, OH Started and warmed-up the 62 Catalina today in the garage. Let it run about 1/2 hour. Miss the sound of the solid lifter Pontiac engine during the dreary months. Wanted to go out for a drive but still 1/4" of salt on all the roads here from the couple inches of snow we had just 2 days ago!
  #309
Old 02-26-2024, 03:50 PM
VCho455's Avatar
VCho455 VCho455 is offline
Picked up this 389 a while back for my Suburban. Took the top end off to swap heads and check things out inside. Everything looked as expected except the water pump. With that stamped impeller and what looked to be .250 plus of impeller clearance the pump probably didn't move much water. Time to start digging through the stash and see if I can find an late 11 bolt impeller and get it to fit this early pump.
ID:	629402   Click image for larger version
ID:	629403   Click image for larger version
ID:	629405   Click image for larger version
ID:	629406   Click image for larger version
  #310
Old 02-26-2024, 05:24 PM
BILL BOWMAN1's Avatar
Test fit lower control arm, took a little massaging to get back in with new bushings as expected. Had to spend the majority of the day in the yard spring cleaning, mainly those 80 trillion Sweet Gum monkey ball thingies- nastiest trees on the planet!
  #311
Old 02-26-2024, 06:06 PM
The intake is a 1962-1963 421 SD NASCAR intake.I had Dave at SD rework the ports to match late heads,used a water Xover from a alu intake.Pretty much a RAIV-455HO intake for a AFB carb.Tom
  #312
Old 02-29-2024, 07:03 PM
Shiny Shiny is offline
Started the car today for the first time in a couple months. I was happy it fired right up after gas finally made it to the carb.
Battery had run down before so I checked the voltage and heard "no Mike, the alternator is not working" inside my head.
One of those good, bad, good, bad things. Hopefully it will be easy to figure out and correct.
  #313
Old 02-29-2024, 07:05 PM
Verdoro 68's Avatar
I knew there had to be something cool about that seemingly ordinary combo!
Ken
  #314
Old 03-03-2024, 04:47 PM
67drake's Avatar
67drake 67drake is offline
Record temperatures here in SW Wisconsin today. Above 70 right now. Tired of working of stuff, and my GTO looked sad and dusty. My son has his learners permit and needs to learn how to shift a Muncie! Add all that up and I DROVE my Pontiac today. Pretty rare I get to sit in the passenger seat!
It’s running great. Burned about 1/4 tank off then filled it up with some fresh non ethanol gas.
ID:	629746   Click image for larger version
ID:	629747   Click image for larger version
13.95 @ 102.1 on street tires @ 4055lbs.
The Following 3 Users Say Thank You to 67drake For This Useful Post:
  #315
Old 03-03-2024, 09:27 PM
67drake's Avatar
And then threw my new center link in.
The Following 2 Users Say Thank You to 67drake For This Useful Post:
  #316
Old 03-04-2024, 12:46 PM
[QUOTE=67drake;6489959]Record temperatures here in SW Wisconsin today.
Lookin' confident behind the wheel... 👍
  #317
Old 03-04-2024, 01:13 PM
Verdoro 68's Avatar
Awesome! It's a funny feeling being in the passenger seat, isn't it?
How'd he do with the Muncie? My son is still trying to figure out the 6 speed on the T/A. At the rate he's currently learning, I may need to start shopping for a clutch.
Ken
  #318
Old 03-04-2024, 02:48 PM
67drake's Avatar
He did OK. Grew up riding dirt bikes, so familiar withthe idea behind feathering the clutch, but throw in an old original worn out shifter and it can be challenging. He was a little nervous about down shifting into reverse, but assured him that ain’t gonna happen unless he really tried.
  #319
Old 03-04-2024, 10:21 PM
ReelFun's Avatar
ReelFun ReelFun is offline
Replaced the throwout bearing.
1965 GTO
389 Tri-Power
4-Speed
Johnny
The Following User Says Thank You to ReelFun For This Useful Post:
  #320
Old 03-05-2024, 09:03 AM
form74's Avatar
form74 form74 is offline
Pulled the cover off the Formula opened the hood to see the empty engine bay.
Got some work to do before the new motor is ready
ID:	629885   Click image for larger version
74 Formula
Below motor destroyed last fall
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
New motor
461 stroker
Edelbrock 87 cc dport heads
Performer RPM
Results will be posted after the track
The Following 2 Users Say Thank You to form74 For This Useful Post:
