#401
Finished up the TH400 and went to install the deep pan just to find out it's not deep enough....smfh
#402
Not today... but.... Bought this yesterday.. When I got it home I did a wheel/tire swap as the Radial T/A's that were on it were 40 years old.... and I washed it too.. Now its at my shop changing all fluids and doing some rear brake work.
Current Pontiacs -1973 Formula SD455 - #'s auto orig paint 1972 Trans Am - 4 speed orig paint 1966 2+2 convertible - 421 4bbl automatic 1967 Grand Prix - 4 speed orig paint 1967 GTO - 4 speed orig paint 35k orig miles |
#403
Catalina- test fit the centerlink , tie rods , and idler arm.. just finger tight, got steering wheel centered and wheels eyeball straight. Can now tighten it all down for good. Need to order new Addco sway bar , and front end should be complete.
LIFT HEAVY, LIFE IS TOO SHORT TO BE SMALL! |
| The Following User Says Thank You to BILL BOWMAN1 For This Useful Post: | ||
#404
I went to the auto parts store and bought weatherstrip adhesive.
" Is wearing a helmet illegal" Mike Kerr 1-29-09 |
#405
Replaced dinky radiator overflow bottle with a gallon sized unit.
#406
This one fits....
#407
Changed plugs and coil in the 69 bird.Waiting for me carb guy to come over and trouble shoot.Tom
#408
Cleared all the parts out that I was storing in the trunk that I’m sorting through now to make an attempt to move forward.
Installed the new reproduction trunk mat and the spare, pretty sure I bought the mat from Bill Ryder here on the forums several years back. One less box on the shelf so that’s a win in itself. ![]() Also put the fiberboard spare tire cover on it that I found in the trunk of one of my cars years ago, maybe from a ‘69 GP I’m not sure.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
| The Following User Says Thank You to b-man For This Useful Post: | ||
#409
Just got an Email from Addco, your sway bar is on back order until 4/27. I really thought I was gonna be done with this front end in a couple days!! Glad I didn’t toss the old one yet. Doing a quickie cleanup and paint job on the old one..
#411
Installed a new alternator. On the last drive of the season last year, I noticed my voltage was low. It was just below 13 on my gauge. I was pretty sure it was bad so I ordered a new one last week from Summit. I fired the car up today and the alternator was only putting out 13.2 volts on my meter so I swapped it out. The post for the power cable on the back was loose.and it rotated when I tried to remove the nut. So I had a little struggle getting it off and broke the connector/terminal off in the process. Had to run out and get a new one since I didn't have any that would work. Now I need to find someone to rebuild my original 70 alternator which I'll put back in.
#412
Its easy to repair your own.. Service manual explains how.
Numerous vendors out there selling the parts. The only special tool you'll need is a toothpick. https://store.alternatorparts.com/gm...pair-kits.aspx
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2015 Chevy Express ![]() 2024 Cadillac LYRIQ |
| The Following User Says Thank You to OG68 For This Useful Post: | ||
#413
| The Following User Says Thank You to jhein For This Useful Post: | ||
#414
finally ordered my much needed center link, tie rods, and new borgensen unit...I guess I won't be getting a new cell phone anytime soon #carpoor
Esquire '74 T/A 455 Y-code SD clone previously on Dawson's Creek: '74 T/A 400 '81 AMC SX/4 '69 FB 350 |
#415
#416
Drove the 57 wagon yesterday wile the weather was nice.
Don't seam to get very nice day's yet so when it's nice out I fire it up and drive around a bit. I'll get pics up soon. GT |
| The Following User Says Thank You to blueghoast For This Useful Post: | ||
#417
Installed seats and carpet today... door panels tomorrow.
I am not a fan of color changes... but I did it the right way.. The white interior was pretty nasty..... though it did have that cool old T/A smell ... I kept all of the original white interior pieces so it can be put back original. All of the hard plastic interior panels I installed are OEM and molded in black.. not recolored. Installed new black seat covers as well. Only thing I recolored was the headliner using SEM products. I do like the car a lot better with black interior.
#418
Looks good
#419
I love this time of year especially after one of our long boring winters!
Picked her up from the storage barn today and started without too many cranks. They haven't cleaned the salt from the streets here yet but I had to get her early to get a jump on the loosey goosey steering upgrades...coming soon
| The Following User Says Thank You to kingbuzzo For This Useful Post: | ||
#420
always had issue with the airhorn gaskets on all 3 TriPower carbs oozing/getting wet with gas. My fuel pump is pushing out 6psi. I ordered the regulator kit from John at pontiactripower.com.
There was NO good place to install it. I had to make a bracket to hold the regulator. Not a lot of room to install it with the pressure gauge and filter. Haven't had a chance to run it yet because of the crappy wet weather. It does register a little over 3# now just cranking over in my garage. I can see the gauge sitting in the drivers seat with the hood open. |
