Old 03-25-2024, 07:11 PM
65 Lamnas's Avatar
Finished up the TH400 and went to install the deep pan just to find out it's not deep enough....smfh
  #402
Old 03-25-2024, 08:33 PM
Not today... but.... Bought this yesterday.. When I got it home I did a wheel/tire swap as the Radial T/A's that were on it were 40 years old.... and I washed it too.. Now its at my shop changing all fluids and doing some rear brake work.
  #403
Old 03-28-2024, 05:21 PM
BILL BOWMAN1's Avatar
Catalina- test fit the centerlink , tie rods , and idler arm.. just finger tight, got steering wheel centered and wheels eyeball straight. Can now tighten it all down for good. Need to order new Addco sway bar , and front end should be complete.
The Following User Says Thank You to BILL BOWMAN1 For This Useful Post:
  #404
Old 03-28-2024, 09:29 PM
4dblnkldude's Avatar
I went to the auto parts store and bought weatherstrip adhesive.
  #405
Old 03-29-2024, 02:00 AM
Replaced dinky radiator overflow bottle with a gallon sized unit.
  #406
Old 03-29-2024, 04:32 PM
65 Lamnas's Avatar
This one fits....
ID:	631311   Click image for larger version
ID:	631312   Click image for larger version
ID:	631313   Click image for larger version
ID:	631314   Click image for larger version
  #407
Old 03-29-2024, 06:49 PM
tom s tom s is offline
Changed plugs and coil in the 69 bird.Waiting for me carb guy to come over and trouble shoot.Tom
  #408
Old 03-29-2024, 07:23 PM
Cleared all the parts out that I was storing in the trunk that I’m sorting through now to make an attempt to move forward.
Installed the new reproduction trunk mat and the spare, pretty sure I bought the mat from Bill Ryder here on the forums several years back. One less box on the shelf so that’s a win in itself.
Also put the fiberboard spare tire cover on it that I found in the trunk of one of my cars years ago, maybe from a ‘69 GP I’m not sure.
ID:	631317   Click image for larger version
ID:	631318   Click image for larger version
ID:	631319   Click image for larger version
  #409
Old 03-29-2024, 08:43 PM
Skidmark's Avatar
Skidmark Skidmark is offline
Attachment 631034
I don't know how you do it, but you continue to find some of the best Pontiacs out there.
  #410
Old 04-01-2024, 05:13 PM
Just got an Email from Addco, your sway bar is on back order until 4/27. I really thought I was gonna be done with this front end in a couple days!! Glad I didn’t toss the old one yet. Doing a quickie cleanup and paint job on the old one..
  #411
Old 04-01-2024, 07:35 PM
jhein's Avatar
jhein jhein is offline
Installed a new alternator. On the last drive of the season last year, I noticed my voltage was low. It was just below 13 on my gauge. I was pretty sure it was bad so I ordered a new one last week from Summit. I fired the car up today and the alternator was only putting out 13.2 volts on my meter so I swapped it out. The post for the power cable on the back was loose.and it rotated when I tried to remove the nut. So I had a little struggle getting it off and broke the connector/terminal off in the process. Had to run out and get a new one since I didn't have any that would work. Now I need to find someone to rebuild my original 70 alternator which I'll put back in.
  #412
Old 04-01-2024, 09:12 PM
OG68 OG68 is offline
Its easy to repair your own.. Service manual explains how.
Numerous vendors out there selling the parts. The only special tool you'll need is a toothpick.
https://store.alternatorparts.com/gm...pair-kits.aspx
  #413
Old 04-02-2024, 09:38 AM
jhein's Avatar
Thanks for that. I'll be ordering a kit. Which is funny, their kit costs more than the alternator that I bought. LOL.
The Following User Says Thank You to jhein For This Useful Post:
  #414
Old 04-02-2024, 11:52 AM
finally ordered my much needed center link, tie rods, and new borgensen unit...I guess I won't be getting a new cell phone anytime soon #carpoor
Been chipping away at this.
  #416
Old 04-02-2024, 06:04 PM
blueghoast's Avatar
Default 57-wagon
Drove the 57 wagon yesterday wile the weather was nice.
Don't seam to get very nice day's yet so when it's nice out
I fire it up and drive around a bit. I'll get pics up soon.
GT
The Following User Says Thank You to blueghoast For This Useful Post:
  #417
Old 04-06-2024, 07:08 PM
Installed seats and carpet today... door panels tomorrow.
I am not a fan of color changes... but I did it the right way.. The white interior was pretty nasty..... though it did have that cool old T/A smell ... I kept all of the original white interior pieces so it can be put back original. All of the hard plastic interior panels I installed are OEM and molded in black.. not recolored. Installed new black seat covers as well. Only thing I recolored was the headliner using SEM products. I do like the car a lot better with black interior.
  #418
Old 04-06-2024, 11:14 PM
Looks good
Old 04-06-2024, 11:42 PM
Default Spring has sprung....
I love this time of year especially after one of our long boring winters!
Picked her up from the storage barn today and started without too many cranks. They haven't cleaned the salt from the streets here yet but I had to get her early to get a jump on the loosey goosey steering upgrades...coming soon
ID:	631692   Click image for larger version
  #420
Old 04-07-2024, 08:40 AM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
Default fuel pump issue hopefully resolved
always had issue with the airhorn gaskets on all 3 TriPower carbs oozing/getting wet with gas. My fuel pump is pushing out 6psi. I ordered the regulator kit from John at pontiactripower.com.
There was NO good place to install it. I had to make a bracket to hold the regulator. Not a lot of room to install it with the pressure gauge and filter.
Haven't had a chance to run it yet because of the crappy wet weather.
It does register a little over 3# now just cranking over in my garage. I can see the gauge sitting in the drivers seat with the hood open.
ID:	631701   Click image for larger version
ID:	631702   Click image for larger version
