Can someone tell me if on the core support there is a nut welded in the hole for this hood stop stud or is it a push in speed nut like the one pictured? I am thinking I may have a aftermarket support because I only have a hole and no sign of broken welds. 66 GTO
I hope this is what you are looking for? The rubber bumper?
https://forums.maxperformanceinc.com...1&d=1712956860
Fort Worth/Dallas TX area 1966 GTO Fontaine Blue 389 CID Carter AFB Muncie 4 speed (orginally an automatic car) |
I do know what they look like and where they go. I need to know if what they go into has a welded in nut or if it has a clip sort of like the pic. I posted. My hole is just a hole without a thread to screw these into.
I wish I could help you, but my car is a 67 and it is locked up in a building at our local Fair Grounds for a car show. I can look tomorrow morning and report back tomorrow evening if no one else chimes in. I am pretty sure it is a welded nut.
I'm thinking you may be right but please let me know for sure though. You wouldn't happen to be at the Spokane Washington show by any chance?
Just checked two supports, at a glance the underside
looks like a common nut with no weld to be seen. But there's a circular parting line on the topside, so the nut appears to be a weld nut? |
Thank you. And of course a person would never find a nut kike that. Looks like it's time for a riv nut.
No, I am in Leesburg, Georgia. And, the nut is definitely welded to the underside of the core support. I can't get a picture of it, but I was able to run my hand up under and feel it. There was no cage around it, just the nut. There is a jam nut on the threaded hood bumper that tightens it up once adjusted.
Remember no one is perfect. Everyone's butt has a crack in it! Last edited by fyrffytr1; 04-13-2024 at 10:33 PM. |
The Following User Says Thank You to fyrffytr1 For This Useful Post: | ||
I think this is what you are looking for, at least itīs what i have seen used on an original 1966 GTO core support:
https://www.amkproducts.com/bulk-fas...forlookup=7135 |
The Following User Says Thank You to Kenth For This Useful Post: | ||
I was sure hoping it wasn't a weld in.
X2 on OE being welded.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. ![]() |
Oh well. I installed riv nuts yesterday. That's what you do when some idiot don't weld a nut on backside.
The Following User Says Thank You to 1950Mercury For This Useful Post: | ||
You do what you gotta do!
