SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference.
Old 05-03-2024, 06:28 AM
er455 er455 is offline
Default 1972 STD BORE 400 BLOCK
This 1972 block was honed years ago and is a std bore 2 bolt block that is not drilled for 4 bolt main caps , these blocks that are not drilled are much stronger in the main cap area because the xtra hole that are drilled take material away from the main saddles , would be a great stroker build, Hard to find a std bore block these days $800 pick up only in central Fl 34442
Old 05-03-2024, 06:30 AM
Default 400 block
here are some pics
ID:	633115   Click image for larger version
Old 05-04-2024, 05:19 PM
650.00
Old 05-05-2024, 02:33 PM
prostreet64's Avatar
prostreet64 prostreet64 is offline
650.00
PM sent.
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car.
79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.60 @ 126 so far...
Old 05-07-2024, 05:58 AM
Default 72 STD BORE BLOCK
650.00
600.00 pick up only in central Fl 34442
Old 05-12-2024, 09:04 AM
Default Block
SOLD
