Old 06-14-2024, 09:26 PM
cnc's Avatar
cnc cnc is offline
Default Coat hook
In my 73 I have the rear coat hooks …I also have the shoulder belts that are wrapped up and are placed up against the headliner …can someone with a 73 post a pic for location. I’ve just installed my new headliner cardboard backed into the car and just looking for verification on install…for the rear hooks …I may also be looking for one hook …my son made one for me with a mold from the original so not sure how the copy will work…thanks
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
Old 06-17-2024, 12:32 PM
I'm interested in this as well, since I am switching over from a bow-type to the cardboard type.
I suspect they would be in the same location as the bow-type though.
Old 06-17-2024, 06:09 PM
cnc's Avatar
cnc cnc is offline
U have a pic of one installed with the bow type
Old 06-17-2024, 07:50 PM
SD73's Avatar
SD73 SD73 is offline
Here's each side. It looks like they very a bit from side-to-side so be sure to find the screw hole before you install.
ID:	635493   Click image for larger version
Old 06-17-2024, 08:25 PM
cnc's Avatar
cnc cnc is offline
Hmmm perfect thanks I need to take that upper trim off and get some of those clips to attach to the roof think theres 3 a side there the white clips that twist into the trim then get pressed into the roof need to find them locally…appreciate the pics
Old 06-17-2024, 08:31 PM
SD73's Avatar
No problem. I think the last time I got some of those clips Autozone had them. They're still pretty common.
Old 06-18-2024, 01:07 PM
Excellent, thank you SD73!
