Old 07-01-2024, 05:01 PM
beemergary's Avatar
Default Alternator gets hot fast
Getting real hot right after start up. Took apart and bearings seem fine and greasy. I did grease them awile back. Its a converted to one wire on street strip car that's mostly strip. Thanks.
Old 07-01-2024, 05:31 PM
DO you have a voltmeter installed?
Might be overcharging making it hot?
Old 07-01-2024, 06:06 PM
Bill Hanlon's Avatar
"Converted" how?
Old 07-01-2024, 08:54 PM
beemergary's Avatar
Originally Posted by Bill Hanlon View Post
"Converted" how?
No more external voltage regulator connected to nuke things. 1963 everything is still there but looks stock but internal vg and only one working wire.
Old 07-01-2024, 09:18 PM
george kujanski's Avatar
narrow Belt running down in the bottom of the groove? saw one of those once. Also It may only get hot really quickly if it was outputting into a very high load at low alt shaft speed.. original fan on the alt?
george
Old 07-01-2024, 09:54 PM
So you installed an alternator that was designed to be 1 wire.
I'd start where John Wallace suggested. Check the alternator output voltage a minute or so after starting.
It would also be interesting to know how many amps the alternator is putting out a minute or so after starting. I keep an old under-dash ammeter with about 2 foot long wires with alligator clips on the end as a troubleshooting tool. Disconnect the "one wire", clip one wire of the ammeter to the "one wire" and the other ammeter wire to the stud on the alternator. Start the car leaving all electrical thingies turned off, goose the throttle once to get the alternator charging and read amps after a minute. Should be less that 10 amps, probably less that 5.
Old 07-01-2024, 10:09 PM
beemergary's Avatar
Its an original converted to a 1 wire. Its a 63 tempest an all the power goes thru the amp meter first. Nuked a few so its bypassed (I do miss it). I shoulda at least checked the voltage before removing. I'll take your advise. thanks
Old 07-02-2024, 10:06 AM
Bypassing the ammeter because you "nuked a few" is like putting lipstick on a pig. Problem still exists.
Old 08-08-2024, 04:03 PM
69gp400's Avatar
69gp400 69gp400 is offline
check the battery terminals make sure they are tight and clean sometimes the obvious gets the better of us
Old 08-09-2024, 12:41 PM
stellar stellar is offline
Got any pics of the alternator? I'd like to see an original 1963 alternator converted to one wire. It's probably a latter model alternator that has been converted.
Old 08-10-2024, 01:54 PM
Peter Serio's Avatar
Default Sensor wire on a 10-SI internal regulator alternator
Just my opinion but a 10-SI alternator with the "sense" wire routed right over to the output lug is NOT the way to wire a passenger car alternator.
A good way to wire it is shown in this example:
Name:	10SI Delco alternator wiring diagram_with light blub_B.jpg
Peter Serio
Owner, Precision Pontiac
Old 08-10-2024, 05:12 PM
dataway's Avatar
dataway dataway is offline
If everything else looks fine ... belt slippage can heat it up fast if it's under a lot of charging load.
Old 08-10-2024, 07:11 PM
Belt slippage due to too narrow of a belt or loose belt will heat up the alt core from belt friction and poor cooling due to the alt fan not moving enuf air relative to electrical output level.
George
