Old 01-27-2024, 11:53 AM
Stan Weiss's Avatar
Hi Stan,
That was at 28.1lb peak boost.
Thanks. When you get the tuneup fully dialed in. How much boost will you be able to run?
Stan
Pontiac Pump Gas List
  #2062
Old 01-29-2024, 12:16 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Stan
Not sure at this point when additional boost won't make more power. We still have timing to play with too.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #2063
Old 01-30-2024, 06:55 PM
cgeise's Avatar
cgeise cgeise is offline
Hub Dyno Session last December, EGT's looking a bit on the hot side.
to small to read
  #2064
Old 02-09-2024, 09:19 PM
RAIV-Z's Avatar
Picked up some 91mm turbos and wastegates from Rodney Butler. Possible addition sometime in the 2024 season.
Comparison based on timeslips and http://www.wallaceracing.com/Calculators.htm racing calculator.
Raven 1/4 Mile 7.34 @ 194.32 3650lb
Your HP computed from your vehicle ET is 1,637.63 rear wheel HP and 1,819.59 flywheel HP.
Your HP computed from your vehicle MPH is 1,881.22 rear wheel HP and 2,090.25 flywheel HP.
Rodney Butler 6.278 @228.11 2720lb
Your HP computed from your vehicle ET is 1,950.37 rear wheel HP and 2,167.07 flywheel HP.
Your HP computed from your vehicle MPH is 2,267.76 rear wheel HP and 2,519.73 flywheel HP.
Name:	2024-02-08 17.14.36.jpg
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
The Following 2 Users Say Thank You to RAIV-Z For This Useful Post:
  #2065
Old 06-08-2024, 07:54 AM
RAIV-Z's Avatar
On our last track outing on May 27th, we encountered a transmission problem. The tune set the launch boost to approximately 14 lbs, which is about 6 lbs more than our previous launches. The initial hit was significantly harder than before, but shortly after, we experienced a sharp decrease in acceleration. The car then started pulling again but rapidly shifted from first to third gear, accompanied by a sharp decline on the G meter. Reviewing the data logs, we noticed that both the converter charge and line pressure were extremely low compared to previous successful runs. While loading up to go home, we detected a distinct smell of burnt transmission fluid. We had been using John Deere Hy-Gard fluid, which we later discovered is not recommended for turbo cars.
Upon returning home, we removed the transmission and sent it out for inspection and refresh. Despite the burnt smell, the transmission was in good shape, except for needing a new front pump and replacing two clutches (actually replaced all of them) that showed some discoloration. After refreshing the transmission, we disassembled and cleaned the converter, flushed out the lines and transmission cooler, and then re-installed everything.
While checking fluid levels, I noticed that the driver’s side bank was reporting an AFR of 18-20. After thoroughly checking everything, I couldn't find any issues on that side. The engine ran and sounded great when I changed the tune to use the passenger side O2 sensor only. Eventually, I discovered a header leak on the #5 cylinder at the double slip collector. The mild steel tube on #5 had shifted enough to pull itself out of the collector. To fix the issue, Michael Hall extended the collector side for cylinder #5 by about 1/2 inch. Now, the O2 readings are correct on both banks.
After some general maintenance this weekend, we will be race ready.
Name:	2024-05-29 06.27.17.jpg
ID:	634955   Click image for larger version
Name:	2024-06-03 13.31.00.jpg
ID:	634956   Click image for larger version
Name:	2024-05-21 17.18.34.jpg
ID:	634957   Click image for larger version
Name:	2024-06-06 19.43.48-1.jpg
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #2066
Old 06-08-2024, 10:46 AM
Dragncar Dragncar is online now
Good to hear.
Your SFI T400 case, what brand is it ?
  #2067
Old 06-08-2024, 11:01 AM
Nice trans and nice RS/SS in the background! I sure get tired of fighting the top bolts on mine with the CSR trans shield!
  #2068
Old 06-08-2024, 09:41 PM
RAIV-Z's Avatar
Originally Posted by Dragncar View Post
Good to hear.
It's a Reid case.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #2069
Old 06-08-2024, 09:44 PM
RAIV-Z's Avatar
Thanks, the Camaro has a RAIV Pontiac engine with a 4 speed.
I hear ya, I was running a CSR trans shield a few years back. We swapped over to the Reid case when we broke the bell and part of the trans body back in October 2019. The Reid case is a really nice piece.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #2070
Old 07-05-2024, 05:37 PM
cgeise's Avatar
FYI Rosslier recommends HY-GUARD for their high HP turbo 400 --- not sure who told you not to ???
The Following User Says Thank You to cgeise For This Useful Post:
  #2071
Old 07-05-2024, 07:16 PM
RAIV-Z's Avatar
Hi Curt,
That was direct from Carl. Not recommended for a turbo car.
He did recommend a few options for a turbo car, the pricing was from a web search a few months back.
• TCI Max Shift Synthetic Transmission Fluid 950655 ~$14
• Mobil 1™ Synthetic LV ATF HP ~$9 BLUE LABEL
• LAT PRO-LITE ATF TRANS FLUID 20 WT ~26.75 WT
• Maxima SYN ATF 20WT ~$16 QT
Need to check on this one: Castrol TranSynd 668 Full-Synthetic Automatic Transmission Fluid, 5 Gallon Pail ~ $9.50 - $9.90 QT. No real world feedback yet.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #2072
Old 07-06-2024, 05:50 PM
461-69bird's Avatar
461-69bird 461-69bird is offline
If you go on drag race results.com, that 668 is used by alot of them. It's a bracket race forum but they all say the 668 reduces temps and works very well
69 Firebird
472, Bullet SFT, KRE 85cc, Victor, 850xp, TH400, TSP 9.5" 4800, 3.90 10 bolt, Viking DA rears, QA1 single fronts, 3558lbs. best to date 11.14@120
The Following User Says Thank You to 461-69bird For This Useful Post:
  #2073
Old 07-06-2024, 06:39 PM
Drag Star Le Mans's Avatar
Thanks, the Camaro has a RAIV Pontiac engine with a 4 spd.
That has got to hurt the Chevy guys feelings.
DragStarLeMans
The Following User Says Thank You to Drag Star Le Mans For This Useful Post:
  #2074
Old 07-12-2024, 10:33 PM
67'7F6'Bird's Avatar
This is the RAVEN in its current state awaiting a Saturday Morning delivery from DCI Motorsports. Don Johnston put all hands on deck with this new set of DCI Ram Air V Heads. These New Castings feature a Slow Burn Combustion Chamber, Lower Compression ratio, larger copper seats, much more meat in the shared wall right below the seats and appropriate port work. Much more done to the heads which Don can answer.
We hope to get the engine back together and be able to bring the RAVEN to Norwalk for the 2024 Pontiac Nationals and improve upon our previous best of 7.36 ET @ 194.32 MPH.
Send Positive Vibes!!!
~The Raven Racing Crew
https://www.facebook.com/groups/220092308823847
  #2075
Old 07-13-2024, 06:39 AM
Get'R done!
Hoping for the best.
  #2076
Old 07-13-2024, 08:30 AM
Scott Stoneburg's Avatar
Good luck on setting a new best!
The Following User Says Thank You to Scott Stoneburg For This Useful Post:
  #2077
Old 07-16-2024, 09:36 PM
The RAVEN will be at Norwalk.
  #2078
Old 07-16-2024, 10:38 PM
PAUL K's Avatar
PAUL K PAUL K is offline
RAVENTTFMF's!!!
Best of luck!
Go fast, see Elvis!
  #2079
Old 07-17-2024, 09:56 PM
74SDformula's Avatar
74SDformula 74SDformula is offline
Really looking forward to an in person look at all of your hard work. Hope the weekend goes as planned.
  #2080
Old 07-18-2024, 10:54 AM
mgarblik mgarblik is offline
Do you know approximately where you will be pitted? I would like the chance to see it up close in person. I always miss cars and people I would like to see at Norwalk. The event is pretty vast and spread out.
