Old 07-07-2024, 10:20 AM
i82much's Avatar
i82much i82much is offline
Default Isolate heater core in summer
Anyone use valves in their heater hoses to manually isolate the heater core in summer? Curious if it makes a worthwhile difference. 65 GTO, non-ac car.
Old 07-07-2024, 10:21 AM
I was wondering that myself as the 64 Corvette I am working on they used them on both lines -as well as made a spaghetti bowl of heater and A/C hoses that is butt ugly!
Old 07-07-2024, 10:44 AM
Why for summertime do you not just use a union to jump it out instead of spending far more money on a control valve?
And yes it makes a difference as that’s why ac cars have control valves, a ton of difference , no.
Old 07-07-2024, 10:56 AM
i82much's Avatar
i meant something like this:
https://www.amazon.com/Joywayus-Auto...Y2hfYXRm&psc=1
Old 07-07-2024, 11:09 AM
a fine example of installation from the ad...
The Following 3 Users Say Thank You to Scarebird For This Useful Post:
Old 07-07-2024, 11:22 AM
Nope never done that and we drive the cars in 100+ temps. Plus it's butt ugly. I'd gasp if I opened my hood to that and then quickly close it before anyone else saw that mess
https://youtu.be/XqEydRRRwqE
Old 07-07-2024, 11:31 AM
i82much's Avatar
the day that valve is the ugliest thing under my hood, i will kneel down and thank the heavens.
The Following 5 Users Say Thank You to i82much For This Useful Post:
Old 07-07-2024, 11:39 AM
At 20 bucks this is a far cheaper and far less unsightly solution.
If you jack up the ass end of the car 8” when installing these you will not even spill any coolant.
Old 07-07-2024, 12:02 PM
PAUL K's Avatar
PAUL K PAUL K is offline
I think one gets more heat through the floor boards from the headers than hot water circulating through the heater core. Plus running the heater on high can help cool the engine down if you get caught in a traffic jam and the temperature starts creeping up.... That's what summer time cruising is all about. Sweeting like crazy with the heat on high, windows down and showing off the Burger King drive thru rough idle camshaft.
Go fast, see Elvis!
The Following 4 Users Say Thank You to PAUL K For This Useful Post:
Old 07-07-2024, 01:00 PM
zippy's Avatar
zippy zippy is offline
I pinch my heater core line in summer. And notice it helps the engine cool a little better. Not recirculating hot coolant from head back to water pump.
Dan Pesonen
"If it ain't broke, modify somethin till it is"
Old 07-07-2024, 01:42 PM
grivera's Avatar
grivera grivera is offline
Prior owner of my 66 made this contraption - a 3/4 to 5/8 reducer would have been so much easier…
Will Rivera
Old 07-07-2024, 03:05 PM
Formulas's Avatar
Formulas Formulas is offline
I haven't used this yet 5/8 barbed 1/4 turn ball valve from Lowes or Homie'D
Old 07-07-2024, 03:17 PM
LOL I knew I could count on you to find the humor in that
Old 07-07-2024, 04:48 PM
77 TRASHCAN's Avatar
I've used stuff like that. You can buy smallish valves like that with 1/2" female pipe threads. I buy the barb fittings from a parts store.
Yes, it does work.
I work on school buses. They all have heater valves, and all are common hardware ball valves. Older models had gate valves.
Some of the older buses only used one valve. It did its job. I just didn't trust one valve on my car...
Shut it off
Shut it off
The Following User Says Thank You to 77 TRASHCAN For This Useful Post:
Old 07-07-2024, 05:30 PM
i82much's Avatar
is it better to bypass or block it entirely?
Old 07-07-2024, 05:47 PM
NeighborsComplaint's Avatar
.. or you could just set your heater control valve to the coolest setting limiting coolant flowing through the heater core, but I guess that would be too easy.
Triple Black 1971 GTO
Old 07-07-2024, 06:13 PM
Didn't GM-Pontiac have 1 vacuum-pot controlled heater valve, like in 69-70 cars?
Old 07-07-2024, 06:24 PM
Formulas's Avatar
Yes my 1970 Van Nuys Formula had a vacuum operated heater control valve, pretty sure only time it was open was when heat was selected they liked to freeze up as in not operate and they would leak coolant as well, i took mine off for the leak when i got the car in the 90's
Old 07-07-2024, 06:28 PM
i82much's Avatar
does a non-AC car even have one?
Old 07-07-2024, 06:32 PM
Just put the valves inline, in the heater hoses. Circulate the coolant to bleed the air out, with the valves open. Then just turn them off in the summer.
Shut it off
Shut it off
