Old 07-25-2024, 09:37 PM
Scott Stoneburg's Avatar
Default 72 Firebird build
My friend recently bought this twin turbo '72 Firebird. Is mostly done, just have to finish the interior. It's super nice, 461 twin turbo, motor was done by Butler, 3" oval exhaust, 6 speed trans, 9" rear. He wants to lose the bulky seats, supposedly out of a Bentley , and install new door panels and carpet, headliner. Needs some touch ups on the dash.
It has Ram Air manifolds for exhaust, how much you think that is killing the power or not on a turbo set up?
He adds this to his collection, others include a
68 Conv. GTO
65 GTO
67 GTO
78 Trans Am.
ID:	637446   Click image for larger version
ID:	637447   Click image for larger version
ID:	637448   Click image for larger version
The Following 4 Users Say Thank You to Scott Stoneburg For This Useful Post:
Old 07-25-2024, 11:16 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Very cool!
Go fast, see Elvis!
Old 07-26-2024, 02:09 AM
krisr's Avatar
krisr krisr is offline
Absolutely zero. Log manifolds on LS stuff will go 1000hp all day with pretty good EMAP. Just make sure you give priority to the wastegate and size it right - mine is on the passenger side crossover right on the corner of the bend and it handles the boost easily in a 3port configuration to the bottom port on the gate. I found with my turbo car with the stock manifold + log manifold, ceramic coating + wrapping the log manifold was the best for heat management and keeping the sparks inside the wires
Old 07-26-2024, 07:33 AM
Cool, thanks Krisr
Old 07-26-2024, 12:42 PM
Cool car, well done.
Old 07-26-2024, 06:38 PM
70 bird's Avatar
70 bird 70 bird is offline
X2 I run log manifolds with a 2 1/4 hotside and it works fine. For the street manifolds are fine plus they don't leak. The largest restriction to flow is in the turbine housing. You can put a large of a pipe as you want in front of a restriction, and it doesn't help anything.
Old 07-26-2024, 09:48 PM
Thanks for the input! Really making me rethink doing a turbo build, other than starting from scratch it's so tempting. So much potential.
Old 07-26-2024, 10:08 PM
R 70 Judge's Avatar
Pretty sweet build! I like it
James
1970 Trans Am
Old 07-28-2024, 09:03 AM
krisr's Avatar
I was a big cube NA guy for years and went to the dark side a few years ago. It's the most fun you can have wearing pants
