Old 08-01-2024, 06:04 PM
DaleO's Avatar
DaleO DaleO is offline
Default Our Pontiac's camshaft length
Does anyone know off the top of your head what the length is? I'm taking some planning measurements and am wondering if I'll be removing the trans cooler or can scoot it enough for an in chassis swap. Thanks.
Old 08-01-2024, 06:24 PM
You can’t just unbolt the non hose end of the cooler and pivot it down below cam height?
Old 08-01-2024, 06:25 PM
242177P's Avatar
242177P 242177P is offline
Just measured 22 1/2"
The Following 2 Users Say Thank You to 242177P For This Useful Post:
Old 08-01-2024, 06:29 PM
I would think that if you measure the length of a push rod cover and add 3 inches to that then such a measurement should be more then enough.
Old 08-01-2024, 08:08 PM
ID67goat's Avatar
ID67goat ID67goat is offline
Is this on a 66/67 GTO? If so, I am doing this now on my 67 and I had to unbolt the horns to have enough room to get the cam out.
The Following User Says Thank You to ID67goat For This Useful Post:
Old 08-01-2024, 09:07 PM
Depends.
Is it a 326 cam, a 400 cam or a 455 cam we’re measuring?
The Following 4 Users Say Thank You to b-man For This Useful Post:
Old 08-01-2024, 09:29 PM
If it’s only a 2bbl cam it’s even shorter!
Old 08-01-2024, 09:35 PM
johnta1 johnta1 is online now
I thought it was the 3/4 cam that was shorter?
The Following 3 Users Say Thank You to johnta1 For This Useful Post:
Old 08-01-2024, 10:22 PM
grivera's Avatar
grivera grivera is offline
Interesting- I pulled the cam on 66 and only had to remove the radiator
Will Rivera
The Following User Says Thank You to grivera For This Useful Post:
Old 08-01-2024, 10:47 PM
65 Lamnas's Avatar
Now when someone asks you, "how big a cam you got?" you can tell them 22-1/2 inches.
The Following 4 Users Say Thank You to 65 Lamnas For This Useful Post:
Old 08-02-2024, 01:33 PM
DaleO's Avatar
Probably, I hope so. I'm just doing a mental installation test run for an eventual swap and just don't have the cam (or any for that matter) yet.
Old 08-02-2024, 01:34 PM
DaleO's Avatar
Thanks!
Old 08-02-2024, 01:38 PM
DaleO's Avatar
Thanks! Yep 67. With the 22 1/2" value I can definitely see the need
Old 08-02-2024, 01:42 PM
DaleO's Avatar
Thumbs up
You "sizers" are cracking me up.
Old 08-02-2024, 01:44 PM
DaleO's Avatar
Hey! I just became a Senior Member with this post!
The Following User Says Thank You to DaleO For This Useful Post:
