Old 08-17-2024, 05:40 PM
joes455 joes455 is offline
Default Lower pully cracked
Took a little cruise pulled in the garage and noticed a sound that seemed like rod knock.Noticed this crack on the lower pully
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119
Old 08-17-2024, 05:52 PM
steve25 steve25 is online now
Very lucky you were able to get it home before it failed all the way and took out your radiator.
That’s sure aggravating but better than something internal.
The Following User Says Thank You to PontiacHO For This Useful Post:
Old 08-17-2024, 06:35 PM
yahooskidoo's Avatar
yahooskidoo yahooskidoo is offline
Default Pulley
If you need a replacement I have like 6 of them, if you post the part # I'll take a look.
Old 08-17-2024, 07:07 PM
dv657172's Avatar
dv657172 dv657172 is offline
Dont mean to hijack this thread but having a hard time removing my lower pulley. It wouldnt pull off the balancer once I removed the four screws. Even the reinforcing ring wont come off. I currently have the balancer, pulley and reinforcing ring off the engine all as one unit, none of which will seperate. Any ideas?
DV
Old 08-17-2024, 07:18 PM
Sounds like it’s all rusted together .
If it’s not too badly cracked then
Put the bolts back in
Put the belts back on and tighten them up
Then back the bolts out 1/16” and start the motor.
The load force my be enough to bust it free.
If not then it time to drive a big ass chisel or pry bar behind the pulley to split it free off the face of the balancer.
Old 08-17-2024, 07:23 PM
Thanks yahoo pn is 481038yb I really don't think it would be safe to reweld this.I need one like yesterday ,going to the track Sat.Thanks in advance
Old 08-17-2024, 07:32 PM
dv657172's Avatar
Thks Steve. It looks like chisel is coming out as engine is out of car for a dipstick tube replacement. If you get bored pls wander over to the heating and cooling section for my water pump question as I have had a lot of looks but no replies.
DV
Old 08-18-2024, 09:48 AM
Can this pulley be repaired by welding temporarily so I can race it ?
Old 08-18-2024, 10:47 AM
Question
DV
Just answered my own question about welding, after some more sanding around bolt holes.When was the last time you checked your lower pulley?
Old 08-18-2024, 11:22 AM
Looks also like rust pitting was involved in the start of the crack.
Old 08-18-2024, 12:03 PM
Did you have the support washed spacer in place when it cracked?
Old 08-18-2024, 12:47 PM
Yes and all bolts were tight when removed.Support bracket was installed in front of pulley
Old 08-19-2024, 06:08 PM
Default Pulleys
Heres what I have.
ID:	638626   Click image for larger version
ID:	638627   Click image for larger version
ID:	638628   Click image for larger version
Old 08-19-2024, 06:19 PM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
I wouldn’t weld it but if you do be sure to drill holes at the ends of the cracks
