Wouldn't a pontiac starter be somewhat useless under that kind of heat emanating from the block...at least until she cools down?
Esquire '74 T/A 455 Y-code SD clone previously on Dawson's Creek: '74 T/A 400 '81 AMC SX/4 '69 FB 350 |
I guess that would create a pretty easy test for the OP. When the engine is off and heat soaked, disable the fan in the ecu, then attempt to start.
The Following User Says Thank You to JLMounce For This Useful Post: | ||
I still run a factory type starter, but it's fairly new. My engine soaks to about 210 if I've been hard on it and shut it down. No issues with cranking the engine after sitting for 5-10 minutes or so.
Spot on I believe
The Following User Says Thank You to Randylk For This Useful Post: | ||
A 165 thermostat but it typically runs 20--25 degrees above the thermostat rating? The thermostat is not in control of engine temperature. The electric cooling fan MAY be in control--but perhaps not adjusted properly, or perhaps it's not in control either. Your cooling system has genuine problems. PROBABLY related to the "$3500 radiator and fan set up". What temperature is the fan engaging? What temp does it disengage? Last edited by Schurkey; 09-13-2024 at 09:25 PM. |
My thoughts exactly. I have an iron head 455 that runs 180 all day with a stock water pump and a stock 4 row radiator. My entire drivetrain cost about a third of this guy's cooling system - AND runs way cooler. WTF?
Just curious…does it not turn over or turn over really slowly, or does it just not fire
I don't know, things are only getting more expensive. I just bought a radiator from Griffin for the Vega, that was $1200 alone, and it's not a very big radiator either.
The Following User Says Thank You to Formulajones For This Useful Post: | ||
I asked about that way back in Post #2, and never got a response beyond "doesn't have a problem cranking".
Can you post a picture of the radiator/fan setup?
Hopefully you are not using one of those dual electric fan setups with the shroud about 1" deep. They only use about half the radiator.
The Following User Says Thank You to dataway For This Useful Post: | ||
I'm wondering about this also like Schurkey. 165* thermostat and you say the engine runs at 185-190* It appears to me something is not doing a proper job in the coolant system. That's the other thing to that has been asked. What is the fan on/off temperatures. When the thermostat opens at 165* you better have the fans running. Do a test, turn your fans on when you start the engine and see if the thermostat controls your engine temp. Oh, put the new stat in first. Like has been mentioned, change thermostat. Get a decent stainless thermostat from Napa. https://www.napacanada.com/en/p/THM1...QiLpSLPMSBSI4h
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 4:11 gear. 29" slick. Best so far 9.95@134 mph. 1.43 60 ft. 76 Trans am, TKX .81 o/d, 3.73 Moser rearend, 468 with KRE D-ports, Doug headers, 3" Exh. Last edited by chuckies76ta; 09-14-2024 at 07:10 AM. |
What kind of gauge are you running, or are you looking at the handheld for coolant temps?
Yup, pics would help a lot. Water pump divider clearanced? AC pulleys? What BRAND T-stat? (And which one) Are you running a bypass regulator or deadhead? (the Sniper internal regulators are known to be a problem) Fuel heat soak usually isn't an issue at EFI fuel pressures so those changes aren't going to have any positive effect. Look at the attached image, these are the relevant items, as well as the 'Cranking Timing' value. .
A cooling system with enough reserve capacity should be able to keep the engine at thermostat temp. I looked at "entropy radiator" and it looks like a very expensive billet version of the dual-fan setups we've all seen. I have NEVER had luck with a system like that. They don't flow enough air through the core, especially when the fans are off. On my current '67, I just removed a dual paddle fan system like that and replaced with a stock clutch fan and shroud. Even with no thermostat it ran at the turn-on temp of the electric fans, 185-190. That's a sign of blocked airflow. I ran the car with the clutch fan and no thermostat, and the hottest it got was 170 stopped in traffic and 150F going down the road. So with a good 180F thermostat, I know I have some reserve cooling capacity. It never gets over 185 when running, and when I shut it off, it climbs to 200 on a 96* summer day. Not bad for a used fan and shroud and a $50 fan clutch The other thing to consider is sediment in the cooling system. If an engine has rusty or clogged cooling passages, the parts of the block sitting under sediment builds heat. Upon shutdown, that area sheds the built up heat to the water, which then spikes in temperature. If any rust or sediment is coming out during flushes, it needs to be flushed until the water runs clean. Also check the radiator for clogs due to crap coming from engine block. https://entropyrad.com/collections/radiators
I could explain all this to the girl at the parts store, but she'd probably call the asylum. White '67 LeMans 407/TH350/Ford 3.89... RIP Red '67 LeMans. 407/TH400/Ford 3.25 Last edited by chiphead; 09-14-2024 at 09:10 AM. |
The Following User Says Thank You to chiphead For This Useful Post: | ||
I believe the term for spike in coolant temp after shutdown is 'after boil'.
Very amateur design work in my opinion. Those shrouds should have a metal- or rubber flap that can open at speed to allow "ram air" movement, but closes when the vehicle is moving slowly or stopped. |
The Following User Says Thank You to Schurkey For This Useful Post: | ||
I've been down that road experimenting with setups like that. It seems there are a bunch of radiator/fan companies that design there electric fan setups like that and every one I've tried always had an issue passing enough air to control engine temps. What ends up happening when I tried it is eventually the fans just run all the time, even on the highway, because even at speed it's a struggle to get air through the radiator when so much of it is blocked off. I had a big thread about it the last time dad wanted to try it on his GTO and even had Cold Case involved, adding holes and rubber flaps all around the electric fans where I could fit them and it was just never enough to control the issue.
I completely got away from those setups years ago and now only use a good quality radiator with the factory shroud and a clutch fan setup. Now I can't even get the engines hot in the AZ desert heat. |
If a thermostat is rated to start opening at 180*, are we suggesting that the cooling maintain that temperature even when the valve is not fully open? I'll put my helmet on for this one as this makes no sense. It seems nornal to have the operating temperatures 15-20* above the thermostat rated opening point.
Some guys have probably over engineered their cooling system and can maintain coolant temperatures when the thermostat valve is only partially open and is what I think is actually going on here. And maybe to a lessor degree, guys with more modest cooling systems but with cooler air temperatures (less demand on system) see the same situation occuring. Seems to be a bit of stretch to say a cooling system has "lost control" not maintaining the thermostat rated starting opening temperature but never overheats the engine. My cars run 180* thermostats and typically run 195-200* no matter what I throw at them, driving style wise, and see almost zero ROI chasing something like this down. |
#38
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop
The Following User Says Thank You to nUcLeArEnVoY For This Useful Post: | ||
#39
#40
Here is my experience with 160* thermostat in both vehicles. The 160* thermostat starts to open at 160* and it only takes a less than say 15 sec to be fully open. Having said that the cooling system in both cars maintains the 160 degrees give or take a few degrees. If the coolant system is design/ working properly there is no 15/20* swing in temperature. As the coolant temperature increases or decreases that is when the thermostat modulates to accommodate the coolant system. I can run my car with the 160 * thermostat in any outside temperture and it never goes above 160*. The Firebird with the IA2 at 789 hp is a different animal, only runs at the track.On the street in really hot, 85-90* F weather it cannot get enough air through the radiator when driving slow with the electric water pump and dual fans. At the track if only hits around 170-175* in same hot temperature outside. So it has a 160* thermostat and the system cannot keep up when the vehicle is driven slowly in very hot weather. At the track with heat it up to 160* and do the 1/4 mile run with it reaching 170-175* when back at our pit. Morel of all this, if you have a 160,165,180,190 degree Stat the coolant system should maintain that temperature.
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 4:11 gear. 29" slick. Best so far 9.95@134 mph. 1.43 60 ft. 76 Trans am, TKX .81 o/d, 3.73 Moser rearend, 468 with KRE D-ports, Doug headers, 3" Exh. |
The Following User Says Thank You to chuckies76ta For This Useful Post: | ||
